10k oil changes
Discussion in 'General 4Runner Talk' started by Jynarik, Jul 24, 2019.
  1. Jul 31, 2019 at 9:33 AM
    #91
    DGP1961
    DGP1961 New Member
    2018 SR5 Premium
    I didn't want the doors to lock automatically after bringing it home called the salesmen up and he said bring it in. Took a whole five minutes or less free. Dealers just don't get it they would monopolize repairs if they brought their prices down within this atmosphere.
  2. Aug 2, 2019 at 1:33 PM
    #92
    Tuco S.
    Tuco S. New Member
    No worries, happy to help. In the 3rd link, Blackstone recommended the owner try a 12k interval for his next analysis.
    Oil change intervals are a source of contention on every forum. Lots of people swear that wear metals actually decrease with a longer interval, because detergents are much stronger when oil is fresh. I honestly don't know if it's true, but if it is true, you will see less wear metals with one 10k inveral than you will with two 5k intervals. Not to mention you would be saving a few bucks, and not wasting resources.
    Bottom line, the Toyota engineers didn't pick the oci numbers out of their butts. 10k is a conservative interval for normal use. 5k is a VERY conservative interval for extreme use. Every single uoa I have seen backs this up.
  3. Aug 4, 2019 at 6:40 PM
    #93
    DGP1961
    DGP1961 New Member
    2018 SR5 Premium
    I forget where but years ago I read an article that said you can actually change your engine oil too often.
  4. Aug 16, 2019 at 8:10 AM
    #94
    MountainMan
    MountainMan New Member
    Pacific Northwest
    I've always changed out the factory oil in new vehicles in the first 1000 miles or so due to all of the crap in the oil from the engine breaking in. But, I'm an old hot rodder and am basing that practice on building engines 30 years ago. Maybe Toyota uses a minimum of assembly lube and the tolerances are such that you don't get a bunch of metal shavings and other debris in the oil right off the bat.
    I've also heard that running synthetic oil before the first 10k miles doesn't allow the engine to properly break in.
    I don't know. I'm open to new opinions and facts. Like I said; my experience is based on decades old data and evidence. I could be completely wrong in my thinking, now. :oops:
    Oey12[QUOTED] likes this.
  5. Aug 16, 2019 at 9:50 AM
    #95
    2016Pro
    Not necessary anymore. Go check out bobistheoilguy.com a lot of good updated information on there.
    MountainMan[QUOTED] likes this.
  6. Aug 16, 2019 at 10:31 AM
    #96
    Oey12
    Oey12 New Member
    Joey`
    2017 SR5
    Eibach Pro Sport leveling shocks, Firestone airbags, and Baja Design fog lights...
    I think it really depends on the application. For example you are an old hot rodder, I would absolutely change the oil out in the first 1k on a vehicle like that and I would back up all day everyday in that argument. Or any drag racing or track car for that matter... My reason being it that typically those motors are a miss mosh of different aftermarket parts to achieve one goal...power to go fast. Most aftermarket parts or engine machining are not tested for reliability or longevity. Where as a mass produced motor is because the manufacturer needs to find the best balance of power, mpg's, longevity, and reliability. Now some manufacturers are better than others (I think Toyota is one of the best... I value reliability and longevity the most). For example I would not do 10k oil changes on the Ford Eco Boast engines because they are having a problem with oil getting real dirty real quick causing the oil to dilute badly. And I have met people who just who didn't really care. I took over my wife's car, which she bought brand new, at 90k to commute with (2009 V6 Honda Accord) and I got 175k before I traded it in. A family member took care of the car for her and used Walmart dino oil and followed the oil monitor which usually went off at about 7500k. That car had a pristine engine with zero sludge...go figure cause it always baffled me.
    WallyT4R and nimby like this.
  7. Aug 16, 2019 at 10:42 AM
    #97
    2016Pro
    On my Tacoma I typically change the oil every 12,500 miles. Occasionally I get the oil analysed by blackstone labs. Their last analysis suggested I could go to 14,000 miles. Brand of oil doesn't matter, I use Walmart supertech quite frequently. Whatever is on sale is what I use. I do run synthetic since I extend my oil changes.
  8. Aug 16, 2019 at 11:07 AM
    #98
    Oey12
    Oey12 New Member
    Joey`
    2017 SR5
    I agree with you brand really doesn’t matter. What I meant to point out it that even a non-synthetic oil can safely be used longer than originally thought with zero issues. So there is no reason a any API synthetic can’t go 10k especially in the 4.0 motors...
    WallyT4R, 2016Pro[QUOTED] and nimby like this.
  9. Aug 16, 2019 at 11:25 AM
    #99
    I think being able to run 10,000 miles on an oil change is incredible. Versus every 3,500 in earlier models. That’s almost three times as much, saves so much time and money....Guess the bearing tolerances have a lot to do with it? Computer and machining advancements...
  10. Aug 19, 2019 at 2:18 PM
    #100
    BananaWagon
    BananaWagon Highly Caffeinated
    Ray
    Nomad
    2019 Black TRD Off-Road
    None.... Yet.
    Attached is an oil analysis of the factory oil at 2200 miles prior to it's first oil change.
