2.5 inch lift vs 3 inch lift?
Discussion in 'California' started by alexh2, Feb 16, 2021.
  1. Feb 16, 2021 at 8:47 PM
    alexh2
    alexh2 [OP] New Member
    2020 4Runner Venture (White)
    I know its such a slight difference, but do you guys have any opinions between the two? Lol I have no preference, just want to see if there are any pros/ cons for either.
    Can you guys post pics of your rigs if you have 2.5 or 3 inch lifts?
    Want to get an idea of what they'll look like after the suspension sits a bit too.
  2. Feb 16, 2021 at 8:57 PM
    Henry J
    Sacramento Ca
    3” OME with 285’s
    Thatbassguy and Mtbpsych like this.
  3. Feb 16, 2021 at 8:58 PM
    Doza615, Mtbpsych and SR5 Limited like this.
  4. Feb 16, 2021 at 8:59 PM
  5. Feb 16, 2021 at 9:06 PM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
    This is a great read. What size tire - how much lift.........and more..............
    https://trail4runner.com/2018/01/03/largest-tire-size-4runner/
  6. Feb 16, 2021 at 9:40 PM
    Mtbpsych
    Mtbpsych New Member
    3”
    Dat1Trd and Thatbassguy like this.
  7. Feb 16, 2021 at 11:08 PM
    Tuco S.
    Tuco S. New Member
    Does yours have KDSS? If so it's generally recommended to stay at 2.5" or less for the front. I don't think there is a consensus on that lift height restriction, but you may encounter some issues with lean and ride quality if you go much higher than 2.5". That said, I'll be going with a 3" Dobinsons (stock weight) which I feel should settle to around 2.5" due to the weight of my sliders and steel skids.
    If you don't have KDSS, I would do 3" front all day long.
    donnermel and Thatbassguy like this.
  8. Feb 17, 2021 at 3:43 AM
    3"/2" lift/leveling kit RevTek 275-70-17 tires20200807_201034[458] 4runner2.jpg
  9. Feb 17, 2021 at 5:48 AM
    Well, 2.5 is about the cutoff for needing new UCA's, so if you don't want to mess with that I'd stick with 2"-2.5".
    When I lift mine, I want to stick with 2" front. AFAIK, 3" doesn't really allow a bigger tire than a 2", and my thinking is I'd rather leave a little down travel left at 2" than being topped out at 3".
    Just my .02.
  10. Feb 17, 2021 at 3:14 PM
    Eye ball won't even notice the difference.
    Find a brand that you want and go with it.
    j4unner and Thatbassguy like this.
  11. Feb 17, 2021 at 4:25 PM
    Chris In Milwaukee
    Chris In Milwaukee New Member
    Chris
    3 inches might be at the ragged edge of where you might also need to consider a diff drop kit. When I chose mine, I asked about that from the vendor. 2.5 inches doesn’t need it. I did get new UCAs, though.
    Thatbassguy and Toy4X4 like this.
  12. Feb 17, 2021 at 5:03 PM
    I didn't mention in the previous post, we do have a diff. drop also. JBA UCA's installed too. Thanx for reminding me Chris..
  13. Feb 17, 2021 at 5:04 PM
    3" here no diff drop needed.
    Doza615 and Thatbassguy like this.
  14. Feb 17, 2021 at 8:14 PM
    SomeDogsLife
    SomeDogsLife 805 SoCal Girl
    Alyx
    Ventura County, CA
    2021 Venture Special Edition
    Matte Rivera Blue + black fenders, hood scoop & roof wrap, Full vehicle PPF, Smoked headlights & taillights, Ceramic window tint 5% back & 17% front + UV blocking clear windshield tint, Hydrophobic coated wheels & windows, fog light fangs.
    Do your bigger tires rub when turning?
  15. Feb 17, 2021 at 8:31 PM
    Rmacdon
    Rmacdon New Member
    RM
    2020 SR5 Prem
    3inch Revtek lift front 2 inch rear 285/70r17 Toyo AT III 17 Black Rhino Ridge -6 offset
    Soldierj613, Thatbassguy and Toy4X4 like this.
