1998 Cylinder 3 Misfire
Discussion in '3rd Gen 4Runners (1996-2002)' started by ZachG99, Apr 5, 2025.
  1. Apr 5, 2025 at 1:37 PM
    ZachG99
    ZachG99 [OP] New Member
    Zach
    I bought a 1998 3.4 Toyota 4Runner with 284,000 miles last week, and I’m dealing with a P0303 misfire on cylinder 3. I’ve replaced the spark plugs (OEM), ignition wires (NGK), and swapped ignition coils, but the issue still persists in cylinder 3. The spark plug in cylinder 3 is somewhat greasy and oily compared to all the other plugs, the threads are also much cleaner looking comparatively, the ceramic area also showing signs of oil contamination. I’ve noticed that the engine light will flash typically under hard acceleration, but then it goes away on its own after a bit. I can also feel more of a shake when the car is in gear idling compared to in park. Compression on cylinder 3 is solid at 190 psi, so I don’t think it’s an internal engine issue. Could this be caused by oil leaking into the spark plug well from a bad valve cover gasket or possibly worn valve stem seals? Has anyone experienced something similar or have suggestions on how to fix this?
  2. Apr 5, 2025 at 1:50 PM
    First off; thats the wrong plug.
    You need to use the dual electrode plug. Dont use the 4 prong plug either I was offered a set and burned all the prongs off of one.
    Second; I had this same cylinder and code, it was an injector.
    Superdave1.0 likes this.
  3. Apr 5, 2025 at 1:51 PM
    Its a 6 cylinder right? Those plugs look good even though there not the correct dual electrode.
  4. Apr 5, 2025 at 1:58 PM
    ZachG99
    Zach
    These were the plugs that were in, I just replaced them with the correct dual electrode plugs from Toyota and still have the same issue.
  5. Apr 5, 2025 at 1:59 PM
    ZachG99
    Zach
    Yes 3.4 engine. Is there anything to be concerned about with the plug from cylinder 3 having the ceramic being black from oil and all the other plugs are white? Or could this be a cause from the injectors?
  6. Apr 5, 2025 at 2:03 PM
    its not that bad really. But wrong plug.
  7. Apr 5, 2025 at 2:40 PM
    Does not look like the crush washer even flatened. To tighten plugs use a wrench and tighten the threads until stops with your fingers. Then using the wrench tighten:
    11:00 am to 3:00pm
    11:00 am to 3:00pm
    then 11:00 am to 1:00pm
    You will feel it tighten and compress the crush washer on the plug.
  8. Apr 5, 2025 at 2:49 PM
    Ya I would say the "cleaner" threaded plug was not combusting at all?
    Vote: injector
    You might want to do all six and new pig tails.
  9. Apr 5, 2025 at 3:04 PM
    ZachG99
    Zach
    When I replaced all 6 plugs I torqued them to 13 foot pounds per the spec. After driving around for a few minutes I pulled the new plugs back out and noticed the spark plug in cylinder 3 doesn’t have any change in color due to the heat like the other 5 plugs. I’m guessing the fuel injector is bad like you said.
    (Cylinder 3 spark plug is on right, notice the diode doesn’t have the coloration like the other plug)
  10. May 8, 2025 at 8:23 PM
    eagle_one_limited
    eagle_one_limited New Member
    Gonzo
    Los Angeles, CA
    2002 limited 4runner 2wd
    Did you figure out the issue?I have similar problems with my 4runner also
  11. May 8, 2025 at 8:25 PM
    ZachG99
    Zach
    Yes, it ended up being the fuel injector.
  12. May 8, 2025 at 8:31 PM
    eagle_one_limited
    Gonzo
    Los Angeles, CA
    Thanks for the quick response. I'm hoping mine is an easy fix too
  13. May 8, 2025 at 8:37 PM
    ZachG99
    Zach
    No problem, mine went bad electrically. It didn’t have any resistance when I tested it with a multimeter. You should be able to test yours without removing the injector or the fuel rail. If the resistance is good there’s still a chance it could be clogged.
  14. May 8, 2025 at 8:40 PM
    eagle_one_limited
    Gonzo
    Los Angeles, CA
    Thank you. I'll try that next
  15. May 8, 2025 at 8:40 PM
    BLKNBLU
    BLKNBLU New Member
    2019 Nautical Blue OR
    Same for me a couple years ago. Same symptoms, same steps to assess, same #3 location even. And same successful solution. But go through the steps to r/o other possibilities. I put in a set of 6 from Motor West.
