06 Sunroof problem
Discussion in '4th Gen 4Runners (2003-2009)' started by Bulldog90, Mar 17, 2024.
  1. Mar 17, 2024 at 5:56 PM
    Bulldog90
    Bulldog90 [OP] New Member
    Billy
    2006 4 Runner Sport Addition 4×4 Black
    The 06 4 Runner I have has a sunroof and it's not working the motor that was in there I thought was bad so I bought another one and it's still not working. When I hit the button it will drop some but not go down and back it's just making a machine gun sound when I push the button up or down. Can any one please help me with this problem and has any one had this problem before I hope it doesn't get more expensive to fix then just the motor. Thanks for the help and info.
  2. Mar 17, 2024 at 6:13 PM
    gkomo
    gkomo New Member
    San Diego, CA
    2004 4Runner Limited V8
    Pretty sure this is common and something with the rails/slides aren’t working properly. Not sure if you can adjust them… mine is broken too and most people recommend just not using your sunroof. lol not an ideal solution but I think it is kind of expensive to fix
  3. Mar 17, 2024 at 6:16 PM
    Bulldog90
    Billy
    Thank you for the help I have seen it cost from $ 900 to $ 1,000 dollars to fix but it's worth it it's worth having in a 4 Runner
  4. Apr 2, 2024 at 8:30 AM
    Ralph Blake
    Ralph Blake New Member
    2008 sr5 4runner
    What i have learned about sun roofs and power windows, try hard not to use them as both are costly to get fixed just the parts are out of reach for many.
    I have two with sun roofs and they remain closed.
  5. Apr 2, 2024 at 8:34 AM
    Bulldog90
    Billy
    Thank you for the info I'm going to try and get it fixed it the passenger side track that is stuck and won't retracted at all
  6. Apr 2, 2024 at 5:03 PM
    Bluesky 07
    Bluesky 07 Not a New Member
    Russell
    Northern Georgia
    Here's a TSB and the electrical schematic from the FSM in case they're helpful to anyone with a moon roof problem.
    BassAckwards and kmntq4 like this.
  7. Apr 2, 2024 at 5:05 PM
    Bulldog90
    Billy
    Thank you
  8. May 9, 2024 at 5:47 PM
    red-brian87
    red-brian87 New Member
    Brian
    Roanoke va
    2004 4runner limited v8
    I had a problem with mine not stopping and grinding you had to get it just right by hitting the button or it wouldn't close you had to grab it and help it get past the stuck spot. I cleaned and greased the top which looked like it had never been done. As well as disconnected the battery so it could relearn where the opened and closed spots where. This is after I started taking it all apart and took half the headliner off. May not help you but this is just some advice.
  9. May 11, 2024 at 6:28 AM
    4R777
    4R777 New Member
    This. I like to use it when driving slow in the mountains, but that's about it.
    They are stupidly expensive to fix. The motor alone is more than $500, and some of the parts are discontinued.
    Sunroof and roof parts diagram for 4th Gen 4Runner 2003-2009.
    https://toyota.oempartsonline.com/v-2009-toyota-4runner--limited--4-0l-v6-gas/body--sunroof
    https://parts.americantoyota.com/v-2009-toyota-4runner--sport--4-7l-v8-gas/body--roof-and-components
