12v socket location for my 2024 4Runner SR5?
Discussion in '5th Gen 4Runners (2010-2024)' started by NeverTooLate71, Dec 23, 2024.
  1. Dec 23, 2024 at 9:26 PM
    NeverTooLate71
    NeverTooLate71 [OP] New Member
    Bob
    2024 4Runner SR5
    I understand there may be a 12v socket in or on the center console of my 2024 4Runner SR5?
    Can anyone confirm that? Looking to power up a dash cam.
  2. Dec 24, 2024 at 1:13 AM
    Ummm. Yes. Under a round hinged plastic cover below the climate controls. There is another one in the armrest cubby.
  3. Dec 24, 2024 at 4:41 AM
    Imdav2u
    23 TRD PRO
    SOSHeloPilot likes this.
  4. Dec 24, 2024 at 4:45 AM
    Guppy1301
    Guppy1301 New Member
    Silver 2019 TRD ORP
    Besides the one on the dash that Cptn SpauIding pointed out, have 2 at the bottom of the console in the 2nd row. 2019 TRD ORP. I think the 2020 and up now have USB's there? Mine also has one inside the console.
  5. Dec 24, 2024 at 5:57 AM
    Does your dash cam take 12V directly or 5V USB power? There are adapters for tapping into the rear view mirror connector for a cleaner install. If you want the dash cam to run in surveillance mode while the ignition is off, you'll need to tap into the fusebox under the dash for constant power.
    Shredder likes this.
  6. Dec 24, 2024 at 10:52 AM
    SOSHeloPilot
    SOSHeloPilot New Member
    SouthEast USA & S.E. Asia
    2024 4Runner SR5
    Owned Many Toyotas - Past
  7. Dec 24, 2024 at 11:06 AM
    The fuse taps linked to above are not correct for use with the 4Runner. The 4Runner takes Low Profile Mini fuses.
    Look here.
  8. Dec 24, 2024 at 11:16 AM
    FourBelugas
    FourBelugas New Member
    23 white ORP
  9. Dec 24, 2024 at 11:29 AM
    Imdav2u
    23 TRD PRO
  10. Dec 24, 2024 at 11:55 AM
    Interesting. The image I posted was labeled as 2024. I wonder if the availability of a power outlet on the dash varies by trim level.
  11. Dec 24, 2024 at 11:57 AM
    FourBelugas
    23 white ORP
    wouldn't surprise me, your photo is from a Pro so it could very well be one of those "you must spend this much to get ____ part that saved us 2 dollars" thing they like to do.
  12. Dec 25, 2024 at 8:16 AM
    SOSHeloPilot
    2024 4Runner SR5
  13. Dec 26, 2024 at 8:42 PM
    NeverTooLate71
    Bob
    2024 4Runner SR5
  14. Dec 26, 2024 at 8:44 PM
    NeverTooLate71
    Bob
    2024 4Runner SR5
    Nope, not on mine. It's a USB type power outlet, not a 12v cigarette lighter type
  15. Dec 26, 2024 at 11:29 PM
    Interesting.
  16. Dec 27, 2024 at 4:29 PM
    NeverTooLate71
    Bob
    2024 4Runner SR5
    My 2024 4Runner SR5 only has a 12v plug under the arm rest.
  17. Dec 27, 2024 at 4:49 PM
    In my ‘22 there is what looks to be a knockout to accommodate adding a 12v outlet in the glove compartment. I wonder if the ‘24s have that.
  18. Dec 27, 2024 at 4:51 PM
    Imdav2u
    23 TRD PRO
    My 23 has that, the older 4runners came with a 12 volt outlet in the glove box
  19. Dec 27, 2024 at 5:02 PM
    Do the ‘24s have usb-c on the center stack?
    Edit: I would prefer to have the 12v outlet on the center stack. It can be adapted to USB-a, USB-c, and whatever comes next.
  20. Dec 27, 2024 at 5:04 PM
    Imdav2u
    23 TRD PRO
    My 23 does.
  21. Dec 27, 2024 at 5:47 PM
    My 2022 limited has it in the center lower dash.
    Captain Spalding likes this.
  22. Dec 28, 2024 at 1:06 AM
    RunningBear
    RunningBear New Member
    2023 TRD ORP, Lunar Rock, KDSS
    If there is power to your rear view mirror, than get this kit from Amazon: https://www.amazon.com/dp/B0CSPJTB3Q?ref=ppx_yo2ov_dt_b_fed_asin_title. You have to check the pin connectors in your car to be sure you order the right kit, they vary depending on whether your pin connector is 10 pin, 12 pin, and maybe a couple other sizes. My '23 ORP is 10 pin. The kit includes USB adapters.
    This vid clearly explains how simple it is to install. (They sell their own adapter which should work perfectly, but I ordered from Amazon to get fast delivery).
    https://www.youtube.com/watch?v=sCiGWb0tBFw
    You have an SR5 so their probably are some differences, i.e. you probably don't have the offroad controls (crawl, terrain, etc.) that I have in my ORP, and it is possible you don't even have power to the rear view mirror, so check all that first before ordering the kit.
    Also, my ORP has an optional accessory, which provides "dual power ports" (one regular USB port and one higher power USB charging port), and the higher power port is in the same spot where the 12v "cigarette lighter" port is shown in another member's car. Not sure if that means anything and possibly they just don't provide those 12 v ports anymore (except in the center console).
  23. Dec 28, 2024 at 4:57 AM
    My '24 does.
  24. Dec 28, 2024 at 8:06 AM
    SOSHeloPilot
    2024 4Runner SR5
    ...^^^... Ditto
  25. Dec 28, 2024 at 8:53 PM
    NeverTooLate71
    Bob
    2024 4Runner SR5
    Why would you need a 12v socket in your glove box?
  26. Dec 28, 2024 at 11:06 PM
    GMRS radio.
