10-13 4runner bumper option: retrofit LFD GX hybrid bumper.
Discussion in 'Armor' started by earth1, May 24, 2024.
  1. May 24, 2024 at 4:25 PM
    earth1
    earth1 [OP] New Member
    josh
    Fort Collins, CO
    13 Limited & 99/87 hybrid (1st gen body/3rd gen everything else
    86/01 4Runner conversion... 1st gen body/3rd gen everything else current mods: 3rd gen cluster SPC UCAs Downey coilovers OME 861 springs rear Poly bushings TJM front bumper homemade rear bumper/tire carrier 285/75/16 Duratracs on LX450 wheels
    Dear OG 5th gen owners, I'm stoked to share that I found a great, no mod, winch bumper retrofit for our red-headed stepchildren of the 5Gs... if you're lucky enough to find one. I bolted on a LFD hybrid front bumper for the 03-09 GX470. It is really close, I wouldn't say it's perfect like you'd expect from a mini bumper in the $800 range. I could probably use another 1/8 inch spacer still, and there's a little manufactured small cut line that shows. It could definitely be taller, the top line falls in the middle of the lower air dam. It's pretty damn good though. I don't even know what other low profile style GX bumpers were out there, but this could work for others, too. I'm sure this can be made to work on a Limited/ SE/ TE bumper- also, with the right depth of spacers. I had to use spacers for my rig, the GX bumper was 1/2 in too far in for the 4R profile- more below. The important part, is the width, all the post-facelift 5G bumpers are too wide and run into our turn signals. This bumper is as narrow as one can be and line up to frame horn mounts. Probably similar to the original CBI bumper in width I'd guess.
    I hadn't seen anyone who had tried, found one on Marketplace... stalked it to a price drop and bought it. I paid $350. The powder coat was just starting to fail. I was able to clean it up and do a decent 2k paint job and 2k satin clear on it. Took my time and dressed all the welds - I normally do that with metal anyway.
    My rig is a 13 Limited with the Canadian SR5 front bumper- it's the same as the 10-13 Trail Edition bumper, without the holes where the front bash guard garnish thing snaps on. Someone hit my rig while parked in front of my house. The truck probably would have been totaled in normal times, but this was when used car prices were high from covid. I had them it put back together with pre-facelift Trail Edition exterior trim. I didn't want just a hidden winch mount, front recovery points are crucial for me building a family hauler/ Costco queen/ light overland/ camping rig for Colorado, Wyoming, Utah type stuff.. After looking for a long time for a used hybrid type bumper, I was considering just buying a full price bumper, cutting some of the fascia width off, and having plate welded back in. Glad I tried this instead, best mod yet. Easy install, and I fit the Badlands 12k winch without moving the power steering line. The worst part honestly was trying to find a center point on the bumper and measuring accurately without any kind of template. My first test fit, I could tell it was going to work great. My first cut was spot on, but I had to temporarily use oversized large construction nuts as spacers between the frame horn and rear of the bumper to get the space right. A local metal shop sheared off (four) 1/4" plates, 4 1/2" x 5". I nipped off the frame horn connection from the discarded sub bumper to use as a template and drilled out 4 holes in my new 1/4 inch stock. Bolted it back up. I could already tell from the dry fit that I could easily install the bumper first, and put the winch on after- much easier than holding it all up together for a by yourself install. I think I covered the basics, not much else to say. Good luck finding a used bumper!
  2. May 24, 2024 at 4:27 PM
    earth1
    josh
    Fort Collins, CO
    I already asked this question in the 5G section, but I will probably get more views here. Does anyone know what the lower bolt size and pitches for the frame bumper- the horizontal bolt?
  3. May 24, 2024 at 4:28 PM
    earth1
    josh
    Fort Collins, CO
    Didn't have to cut much off. Also, kept the lower grill insert mesh thing in case I decide to take the winch out for any reason, even for seasonal storage.
    MeefZah and TrailSpecial22 like this.
  4. May 24, 2024 at 4:38 PM
    earth1
    josh
    Fort Collins, CO
    And - sorry, I'm not active on here and just realized there is a 5G specific armor section. Feel free to move this post if that's a better place.
  5. Dec 26, 2024 at 5:07 PM
    ForeverT4R72
    ForeverT4R72 New Member
    Jon
    2012 4Runner Trail
    Bone stock at the moment
    Great post! I just purchased a 2012 Trail a few weeks ago! How’s the bumper doing so far?
  6. Dec 27, 2024 at 8:29 AM
    ForeverT4R72
    Jon
    2012 4Runner Trail
    A few more questions:
    1. Did you have to adjust the mounting holes?
    2. Does it interfere with your skid plate?
  7. May 26, 2025 at 12:55 PM
    stecow
    stecow New Member
    Steve
    2011 4Runner SR5
    @earth1 I've been eyeing this sort of modification for my 2011 SR5 for a while and can't find a whole lot of info about it. Do you know how much this bumper weighs?
  8. Jul 5, 2025 at 5:17 PM
    I love your wheels
    I think your car pops up on Google when you search 3runner fj cruiser wheels
    Great mod!
