18 T4R Gas gauge and on board computer?
Discussion in '5th Gen 4Runners (2010-2024)' started by edgesalon, Oct 8, 2018.
  1. Oct 8, 2018 at 12:53 PM
    edgesalon
    edgesalon [OP] New Member
    Te
    18 FunRunner :-)
    Hello everyone
    when i fill up the fuel tank my on board computer only shows 350 to 375 miles for distance i knew we have 23 gallon fuel tank like the 4th Gen 4R. and i would get distance of 400 to 425 on the on board computer on my old 4R, what is going on any body have any info on this. is there a rest
    thanks in advance.
  2. Oct 8, 2018 at 1:45 PM
    4X4Runner
    The left coast
    It’s a really bad wild ass guess the computer gives. It’s based off the average MPG’s your computer is reading. You can reset the avg mpg by prettying set until you display the average mpg’s and then hold it to reset it to zero.
    scottalot likes this.
  3. Oct 8, 2018 at 7:30 PM
    edgesalon
    Te
    18 FunRunner :-)
    thanks i did that before i fuel up and did not make any difference
  4. Oct 8, 2018 at 8:50 PM
    4X4Runner
    The left coast
    don’t know what to tell you then, try less skinny pedal maybe?
    I’m averaging 15.5mpg (based on fill up and mileage) so I’m figuring 350 miles before I’m bone dry in the tank.
    scottalot and jgcaps like this.
  5. Oct 8, 2018 at 10:00 PM
    Kyblack76
    Kyblack76 New Member
    Layton, Utah
    18 TRD O.R
    You can stick a LOT more fuel in after the nozzle clicks full. I cram the shit outta mine after the nozzle does the first click "stop", a lot more. ,.. and have yet to ever see any 400 mile range on the screen.
    Mid 300s most I've ever seen. It will base it off what your averaging. Real time, your range will be adjusted by fuel at hand, and what your averaging at the time.
  6. Oct 9, 2018 at 9:44 AM
    edgesalon
    Te
    18 FunRunner :-)
    thanks
  7. Oct 12, 2018 at 3:17 PM
    Mass4runner
    Mass4runner New Member
    2023 TRD ORP
    Apparently this is a bad idea:
    https://oppositelock.kinja.com/dont-be-a-moron-stop-topping-off-your-gas-tank-1702676878
    Strandskov and COexplorer like this.
  8. Oct 12, 2018 at 3:25 PM
    4runningMan
    4runningMan New Member
    New Mexico
  9. Oct 12, 2018 at 4:34 PM
    4X4Runner
    The left coast
    Strandskov, scottalot and ruiz4251 like this.
  10. Oct 12, 2018 at 6:24 PM
    bigzook
    bigzook New Member
    2018 4 Runner SR5
    You can "Reset" your dist calculator by pressing and holding the mode button on your steering wheel. Also, by cramming fuel into your tank, you can flood the evaporative charcoal canister. It is designed to absorb excess fuel vapors from the fuel tank. Not a cheap repair. Never keep "topping off" your tank after the filler nozel clicks off..
  11. Oct 12, 2018 at 6:40 PM
    Mass4runner
    2023 TRD ORP
    While the meme was very convincing, do you have any actual data to support your cynicism? I'm genuinely curious, since I have heard from countless sources that topping off modern gas tanks is a very bad idea.
    Strandskov likes this.
  12. Oct 12, 2018 at 7:05 PM
    4X4Runner
    The left coast
    I think your assumption as to where the gif was directed is wrong. The gif was at the response I quoted and the “probably what your link says...haven’t looked at it yet”.
  13. Oct 12, 2018 at 7:23 PM
    Mass4runner
    2023 TRD ORP
    Well, that's why I shouldn't assume!
  14. Oct 12, 2018 at 7:54 PM
    4X4Runner
    The left coast
    The articles are really well written and descriptive. I say articles because in the comments he provides a link to a second part on it. I knew overfilling had an affect on the crap system but wasn’t sure how and that article spells it out pretty damn well.
    Mass4runner[QUOTED] likes this.
  15. Oct 12, 2018 at 10:34 PM
    4runningMan
    New Mexico
    I edited my post for you. Didn't mean to clutter the thread.
  16. Oct 13, 2018 at 3:05 AM
    scottalot
    scottalot Stockalot
    Scott
    Charleston SC
    2018 T4R offroad
    To be determined
    :wave:
  17. Oct 13, 2018 at 6:18 AM
    4X4Runner
    The left coast
    Hola bitchola! Ever find out if you have KDSS or not?
    scottalot[QUOTED] likes this.
  18. Oct 13, 2018 at 6:44 AM
    scottalot
    scottalot Stockalot
    Scott
    Charleston SC
    2018 T4R offroad
    To be determined
    I honestly haven’t looked again, haven’t stopped this week. But I will be going out to look shortly now. First thing is to change settings so I stop getting emails alerts to my stuff here haha
  19. Oct 13, 2018 at 8:01 AM
    j cat
    j cat New Member
    massachusetts
    spacer lift front 1inch
    375 miles is typical on a 5th gen ..same on my 2016 with all stock tires etc..
    when to cold temps hit it does drop down .. lower MPG in 35F and lower temp..
  20. Oct 14, 2018 at 9:57 AM
    edgesalon
    Te
    18 FunRunner :-)
    from what i read on the forums
    the on board Computer takes your driving average MPG and calculates an estimates of what you would get on a tank full of gas per your driving habits but I can tell you its not so accurate
    thanks to every one.
  21. Oct 14, 2018 at 3:56 PM
    j cat
    j cat New Member
    massachusetts
    if you drive in the city and speed is variable then not accurate as the computer will indicate different miles to require fuel.
    so you on a trip, hywy speed same the whole trip , then it is pretty accurate.. I have this work good when I do my 1700 mile drives to florida.
