07 4.0 V6 VSC, Traction control, VSC TRAC and CEL lights are on
Discussion in '4th Gen 4Runners (2003-2009)' started by jacdun, Aug 2, 2022.
  1. Aug 2, 2022 at 6:28 AM
    jacdun
    jacdun [OP] New Member
    What throw all these lights? Thanks
  2. Aug 2, 2022 at 7:52 AM
    iamincrediboy
    iamincrediboy New Member
    South FL
    Code reader to the OBD II port? Any mods recently? gotta give us more to work with Teddy Brosevelt
  3. Aug 2, 2022 at 12:06 PM
    If your Check Engine light comes on, all the others come on too. TOYOTA (and other makers) turn off the traction control when there is an engine problem because it is considered more safe to do so. For example, if I have an evap leak, the engine computer will turn on all those lights. Even though the evap system has nothing to with the traction control and is not going to make the engine run badly.
    You need to read your OBD2 port and give us the codes.
  4. Aug 2, 2022 at 12:26 PM
    Curt56
    Curt56 New Member
    Curtis
    2021 TRD ORP
    Might want to check the battery too , my 08 did that and that was the cause.
  5. Aug 2, 2022 at 1:56 PM
    Any rodent-chewed wires in the engine compartment?
  6. Aug 9, 2022 at 12:24 PM
    Bluesky 07
    Bluesky 07 Not a New Member
    Russell
    Northern Georgia
    Check your gas cap too. Could be as simple as replacing it and clearing the code.
    RonT4R likes this.
  7. Sep 12, 2022 at 5:45 PM
    GPpete
    GPpete New Member
    pete
    2004 v8 4runner limited
    white
    just bought a 2004 limited 4runner and the vsc trac and vsc off lights come on when I drive. mechanic plugged in the code reader and no codes come up. any other suggestions? car seems to run just fine.
  8. Sep 12, 2022 at 7:23 PM
    TrueTexas
    TrueTexas New Member
    The Woodlands, TX
    There was an extended warranty program that replaced the brake light switch attached to the brake pedal for this exact condition. Had the same issue on my 06 and replacing the brake light switch solved the problem.
    Do the lights come on when you press the brake during your drive?
  9. Sep 13, 2022 at 7:45 AM
    GPpete
    GPpete New Member
    pete
    white
    The lights come on once I put the car into drive or reverse and stay on. I am bringing it back to the mechanic who looked it over before I bought and will suggest a new break light switch to see if that does the trick. thank you for the solution. fingers crossed.
  10. Sep 13, 2022 at 8:33 AM
    TrueTexas
    The Woodlands, TX
    Sure. It drove me nuts for months until I got the postcard from Toyota in the mail. The switch is super cheap. Would be worth trying to see if it resolves the issue.
