05 4 runner 191k purchasing today.
Discussion in '4th Gen 4Runners (2003-2009)' started by black7, Oct 10, 2018.
  1. Oct 10, 2018 at 12:35 PM
    black7
    black7 [OP] New Member
    Joe
    05 4runner sr5 4.0
    none
    I have been looking at all of the stuff online about headgaskets. This truck is $6800 with 191k miles. Should I risk buying it with all the gasket issues?
  2. Oct 11, 2018 at 9:27 AM
    RonT4R
    RonT4R New Member
    Ron
    Virginia Beach
    2007 4runner SR5 4WD
    my 2007 has 229k and I drive it everywhere.....
    scottalot likes this.
  3. Oct 11, 2018 at 7:16 PM
    ruiz4251
    George
    TEXAS
    16 Trail Premium
    hell yes. its head gasket no problem easy fix... better head gasket/s. if that's the only issue o'course. check other stuff on it. body lines or repair areas, under the hood check for wrinkles or miss aligned seams and body panels. leaks on engine and trans, dif.
  4. Oct 15, 2018 at 2:20 PM
    swimupstream
    swimupstream New Member
    05 SR5 4WD 4.0
    Did you buy it?! I blew mine at 165k, but that's b'c I tried to limp it off the highway in July after the neck on the radiator blew... limped a little further than I should have. $3k later, engine with 85k on it, and now I'm at 205k and going strong! My fault... head gasket isn't an issue, it just means if it goes bad, prob better plan on a new engine b'c not many people want to do it on an aluminum block.
  5. Oct 15, 2018 at 2:45 PM
    ruiz4251
    George
    TEXAS
    16 Trail Premium
    um, a head gasket is the seal between the engine block and valve head. your talking about cracking or breaking the block from over heating. that's what caused you to have to get a new engine. a simple head gasket wouldn't do that less it's been seeping oil into the spark well and left unfixed. that's whole other fix tho. 160k for a head gasket is about right. personally ive changed them in ather vehicles around 120k-187k.
    norcal1 likes this.
  6. Oct 15, 2018 at 3:40 PM
    swimupstream
    05 SR5 4WD 4.0
    I should clarify... Being that is a job beyond my scope, the cost was nearly the same on an aluminum block engine, and most discouraged it or didn't want to mess w it. Block was good... Was able to sell it off to offset my costs some.
    Thanks for helping!
    norcal1 likes this.
  7. Oct 15, 2018 at 4:08 PM
    ruiz4251
    George
    TEXAS
    16 Trail Premium
    head gasket and o-ring job is not that expensive. $700isk high end
    or 6-12pk a weekend and about $75
