2002 4Runner SR5-- Are hoses missing from this small pipe?
Discussion in '3rd Gen 4Runners (1996-2002)' started by ahoss4runner2002, Jul 28, 2020.
  1. Jul 28, 2020 at 7:23 AM
    ahoss4runner2002
    ahoss4runner2002 [OP] New Member
    Andy
    2002 4Runner SR5 2WD 3.4L
    Hello all,
    Just joined this forum. I recently saw that there is a pipe on top of the engine with no rubber hoses attached to it. I bought the car brand new in 2002. Maybe the mechanic that did valve cover gasket job 6 years ago forgot to put them back on .
    I appreciate if someone can look at his or her truck and let me know .
    Thanks in advance.
    20200724_162724.jpg 20200724_162604.jpg 20200724_162708.jpg 20200724_162622.jpg
  2. Jul 28, 2020 at 7:42 AM
    Mohoman
    Mohoman New Member
    Sean
    99 Limited
    Queen of Battle
    Welcome OP!! Looks like a vacuum hose to me. Part should be 90999-92002. Hopefully someone else will confirm but the piece seems to be inexpensive and is probably an adjustable size part from factory! Cheers
  3. Jul 28, 2020 at 8:56 AM
    ahoss4runner2002
    Andy
    Thanks for your reply. The truck seems to be working fine without them if actually they need to have connections. On the driver side it is obvious there is an capped off angled pipe next to it , on the other site it is not clear where it may need to connect to.
    Hopefully, someone with the same model can verify if indeed this pipe needs connections.
  4. Jul 28, 2020 at 11:02 AM
    My 02 had the same pipe, and was not needed, i believe it is for some sort of re-route, i forget what exactly.
  5. Jul 28, 2020 at 11:14 AM
    ahoss4runner2002
    Andy
    That's great. Thanks a lot.
  6. Aug 2, 2020 at 7:38 AM
    RUNNER96
    RUNNER96 New Member
    Aldo
    1996 4runner 4x4
    TRD blower, snow performance methanol injection, headers,flowmaster, ported & polihed heads, high performance cams, 4.88diff gears.
    Hello. It’s got to have a vacuum leak behind the plenum, small, but still. Just put the hoses and your 4runner will be run better.
  7. Aug 3, 2020 at 11:07 AM
    Bought my 2002 SR5 4x4 new. I have NEVER taken it to the dealer. I just redid the top end of the engine, replacing all molded hoses with TOYOTA ones. I've been over the parts diagrams more than a few times.
    That metal hose has NEVER had anything attached to it. There is no part listed for it that I found. It always has seemed odd to me all the way back from when I bought the car. Also, it is not connected into the manifold in any way.
    I DO think I read somewhere it may be used for the SUPERCHARGER.
    That plastic capped port farther back is also 100% factory.
  8. Aug 3, 2020 at 11:11 AM
    That part number, when checked, fits no 2002.
  9. Aug 3, 2020 at 1:03 PM
    Mohoman
    Mohoman New Member
    Sean
    99 Limited
    Queen of Battle
  10. Aug 3, 2020 at 1:07 PM
  11. Aug 4, 2020 at 5:55 AM
    RUNNER96
    RUNNER96 New Member
    Aldo
    1996 4runner 4x4
    I still can’t figure out this site, but I think I posted t2 pictures of what exactly what ahoss4runner needs.
  12. Aug 4, 2020 at 6:25 AM
    What year car is this? It doesn't look like a 2002.
    You are missing the big fat hose at the back of the engine that is in OP's pics. Look for the one with the white painted line on it where it goes in the bracket that you don't have. You don't have that setup. The metal hose is probably a holdover from your car's year to ours.
    ahoss4runner needs nothing. His setup is fine.
    -Mike
  13. Aug 6, 2020 at 8:39 AM
    RUNNER96
    RUNNER96 New Member
    Aldo
    1996 4runner 4x4
    It’s from a 97
  14. Sep 29, 2021 at 6:32 PM
    tidmarshsmiths5
    tidmarshsmiths5 New Member
    upload_2021-9-29_21-31-59.jpgBut where does this go?
  15. Jun 26, 2024 at 6:41 PM
    Tommy02runner
    Tommy02runner New Member
    Tommy
    02 4Runner limited
    I have the same and mine doesn't have a hose I think it's leftover from the other model! Lol
