200,000 Mile 4Runner. What suspension components should I replace?
Discussion in '4th Gen 4Runners (2003-2009)' started by necits2014, Mar 7, 2019.
  1. Mar 7, 2019 at 2:09 PM
    necits2014
    necits2014 [OP] New Member
    2004 4Runner Limited V8
    Hello all! Purchased my first 4Runner over the summer. Think I got a good deal (2004 V8 w/ 200,000 miles for $6000). I had the Timing belt/ water pump, etc replaced shortly after purchase. Now looking into suspension. Obviously with this many miles the ride kinda sucks. I plan on doing struts, shocks, and springs in the spring (Looking at Bilstein 5100's). What else should I consider replacing while I have it apart (Control arm bushings, sway bar bushings,.... etc)? This will be my daily driver and won't see much off road (I have the FJ Cruiser for that :))
  2. Mar 7, 2019 at 2:18 PM
    HoBoDanny
    HoBoDanny Dude...
    Daniel
    Kentucky
    2004 SR5 V6 4WD 4Runner
    Welcome! I would check upper/lower ball joints, inner/outer tie rods, sway bar end links, sway bar bushings, control arm bushings, all rear suspension bushings, and grease the driveline. Don’t just replace it all inspect and replace what needs replacing.
  3. Mar 8, 2019 at 10:42 AM
    necits2014
    Thanks for the info! :) I'll post more pics of condition of components in the spring when I have it apart. Unfortunately no garage and its cold in CT right now!!
    HoBoDanny likes this.
  4. May 3, 2019 at 7:22 PM
    chassis
    chassis New Member
    Indiana
    Sold: 2005 4Runner SR5 V6 4WD
    Stabilizer bar links make a big difference.
    I have 205,000 miles and haven't replaced ball joints or control arm bushings. They don't appear to need replaced IMO.
    necits2014 [OP] likes this.
  5. May 9, 2019 at 10:24 AM
    necits2014
    Any recommendations on shocks and struts? What about coils? Honestly the extent of my off roading will be class 5-6 roads. I would like to put some 31" BF Goodrich A/T tko's on it also. Thanks!
  6. May 9, 2019 at 10:34 AM
    chassis
    chassis New Member
    Indiana
    Springs only if you need them, if you are referring to replacing due to high mileage. My 4Runner is a highway cruiser so hasn’t needed springs.
  7. Jun 3, 2019 at 8:47 AM
    captsolo
    captsolo New Member
    Tom
    nassau bahamas
    2005 SR5
    Agree with hobo advice here. I have 2005 4 runner with 150,000 and mechanic asked for the items mentioned by hobo, and I replaced them and they were cheap at Amazon.
    Ride in a 15 year old 4 runner can't expected to be like new 2019 4 runner (even with new struts).
    Price you paid ($6000) is ok. You can get to 400,000, but let the dealer do your tranny fluid change.
    I had the tranny fluid changed at 100,000 miles by the dealer (only). Special Toyota ATF.
    How's the tranny on yours?
