1994 4Runner build
Discussion in '2nd Gen 4Runners (1990-1995)' started by jdmasch, Aug 15, 2020.
  1. Aug 15, 2020 at 1:06 PM
    jdmasch
    jdmasch [OP] New Member
    1994 4runner
    Hey guys I’m new to the forum and a new Toyota owner.
    so about a month ago I picked a 4runner for 1200 off a guy in Phoenix AZ it ran and drove just had a bad cv boot so just to be sure I put two new cv axels on it and I have a click when ever I turn full lock left and barely push the throttle but don’t feel anything in the steering wheel or any kind of catching or biting at all maybe you guys can help me out. Everything is right as well.
    Next I would like to lift it just a little bit to put 33s or 35 12.50s on it what would you guys suggest. It’s not going to be a Dailey by any means it will see more rock and dirt then Asphault trying not to drop 3 grand into either but if I have to do so be it
  2. Aug 15, 2020 at 1:19 PM
    BestGen
    BestGen Member #57
    Paul
    Haunted Turnbull Canyon, CA
    Welcome aboard! :cheers:
    You can run 33/10.50s on the stock rims without a lift. I did it for years. Eventually I added a 1.5” ball joint spacer for a little extra lift. Let’s see some pics!
  3. Aug 15, 2020 at 1:52 PM
    jdmasch
    1994 4runner
    So I wanna put beadlocks on so I can air down in the sand and the rocks out here when I go to crown king or happy jack so what offset would you suggest. And I’ll threw some pics up later. I got a baby shower today for my second baby boy who will be here september 22
  4. Aug 16, 2020 at 9:45 AM
    trlhiker
    trlhiker Lazy Bum
    1992 4Runner SR5 V6 4X4
    That clicking sound may be you hitting to steering stop. Mine did that too and that is what the dealer told me.
  5. Aug 16, 2020 at 11:03 AM
    bthp223
    bthp223 New Member
    Nevada
    1990 4X4
    If you bought cheap axles it’s possible that a new one is out of spec.
  6. Aug 31, 2020 at 1:44 PM
    atgparker
    atgparker Cal Poly, ETME 1988
    Andrew
    Mission Viejo, CA
    1991 White 4Runner 3.0 L
    With 32x11.50R15's 4.88:1 R&P's would be the right gear ratio. Which engine do you have? The brakes can be enhanced with PowerStop drilled and slotted rotors with their semi-metallic pads. The idler arm will let you down running 33's or 35's. See the double shear design that Total Chaos makes for our 2nd Gens.
    Fourtoad and Thatbassguy like this.
