Do snorkels help with MPG? Do they serve as pseudo cold air intakes?
Discussion in '5th Gen 4Runners (2010-2024)' started by LT Smash, Apr 24, 2024.
  1. Apr 24, 2024 at 6:11 AM
    LT Smash
    LT Smash [OP] New Member
    2023 4Runner
    To be honest, I can’t stand the look of them but do snorkels help with performance in any way? Or are they strictly for water crossings?
  2. Apr 24, 2024 at 6:22 AM
    Snorkels are meant to reduce dust inhalation with the side effect of keeping water out too. They do nothing for power or MPGs. Intakes in general do nothing.
  3. Apr 24, 2024 at 6:30 AM
    jdm-v35
    jdm-v35 New Member
    CO
    2018 4runner TRDORP
    Magnuson Supercharger etc.
    As previously mentioned, they are mainly for dust. They usually have drain holes, and the stock airbox has drain holes so their help water crossing is limited as well. If anything you may lose MPG because adding that non-smooth pipe introduces more restrictions to the intake system.
  4. Apr 24, 2024 at 6:45 AM
    ColoradoTJ
    ColoradoTJ I drink...and I know things. Staff Member
    Chris
  5. Apr 24, 2024 at 7:00 AM
    Hey OP, don't let these haters dissuade you from getting a snorkel. You'll easily get another 10MPG from your 4Runner if you slap one of those bad boys onto your truck. Rumor has it, you gain 18HP too.
    When you get one, make sure you put a cap on it like this one. So it looks like you're driving around with a big plastic black dick strapped to the side of your truck.
  6. Apr 24, 2024 at 7:28 AM
    kmeeg LionRunner
    I really would like to have a high air intake for cleaner air. The closest low profile one I see is TJM. I don't like other bulky ones. But the air seems to be taken right in front of the windshield where water and snow is splashed at.
    Rust is a concern too with cutting at the quarter panel and rivets at the a pillar.
  7. Apr 24, 2024 at 7:47 AM
    Grandpawmoses
    Grandpawmoses New Member
    David
    2024 4R TRD Pro
    Too poor to buy anything now
    I want one that's so tall that I have to plan my route to avoid low overpasses.
  8. Apr 24, 2024 at 9:37 AM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited 4WD
    If you're gonna have a dick strapped to your truck, you should add the balls too. Fuckin' Raptor lights man!
    Borracho Loco[QUOTED] likes this.
  9. Apr 24, 2024 at 10:12 AM
    Magiriano
    Magiriano New Member
    Alex M.
    2022 TRD PRO
    If it doesn't say Safari on it tho, it only adds 10HP.
    Go big or go home.
  10. Apr 24, 2024 at 10:30 AM
    Rocko9999
    Rocko9999 New Member
    2011 Limited
    Things that do not improve measurable MPG-Snorkels, Filters, Pedal Commander, Aftermarket Spark Plugs, Ambient Air Intakes, Etc.
    Things that do save gas-not driving your 4Runner.
    Magiriano and chuckem12 like this.
  11. Apr 24, 2024 at 10:39 AM
    Acesandeights
    Acesandeights Newbie - always learning
    So Oregon
    1938 4Runner
    They have the potential to add cooler, cleaner, air; however, that change won't impact your power or mileage on a 4Runner.
    Magiriano likes this.
  12. Apr 24, 2024 at 10:48 AM
    Manhattan
    Manhattan New Member
    Not being a **** but help me understand ^those^ points. I've had lots of 4wds, but never a snorkel.
    1. Cooler air; Doesn't the 4Runner's OE intake/airbox get cool (vs heated by the engine) air already?
    2. Cleaner. I'm assuming this applies only to traveling behind one or more trucks - that would be kicking up dust... right?
    FWIW, #2 is pretty common - following trucks on gravel/dirt roads. I've slowed or stopped long enough to let the cloud settle or drift. So yeah, if you can't see through it, the truck is breathing (well, the filters are breathing it).
  13. Apr 24, 2024 at 10:58 AM
    Acesandeights
    So Oregon
    1938 4Runner
    @Manhattan
    1. because your 4Runner gets cool air already.
    2. yes, #2 is pretty common, but if you're running an air filter, and choose to slow or follow with slightly more space (as you've done in the past), it's not an issue
    You're not being a ****. You're agreeing with, giving examples of, the points I made above.
  14. Apr 24, 2024 at 11:42 AM
    Trekker
    Trekker Regular Member
    1997 3rz 5spd
    It depends on the snorkel, if it is well designed and the engine gets better flow and/or colder air it will decrease milage because higher air pressure or denser air will allow the EFI to inject more fuel. But we're talking fractions of an mpg, the stock location is already optimal for getting cold air so there isn't much room for improvement.
    Snorkels are for keeping the air intake above water when driving through water. Snorkels and cold air intakes (the CAI that look like a snorkel) are also there for better filtering in dusty environment, since the stock location isn't the best for dusty. If you're trying to improve MPG, moving the intake is not an effective method.
