1990 gen 2 clutch replacement
Discussion in '2nd Gen 4Runners (1990-1995)' started by Skian, Aug 5, 2019.
  1. Aug 5, 2019 at 7:49 AM
    Skian
    Skian [OP] New Member
    3slow
    Rancho suspension, air bags for hauling Moto’s and camping with the kids.
    Well, the clutch finally went out on the 3slow, and we are deep into dropping the tranny with days to go before we head to the Stones in Seattle and have reached a stumbling point in the clutch replacement.
    It seems as though there are two pins at the bottom of the main seal housing and we can’t get it out. I can’t find any notes anywhere on how to get it out, does anyone have any ideas without dropping the pan?
    So basically after the removal of the pilot bearing we got stumped as instead of the 2 bolts that seem to come out of the bottom of the housing were nuts on he end of studs? We removed the nuts, but can’t seem to be able to knock out the rear main seal housing. Has anyone seen this before? I can’t find any info on it anywhere.
    Has anyone had this issue before, do I need to drop the oil pan, and if I do, can you do that without unbolting the motor mounts and lifting the motor?
    Thanks, Ian
  2. Aug 12, 2019 at 10:20 AM
    Skian
    3slow
    Nobody out there with any beta on this challenge.