    Use it to support whatever side of the fence you are on.
    MountainMan and WallyT4R like this.
  11. Aug 19, 2019 at 2:25 PM
    #101
    Jynarik
    Jynarik [OP] I like boobies
    Austin Texas
    2019 trd pro voodoo
    How many miles? And what was your note that was taken into consideration?
  12. Aug 19, 2019 at 2:25 PM
    #102
    LKN4Runner
    LKN4Runner New Member
    Lake Norman, NC
    2016 Magnetic Grey Metallic XP 4X4 with 20" Gunner rims and 275/55 R20 Nitto Grappler G2 Tires.
    LOL
    Tama1968 likes this.
  13. Aug 19, 2019 at 2:27 PM
    #103
    Kinda makes me wish I had done my first oil change early.
    I wonder if the abrasives were due to break-in..
    Since I off-road, tow occasionally, and tend to drive the truck hard, I think I'll be sticking with 5K from here on out.
    WallyT4R likes this.
  14. Aug 19, 2019 at 2:29 PM
    #104
    Jynarik
    Austin Texas
    2019 trd pro voodoo
    I’ll be doing my initial oil change at 5k
    BananaWagon likes this.
  15. Aug 19, 2019 at 2:49 PM
    #105
    BananaWagon
    Ray
    Nomad
    None.... Yet.
    Changed at approx 3k miles. Sample at 2200 miles. Special note was "Factory Oil".
    WallyT4R and Jynarik[QUOTED][OP] like this.
  16. Aug 19, 2019 at 2:51 PM
    #106
    BananaWagon
    Ray
    Nomad
    None.... Yet.
    I just drove about 5k towing a trailer through mountains and such. I will do another sample with this oil as well.
  17. Aug 19, 2019 at 4:51 PM
    #107
    Jynarik
    Austin Texas
    2019 trd pro voodoo
    What oil are you going to use?
  18. Aug 19, 2019 at 5:46 PM
    #108
    BananaWagon
    Ray
    Nomad
    None.... Yet.
    I am using AMSOIL right now, but I am running a comparison between AMSOIL and Toyota's through analysis reports. If I don't see much of a difference in the reports I am going to stick with Toyota's oil.
    So I have a few more reports to go off of still. The first was just to see what the factory oil had it it after a few thousand miles and I will not use that in my comparison. I totally expected the results I got: high moly and high abrasives from wear in.
    I figured I would share what I got from the report for those who like data.
    MountainMan, WallyT4R and SlvrSlug like this.
  19. Aug 19, 2019 at 8:29 PM
    #109
    2016Pro
    Brand doesnt matter
  20. Aug 20, 2019 at 4:19 AM
    #110
    Jynarik
    Austin Texas
    2019 trd pro voodoo
    Bruh chill out. I’m well informed on oil.
    I’m asking him because he’s doing oil analysis’
  21. Aug 20, 2019 at 5:08 AM
    #111
    BananaWagon
    Ray
    Nomad
    None.... Yet.
    Correct, and it's all personal preference and what makes you feel warm and fuzzy on the inside.
  22. Aug 20, 2019 at 6:42 AM
    #112
    MountainMan
    Pacific Northwest
    It's the Joe Biden philosophy; facts are irrelevant in regards to whatever truth you want to believe.
  23. Aug 20, 2019 at 6:43 AM
    #113
    Oey12
    Oey12 New Member
    Joey`
    2017 SR5
    :cheers: Priceless...
    BananaWagon and WallyT4R like this.
  24. Apr 25, 2020 at 12:33 PM
    #114
    DallasTRDPro
    DallasTRDPro New Member
    Dallas
    2021 Honda CRV...UGH!
    My 2020 TRD Pro oil maintenance warning came on at exactly 5K miles. Do I just reset it or change the oil??
  25. Apr 25, 2020 at 12:53 PM
    #115
    Mtbpsych
    Mtbpsych New Member
    10k oil change. For some reason the display I guess on the 2020’s changed to that. Just refer to the manual though, should give you the accurate response.
  26. Apr 25, 2020 at 1:16 PM
    #116
    Do you drive in extreme conditions?
  27. Apr 25, 2020 at 1:17 PM
    #117
    DallasTRDPro
    Dallas
    Thats what I figured. The
    I don't think Dallas is extreme.
  28. Apr 25, 2020 at 1:23 PM
    #118
    If you're towing, going through dusty areas, or encountering big temperature changes often that would be considered extreme (according to the manual).
  29. Apr 25, 2020 at 1:28 PM
    #119
    DallasTRDPro
    Dallas
    I drove 3K miles in the first week when I went to Moab on a trip that had been planned for my Jeep, but got death wobble. The rest of the time it has been in 50-80 degree weather. No towing. Not dusty. The other 2K miles have been basically city driving of less than 3 miles a day until the last month when I had to find a county that wasn't shut down that I could coach soccer at a park. Now driving longer distances on highway. None of these things sound extreme. The dealership said it was weird that it would pop up and not required until 10K.
  30. Apr 25, 2020 at 1:32 PM
    #120
    So mostly highway miles, some city driving, no dust, and no towing.
    You sir, are the perfect candidate to change your oil at 10k. :thumbsup:
