1994 4runner no spark at coil wires, newly replaced engine
Discussion in '2nd Gen 4Runners (1990-1995)' started by Somebodydope, Jul 22, 2022.
  1. Jul 22, 2022 at 10:05 AM
    Somebodydope
    Somebodydope [OP] New Member
    So last summer I swamped my 2nd gen up to the handles,
    took in lots of water and shot a rod out of the block.
    Since, I have purchased a 3vze with 160k miles and swapped it out.
    I also switched all the parts from my once running engine over to the new one.
    P.S pump , alternator , water pump ect
    Everything seems to be connected properly
    But now I have no spark.
    I have used my volt reader to see if I have voltage out of the coil and there is nothing
    One thing I have noticed is that the CEL is on when I switch ignition to ACC but turns off soon as I start cranking. If I remember correctly, the CEL use to stay on while cranking until the truck started but I am not 100% sure.
    Maybe this is an indicator to the problem I'm having ??
    There is also a ground wire I was unsure about on the passenger side, so I bolted it to the engine. Maybe in the wrong place, but would it cause no voltage coming from the ignition system..?
    Any help would be appreciated.
  2. Jul 22, 2022 at 11:33 AM
    Is this OBD1 or OBD2?
    Have you tried pulling codes to see if the computer\ECU is alive?
    If the ECU is dead or can not determine the engine timing, it won't energize the coils to make spark. So bad cam\crank sensors could be an issue.
  3. Jul 31, 2022 at 1:50 PM
    Somebodydope
    it is obd1 and no i havent tried to get codes as i dont really know how
  4. Aug 19, 2023 at 5:55 AM
    rolledrunner
    rolledrunner New Member
    1994 Toyota 4Runner SR5 4x4
    Not to bring this back from the dead, but OP did you ever figure this out? I am having the same issue myself now and it is driving me nuts
    thank you
