05 Engine Replacement
Discussion in '4th Gen 4Runners (2003-2009)' started by RL94Tiger, Jun 20, 2017.
  1. Jun 20, 2017 at 6:49 PM
    RL94Tiger
    RL94Tiger [OP] New Member
    Russ
    2005 Silver 4Runner Sport
    needing to replace the engine in my sons 2005 Sport
    4.0L 6cyl
    What years are compatible?
    I know the online sellers say 05-11 but there is a question about the Variable timing being the same
    Any advice appreciated
  2. Jun 21, 2017 at 4:46 AM
    Toyotayoda
    Toyotayoda New Member
    Atlanta area
    1997 SR5 4x4, 302k and counting
    Tacoma whip, 99 console box, tru trac., steering wheel, PWMS and HVAC control out of a 99.
    After 2010 many of the 1GR engines got a secondary air injection system, other than that they stayed the same. The T4R and Tacoma share the same 1GR power plant, however the 1GR in the tundra is different, and not really compatible with the T4R.
  3. Jun 21, 2017 at 6:15 AM
    RL94Tiger
    Russ
    So you don't think there are any Variable timing changes from a 05-06 to a 07 or a 08?
    Thanks
  4. Jun 23, 2017 at 6:23 PM
    Toyotayoda
    Atlanta area
    I don't have TIS open in front of me at home, but no, the only change to the 1GR was in 2010 when the oil filter moved from the upper left of the timing cover to the lower left of the timing cover.
  5. Jun 25, 2017 at 12:26 PM
    wnelax04sr5
    wnelax04sr5 New Member
    Ethan
    CT
    2004 SR5 4X4 Galactic Gray
    IIRC i read about someone who did a motor swap and the computer needs to come with the motor youre bringing in, so you should aim for as close to your model year as possible. the one person who was doing it had like an 05 and tried like an 09 motor and had all sorts of trouble with the computers in the engine and trans communicating
