Yellow Caution Stickers On Rear Door Openings
Discussion in '5th Gen 4Runners (2010-2024)' started by Nick B, Jun 6, 2024.
  1. Jun 6, 2024 at 9:26 AM
    Nick B
    Nick B [OP] New Member
    SW Florida
    2010 TE, 2024 ORP
    My newly purchased 24 OR Premium has these ugly yellow caution stickers on the rear door openings . Has anyone had any luck on easily removing these ? I picked at a corner of one and it seems like they’re stuck good . Maybe a hair dryer ?
    Apparently Toyota didn’t want these ugly stickers to be easy to remove .
    Thanks in advance.
  2. Jun 6, 2024 at 9:31 AM
    You can try goo gone but they don't bother me so I just left them in place.
    JChiz likes this.
  3. Jun 6, 2024 at 9:37 AM
    more4than2
    more4than2 New Member
    2012 4runner trail dark charcoal
    none yet
    I have not tried to remove them, as my 5th gen does not have them.
    For 'bumper stickers", labels on glass jars, I spray them with a spray and wash type of solution. I have not used the solution on painted surfaces, so beware.
    I spray it on, go away, each time I pass by I spray the sticky label. It breaks the glue base down and the plastic labels comes off fairly easily.
  4. Jun 6, 2024 at 2:28 PM
    Gen-V
    Gen-V "Every Day I Try to Be The Man My Dog Thinks I am.
    Palm Bay, Florida
    2024 TRD Off Road Premium
    Nothing yet.
    Just removed those an hour ago. Got a fingernail under one corner, peeled back 1/4 inch then used rubbing alcohol on a paper towel to loosen enough to peel off in one piece. Used the paper towel to remove glue remnants.
    We used the stickers and paper towels in our barbie to start the charcoal....... Made RIBS, yum.
    And Yes the stickers are tuff and obnoxious...!
    Nick B[OP] likes this.
  5. Jun 6, 2024 at 3:16 PM
    Rick G.
    The Texas Hill Country
    2022 SR5 Premium 4WD
    I don't have that on my 2022. I'm curious. Can someone post a pic of these caution stickers if you get a chance? Thanks.
    java likes this.
  6. Jun 6, 2024 at 3:59 PM
    May be wrong but I think any port installed options would get the yellow sticker. I saw a thread the other day referencing one with a different weight rating change by an added accessory. That poster may see this and pop that pic back up.
    2Toys likes this.
  7. Jun 6, 2024 at 4:44 PM
    T in Texas
    T in Texas New Member
    FEMA Region 6
    2024 Terra TRD Pro Terra - finally got it
    I just checked mine,
    and its there, at least on the driver's side,
    warning about after adjusting the seatback, make sure its in the locked position by pulling on it
  8. Jun 6, 2024 at 4:51 PM
    This is what it looks like on my 2023:
  9. Jun 6, 2024 at 5:05 PM
    Nick B
    SW Florida
    2010 TE, 2024 ORP
    Thanks for the reply . I’m gonna tackle mine tomorrow.
  10. Jun 7, 2024 at 8:39 AM
    Nick B
    SW Florida
    2010 TE, 2024 ORP
    With a little patience I got both stickers to come off in one piece with very little glue residue.
    Cleaned the residue off and then waxed the area . Looks perfect. Thanks to all who took the time to reply.
    photo8 likes this.
  11. Jun 7, 2024 at 8:41 AM
    Startrek
    Startrek New Member
    goo gone damage paint
  12. Jun 7, 2024 at 8:47 AM
    I tested some on my peeling PPF without issues. I was going to use it to remove leftover adhesive residue when I remove it entirely.
  13. Jun 7, 2024 at 8:51 AM
    CalcityRenegade
    CalcityRenegade New Member
    Matt
    2023 T4R ORP KDSS
    Heat gun to warm it and remove it, eraser wheel to remove any residue.
    1SilverRunner and backpacker like this.
  14. Jun 7, 2024 at 12:53 PM
    Lost Woods
    Lost Woods New Member
    Goo Gone shouldn't as it's just citrus oil but Goof Off is a solvent that absolutely will. Goo Gone will have the same effect as strip wash so if you use it on the exterior you'll need to wash well with something that cuts oil and reapply wax or ceramic after.
  15. Jun 21, 2024 at 11:55 AM
    JChiz
    JChiz Old Member
    South Of Tucson, AZ
    I removed my passenger side sticker and it left plenty of glue because I was in a rush and did NOT use my heat gun. Several days later I very carefully tried removing the glue with nail polish remover (no luck), rubbing alcohol (no luck) and then Goo Gone with perfect results. Using a cotton rag helped pick-up the loosened glue. Still a PITA to get it all off but that worked with no harm at all to the paint. Thanks WhipperSnapper for the suggestion. Now I will try removing the sticker on the driver's side (after I heat it a little) knowing I can get the rest of the glue off without harming the finish.
  16. Jun 21, 2024 at 12:26 PM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    I have a little extra time today. I may go peel these off along with the dealership logos hidden in the door jams...
    Heat gun then eraser wheel should make quick work of these.
  17. Jun 21, 2024 at 12:57 PM
    Nick B
    SW Florida
    2010 TE, 2024 ORP
    I picked at the edge real carefully until the edge was up enough to grab and then real slow I pulled it off in one piece with very little glue left behind .
  18. Jun 21, 2024 at 1:10 PM
    It is unlawful to remove warning placards from a vehicle, plus it decreases the value. Proceed with caution.
  19. Jun 21, 2024 at 3:20 PM
    Lost Woods
    Unless I'm mistaken, it's the same as mattress tags and that only applies to manufacturers and resellers. The only things the end purchaser cannot remove without cause are the VIN plate and under-hood emissions sticker.
    Either way I have never in my life seen a vehicle devalued for removing stickers or badges.
  20. Jun 21, 2024 at 3:27 PM
    I was being funny. ;)
  21. Jun 21, 2024 at 3:34 PM
    Ripper238
    Ripper238 New Member
    2019 TRD OR
    If that is removed you will void your warranty and if you vehicle gets inspected without those you will be arrested. :evil:
  22. Jun 21, 2024 at 3:41 PM
    Lost Woods
    can never tell these days haha... I've seen some stupid things posted around here.
  23. Jun 21, 2024 at 4:29 PM
    Bro, you live in Texas. No need for a heat gun. Just wait until Thursday. It'll be over 100 degrees! If you leave it in the garage it'll be even hotter. The label may slide off on its own.
    Slopemaster and JChiz like this.
  24. Jun 21, 2024 at 5:15 PM
    1SilverRunner
    Tejas
    :laugh:
    Slopemaster and 2Toys like this.
  25. Jun 21, 2024 at 6:51 PM
    I agree