  16. Feb 17, 2021 at 8:35 PM
    Mtbpsych
    Mtbpsych New Member
    They did slightly in the front, little bit of trimming fixed it (trimmed a lot more than needed for more clearance when stuffing tires and also looks). Then of course, the dreaded body mount that was resolved with a body mount chop and having the caster adjusted.
    Rear tires have been stuffed and have no rubbing. They’re 295’s, so a true 33” tire.
  17. Feb 17, 2021 at 11:59 PM
    SomeDogsLife
    Alyx
    Ventura County, CA
    Looks real good! I kept the stock 265/70/17 tires but went with wider, offset wheels.
    I didn't end up trimming since the quarter panel was bent in enough to stop hitting the wheel well.
    As soon as I need new tires, I'm going to go bigger.
  18. Feb 18, 2021 at 12:15 AM
    Mtbpsych
    Mtbpsych New Member
    A part of me wishes I did that as well, and then started mods after factory equipment pooped out. Nice rig! I dig the color combo.
  19. Feb 18, 2021 at 3:27 AM
    2.3" front with medium duty coils
    1.5" rear heavy duty coils
    295/70/17 (33.5" × 12") tires
    NoochMTB, roc, Belfastboy and 7 others like this.
  20. Feb 18, 2021 at 4:51 AM
    Chris In Milwaukee
    Chris
    Stud. Now don't go gettin' all cocky since you're on holiday in Florida while the rest of us Up Nort' are iced up. :duel:
    That looks so bad ass...
    Toy4X4 and Thatbassguy[QUOTED] like this.
  21. Feb 18, 2021 at 5:05 AM
    Lol! I hope I can bring back some better weather with me.
    I couldn't be much happier with it. I'm still getting decent fuel economy. Acceleration is still good. I need to trim the mud-flaps but otherwise no rubbing.
    I can't wait to really test them out!
    Toy4X4 likes this.
  22. Jun 9, 2021 at 12:38 AM
    tgoodson1814
    tgoodson1814 New Member
    Taylin
    2021 Black SR5 Premium 4Runner
    Is this with a 3in lift in the front and 2 in in the back ??
  23. Jun 9, 2021 at 2:41 AM
    Yes it is. That is what RevTek (manufacturer) claims.
  24. Jun 9, 2021 at 10:15 AM
    tgoodson1814
    Taylin
    What exact kit did you buy ??
  25. Jun 10, 2021 at 2:18 AM
    It was the #432 kit, with the rear shocks and diff. drop.
  26. Jan 27, 2022 at 11:55 PM
    donnermel
    donnermel New Member
    dita.yota
    Truckee/Tahoe
    ‘16 Trail Premium Super White w/ KDSS
    Dobinsons lift and UCA, RCI sliders and front engine skid, H9 bulb swap, Sprint Booster, KnN air filter, Canvasback covers, Raingler cargo net, AVS Window Shade deflectors, Heritage Grill with raptor lights Summer Wheels: Ryder RR03 matte gunmetal with Falken Wildpeaks 285/75/17 Winter Wheels: 18” KD Wheels with Blizzaks Rack is OEM - but changed to black with LFD crossbars Diode Dynamics Ss3 fogs
    How is the suspension doing now? Which did you end up buying if you don’t mind? I’m thinking the same and have kdss as well. Thx!
  27. Jan 28, 2022 at 7:02 PM
    Belfastboy
    Belfastboy New Member
    2021 lifted pearl limited
    BP51’s/IKON rims 275 70 17 falkens Prinsu S&B CAI Pedal commander
  28. Jan 28, 2022 at 7:04 PM
    Belfastboy
    2.5 with UCA’s. It’s a limited so looks a bit strange.
  29. Jan 29, 2022 at 4:42 AM
    roc
    roc New Member
    Michigan
    2021 4Runner TRD ORP
    Looks great.
    What off-set are your wheels?
  30. Jan 29, 2022 at 5:51 PM
    Thank you!
    0 offset. The tires are pretty flush with the fenders.
    roc[QUOTED] likes this.
