03' 4Runner 4.7L...THROTTLE BODY SPACER
Discussion in '4th Gen 4Runners (2003-2009)' started by DIRTBIKEDAVE, Jan 26, 2019.
  1. Jan 26, 2019 at 7:04 AM
    DIRTBIKEDAVE
    DIRTBIKEDAVE [OP] 2nd 4Runner even better than the 1st one I had.
    Dave
    St. Louis, MO.
    My 2nd 03' 4th GEN. even better than the 1st. V8 SPORT
    VOLANT cold air intake, LED's inside, rear, and front. tinted window shades.
    I'd like to see if anyone has put on an airaid throttle body spacer for **the 03' 4.7L**?
    Airaid makes them for the 04 and up 4.7L but says not for the 03? It's exactly the same body and engine. they sent me a damaged one and will sent back for replacement.178510537_R_9ece0404-1ebe-4869-8223-6638444881d4.jpg
  2. Jan 28, 2019 at 7:07 AM
    blackoutt
    blackoutt New Member
    Southern IN
    2007 4Runner Limited V8
    Adventure Build
    Not sure why they wouldn't fit 03 as well if it's make for 4runner, but if it's just for any 4.7 like a tundra or LC there could be different clearances and some variables in throttle body coolant lines and such. Try it. Also not sure they do much other than whistle but would be interested to hear your review.
  3. Feb 23, 2019 at 5:05 PM
    DIRTBIKEDAVE
    Dave
    St. Louis, MO.
    Well, finally got a warm enough day to install. I have a Volant cold air intake system, not working around the hem unit. The intake tube is about 1/2" from fan blades and over flow bottle. But, when installed, thought it was put on backwards from left to right screw (flow of air) it only went on one way and I didn't hear any whistle, but DEFINITELY increased the acceleration low to mid range. I didn't get that with the V6 and airaid with K&N.
  4. Feb 23, 2019 at 9:35 PM
    2016Pro
    Waste of money, snake oil
    BestGen likes this.
  5. Feb 24, 2019 at 1:14 AM
    BestGen
    BestGen Member #57
    Paul
    Haunted Turnbull Canyon, CA
    Exactly. Right behind the "cold" air intake for biggest rip off. :der: You're only mashing the throttle harder! :laughing:
    2016Pro[QUOTED] likes this.
