1999 4runner Instrumental Panel Light Replacement Questions
Discussion in 'Lighting' started by feelingstoned, Oct 21, 2017.
  1. Oct 21, 2017 at 2:34 PM
    feelingstoned
    feelingstoned [OP] New Member
    Hey all. So I'm trying to switch my instrumental panel bulbs with blue LEDs. When I took everything apart the main backlight bulbs sockets (there's 3 of them) all came out burned and broken. When I put the new bulbs in only the right one works (look at the picture, the middle and left lights don't work). The bulb size is #24 NOT #194 (I purchased these first but they were not the right size). Where do I find new sockets for a #24 bulb? I searched everywhere online and nothing comes up. I found sockets for #74 and replaced those as needed. Also what size bulb and socket do I need for the AC panel? is it also #74? Thanks in advance!
    As you can see only the right side lights up.
    On the left is the socket that came out of my car (the green, burned out and broken) on the right side is bulb size #74
    The AC bulbs that need to be replaced:
  2. Oct 23, 2017 at 11:02 AM
    Bob
    Bob Member Staff Member
    Bob
    Any progress or updates on this?
  3. Oct 23, 2017 at 11:26 AM
    feelingstoned
    So far none. The AC bulbs are definitely not #74. As for the instrumental panel I still can't find the right size sockets anywhere
  4. Jun 19, 2018 at 11:58 AM
    Teamroper
    Teamroper New Member
    2000 Silver 4Runner
    Had the same problem. Maybe this will help. Also this helped me a lot!!!e079e01674272504c517b44c76408d9e_236fec9f7d1e582620a427c067b854bd560ae794.jpg