  15. Apr 24, 2024 at 12:25 PM
    3JOH22A Toyota Gigolo
    Poorly designed snorkel can restrict airflow and hurt performance. Otherwise they're mostly for water crossings. If you're bombing through the desert frequently, an elevated snorkel will reduce the amount of dust getting into the airbox, extending your air filter life. That why minivans have snorkels in the Middle East:
  16. Apr 24, 2024 at 12:32 PM
    PointmanUSMC
    PointmanUSMC New Member
    Illinois
    2023 Black TRD ORP 4 Runner Bronze Rims
    Can anyone share some videos on a 4R with a snorkel doing some actual deep water river crossings without being heavily modified? I am curious how water tight the wiring harness fuse blocks etc under the hood could actually withstand water coming to the top of the block? Or are the snorkels all for show and no go?
  17. Apr 24, 2024 at 12:38 PM
    jdm-v35
    jdm-v35 New Member
    CO
    2018 4runner TRDORP
    I think the snorkels can help for quick water crossing or preventing splashing water from getting into the airbox since the inlet is right in the fender, but I wouldn't go that deep. The OEM airbox has drain holes in the bottom to let water out so they can also let water in if youre that deep. The door seals and possibly rear lower vents would also probably slowly leak water in.
    Acesandeights likes this.
  18. Apr 24, 2024 at 12:43 PM
    Acesandeights
    So Oregon
    1938 4Runner
    Your electrical needs to be water resistant, but snorkels don't make submarines. When you enter the water your fan and belts will throw water everywhere. The snorkel helps for that, not actually to keep the engine running with water over the engine.
  19. Apr 24, 2024 at 12:44 PM
    Door seals would be you first issue. What is boils down to is buy a boat for water because a snorkel is just one of many many things needed to get into deep water. Toyota doesn't want you to go over the hubs.
  20. Apr 24, 2024 at 12:47 PM
    PointmanUSMC
    Illinois
    So if I get what your saying. Your saying that NO deep water crossing can't or shouldn't be recommended for a 4 Runner? Without expecting electrical issues from submersion. Hence the argument for a snorkel gets thrown out? Unless you wanted the coolness factor and clean air?
    :facepalm:
    jdm-v35[QUOTED] likes this.
  21. Apr 24, 2024 at 12:50 PM
    jdm-v35
    jdm-v35 New Member
    CO
    2018 4runner TRDORP
    Pretty much, the snorkel has its purpose and capabilities, but as others say it doesn't make a submarine. It would prevent water up to the hub level from splashing into the airbox inlet that's in the fender and it also helps reduce dust ingestion into the intake if you are in dusty areas. I have considered one but purely for dusty environments and following others in dusty places.
    The problem is people are associating "snorkel" with water/swimming. but in this case all it does is raise the level of the intake to mostly prevent dust from getting in. Preventing splashing in the fender is more of a side benefit, but there are many more pieces to deep water crossings.
  22. Apr 24, 2024 at 12:56 PM
    PointmanUSMC
    Illinois
    SOOOOoooo to answer OP questions water crossing out... Cross that off your list. Coolness and clean air in. So no need to cut a hole in your fender. Take it slow so water doesn't splash into intake. Save your money.
    :crazy::cheers:
  23. Apr 24, 2024 at 12:58 PM
    jdm-v35
    jdm-v35 New Member
    CO
    2018 4runner TRDORP
    I think this thread got way off track. They wanted a snorkel to gain MPG lol.
    whippersnapper02 likes this.
  24. Apr 24, 2024 at 1:00 PM
    The under-hood components can withstand submersion, but you may get corrosion and electrical gremlins long-term. The snorkel is there to prevent catastrophic engine failure (bent/broken connecting rods) from hydrolocking.
  25. Apr 24, 2024 at 1:04 PM
    PointmanUSMC
    Illinois
    Yes I know about submerged blocks and hydrolock. Thank you. I was playing dumb to see if there could be some reasonable argument that water crossing a 4 runner was worth while. I figured as much. :crapstorm:
  26. Apr 24, 2024 at 1:12 PM
  27. Apr 24, 2024 at 1:22 PM
    It's the difference between suffering long term effects and being stranded on the trail. It often isn't obvious how deep a water crossing is, and often isn't practical to check with a stick on foot. Short of going in with chest waders, the snorkel just provides additional insurance.
    I don't have a snorkel on my Tacoma, so I always wheel in a group, and follow someone with a snorkel through unknown water crossings.
    Photon_Chaser likes this.
  28. Apr 24, 2024 at 1:28 PM
    PointmanUSMC
    Illinois
    Yes and how swiftly the water is moving can also rush the water in places you hadn't intended. I think some have the misconception that a snorkel means cool deep water crossing when that's not usually the case. There are other factors of what can stall your truck out and to include electrical failures.
  29. Apr 24, 2024 at 1:39 PM
    Photon_Chaser 42465 and counting…
    NorCal Coast, CA
    21 TRD Pro
  30. Apr 24, 2024 at 1:45 PM
    PointmanUSMC
    Illinois
    Now that's what I wanted to see thank you ! Cool to see a 4R do it. Would be nice to see more than 14 seconds of video to see if he continued on up the trail as if nothing had been there or if it stalled shortly after. I like how the video fades out right after he crosses. Does he stall? haha Some creative video editing. Also to know the back story of the rig. Was the electrical modified in any way or was everything fairly water tight from the factory? Thanks for sharing.
