1991. 4Runner Auto Shifter Loose
Discussion in '2nd Gen 4Runners (1990-1995)' started by Arlail76, Mar 19, 2019.
  1. Mar 19, 2019 at 7:51 PM
    Arlail76
    Arlail76 [OP] New Member
    Andrew
    1991 Toyota 4runner
    Nothing but some 31s
    i have swapped for a 1991 4Runner and the auto shifter is loose. I bought the 2 bushings to replace, but after taking everything apart inside, I cannot seem to get to where those bushings are to replace. What am I missing? I thought it would be a quick fix, but I am struggling.
  2. Mar 20, 2019 at 6:13 AM
    Smitty86
    Smitty86 New Member
    Chris
    1992 Toyota 4runner
    Is it only loose at the column? Cause mine is as well and curious as how to fix it. It just wiggles left to right.
  3. Mar 20, 2019 at 6:26 AM
    I don’t know if this helps you or not but here a blow up.
    Rigo likes this.
  4. Mar 20, 2019 at 7:03 AM
    Smitty86
    Smitty86 New Member
    Chris
    1992 Toyota 4runner
    That definitely help. Thanks
  5. Mar 20, 2019 at 7:56 PM
    Arlail76
    Andrew
    1991 Toyota 4runner
    My shifter isn’t like that. Mine is the one with the button on top. When I took it all apart, I couldn’t get down far enough to get to where the bushings should be
  6. Mar 22, 2019 at 3:46 PM
    Arlail76
    Andrew
    1991 Toyota 4runner
    Does anyone have an exploded view of the 1991 version?
  7. Apr 5, 2019 at 11:55 AM
    Arlail76
    Andrew
    1991 Toyota 4runner
    I’ve purchased another complete shifter cluster to replace the one I got. I will put fresh bushings in it. My question is this:
    How difficult is it to disconnect the shifter arms that hook into the transmission and transfer case?
  8. Apr 9, 2019 at 11:26 AM
    Rigo
    Rigo New Member
    If you have the version with the button on top, there's a video of a Tacoma shifter bushing replacement on YouTube. Should be the same. But when I did mine it was in that cross bolt under the shifter like in the picture slvrslug shared
  9. Apr 9, 2019 at 11:27 AM
    Rigo
    Rigo New Member
    Took like 40 minutes maybe
  10. Apr 10, 2019 at 7:52 PM
    Arlail76
    Andrew
    1991 Toyota 4runner
    So, I’ve swapped out the shifter with another one that is way less worn out. I have a question:
    Is there a way to “adjust” the shifter for 4H and 4L?
    When I shift it from 2 to 4, I have to shift it all the way to 4L for it to go into 4WD at all. I know 4H and 4L both work...just gotta fine tune the change-out now
  11. Apr 11, 2019 at 8:06 PM
    Arlail76
    Andrew
    1991 Toyota 4runner
    Adjustment made and I’m good to go
