2000 rear window problems
Discussion in '3rd Gen 4Runners (1996-2002)' started by handslikekyle, Nov 11, 2019.
  1. Nov 11, 2019 at 12:47 PM
    handslikekyle
    handslikekyle [OP] New Member
    2000 4Runner
    hey guys, new to the forums and first post. I have scoured the internet and have yet to be able to find the right answer, so hoping for yalls help!
    My rear window does roll down and back up, but only when I use the key in the tail gate. none of the front controls work. I push the button and not even a sound comes out. I have checked all fuses and everything seems to be ok. curious of any suggestions?
    this car is about to hit 300,000 miles and im looking to start fixing up some issues in the next few months as I enjoy not having a car payment! Thanks in advance!
  2. Nov 11, 2019 at 4:36 PM
    4scooter19
    4scooter19 New Member
    Oregon
    98 and 86 4Runners
    I would check the switch in the console for continuity. I'm guessing it took a crap or has gunk in it.
    4Runner fun likes this.
  3. Nov 12, 2019 at 9:45 AM
    handslikekyle
    2000 4Runner
    I'll give that a shot. Thanks!
  4. Nov 19, 2019 at 3:49 PM
    handslikekyle
    2000 4Runner
    so I had a chance to pull it off and check, and apparently there is no wire harness there! (I bought it awhile ago, it never worked.) gonna attempt to dig behind the radio and see if it maybe is just lying back there.
  5. Dec 10, 2019 at 12:52 PM
    Don't forget to make sure the window lock out is off too on the master driver's side window switch panel.
  6. Apr 25, 2020 at 1:59 AM
    Clutchplate
    Clutchplate New Member
    96 4runner 3.4 Liter
    Try turning on/off your rear window wiper. It may not be in the full down position and if it's not, your window will not roll down.
  7. May 18, 2020 at 11:52 AM
    Tha Krazy One
    Tha Krazy One New Member
    2002 4Runner SR5 SIlver Metallic 4x2
    I have the same issue with my '02. The switch is there but has no harness plugged int it. I swapped out my stock radio to replace it and looked around for a loose harness and couldn't find one.
  8. May 22, 2020 at 1:08 AM
    shake007
    shake007 New Member
    97’ Supercharged SR5
    Look under the center console. The switch was located by my ebrake maybe the harness is there?
  9. Jun 21, 2020 at 8:39 PM
    4Banger98
    4Banger98 New Member
    J
    Las Vegas
    98 4RUNNER 2.7 MANUAL 4x4 3RZ-FE
    If your rear wiper, window, rear dome light, defrost do not work make no sound/light at all, and if you replaced the switch and it's has wires connected it's a wiring problem. This pic is from the top of the liftgate and will cause many problems when broken!
  10. Apr 2, 2021 at 8:43 PM
    4runner allen
    4runner allen New Member
    What ever came of this? The switch is faux there's no terminals...
  11. Apr 3, 2021 at 11:37 AM
    PhantomTweak
    PhantomTweak New Member
    Patrick
    OREGON
    1999 4Runner, bone stock
    Don't forget to check the circuit breaker as well as the fuses.
    Having said that, not having any wires connected to the switch makes the switch work really poorly :D
    Look for the wires/plug that are supposed to go to it. Unless the PO cut the whole thing off, or out of the harness, for some reason.
    Good luck to you!
    Pat☺
