Worried about transmission temps
Discussion in '5th Gen 4Runners (2010-2024)' started by ecoterragaia, Jun 12, 2022.
  1. Jun 12, 2022 at 2:19 PM
    ecoterragaia
    ecoterragaia [OP] New Member
    Central Virginia
    2021 SR5 4WD
    My wife and I hauled our dinky 16' aluminum fishing boat 135 miles to a mountain lake in western VA this weekend (and back). We have a '21 SR5 with 4,100 miles. Boat and trailer weigh ~1,200-1,300 lbs. loaded.
    I babied it the whole way out, shifting between S4 & S5 when conditions required/allowed, and managed to get just over 19 mpg each way. On the very last leg of the journey to our cabin on Thursday we scaled a mountain. Measuring on Google Earth, we went from 1622 ft to 2931 ft over 4.12 miles. It was in 3rd gear almost the whole way up (except it shifted to 2nd once), and due to me going ~40 mph, I'd gathered 3 vehicles behind me. I pulled over at an overlook at the top to let them pass, and when stopped, I smelled that stinky chemical burning odor like when we first bought the vehicle and were breaking it in. It was strong, and my wife was worried that "something broke".
    I didn't notice any slipping or any transmission issues for the rest of the trip, or the drive back home. I'm inclined to believe it was just residual burnoff since it's still somewhat newer, but it's hard not to think that something got really, really hot and needs to be addressed. I might go ahead and start the gradual transmission fluid replacement process early.
    What do you guys think, waste of money or prudent?
    Obligatory lake pics :)
    4runGirl88 likes this.
  2. Jun 12, 2022 at 2:35 PM
    Ya you might want to switch up gas stations.
    kolter45 likes this.
  3. Jun 12, 2022 at 2:42 PM
    universalfrost
    universalfrost New Member
    Joseph
    Belpre, Ohio
    Predator bars, blackout emblems, TRD Pro Wheels, Falken AT3W tires
    I just pulled a boat twice the weight from Wisconsin to southeastern Ohio 667 miles and didn’t notice any issues and had darn good mpg.. my yota has about 9k and still has that same new car odor of burning off manufacturing greases etc when driving and that’s after I scrubbed down the under carriage personally because I was worried that it was something leaking.. must be a new yota thing..
    4runGirl88 and ecoterragaia[OP] like this.
  4. Jun 12, 2022 at 4:01 PM
    08TXRunner
    08TXRunner New Member
    '20 SR5P
    So what were the temps that you're worried about?
  5. Jun 12, 2022 at 4:11 PM
    ecoterragaia
    Central Virginia
    2021 SR5 4WD
    I didn't have trans temps, but just ordered a Scangauge II for future trips.
    My worry was that the strong odors produced on its first trip hauling any weight up steeper inclines might be indicative of an issue. But if it's just regular 'ol burnoff I won't worry about changing the trans fluid over the next 5,000 miles.
  6. Jun 12, 2022 at 4:52 PM
    lrizzo
    lrizzo New Member
    Northern New Jersey
    I have a 2021 with about 14,000 miles and it still smells like something is burning if I’m pulling weight or driving it hard. I think it’s normal.
  7. Jun 12, 2022 at 4:56 PM
    I’m not positive but I think there’s a transmission temp warning light. If that didn’t come on, then your probably ok.
    ecoterragaia[OP] likes this.
  8. Jun 12, 2022 at 5:08 PM
    wsu_runner
    wsu_runner Just lurking...
    I'd be really, really surprised if you overheated your transmission towing a load that small.
  9. Jun 12, 2022 at 6:13 PM
    ARB1977
    ARB1977 It’s a beaut Clark
    Anthony
    If that temp light come on you’ve already cooked the fluid. I believe the Tacoma is set at 300 degrees which is too hot. Get a device that can read the temps. If it’s too high get a bigger cooler.
    Jojotoo likes this.
  10. Jun 12, 2022 at 6:19 PM
    muddyix
    muddyix New Member
    AZ & TN
    '22 AG ORP
    That is one beautiful lake!
  11. Jun 12, 2022 at 7:00 PM
    ecoterragaia
    Central Virginia
    2021 SR5 4WD
    I had no idea that there was a a trans. temp. light. It didn't illuminate so I think it's all good. Thank you!
  12. Jun 12, 2022 at 7:36 PM
    Another reason I think you hit a wall, the EGR may have been working over time to cool the combustion chambers.
  13. Jun 12, 2022 at 7:44 PM
    Check the owners manual because I’m not positive about that.
    My 12’ Sequoia actually has a trans temp gauge on the instrument cluster. We never tow so I have never experienced an elevated transmission temperature situation.
  14. Jun 12, 2022 at 8:13 PM
    GrantA
    North Carolina
    Fully locked 2020 SR5 Premium
    Did a quick Google search and apparently a transmission warning light is a thing. However, reading online if one does get a high transmission temp then a drain and fill is needed asap as the efficiency of the transmission fluid is diminished a large amount. Again this was on another forum and I am surely no expert. But if you got no light you more than likely didn’t heat up the transmission enough to cause an issue (but again I am no expert in the field). Do what you feel is best.
  15. Jun 13, 2022 at 7:15 PM
    DIRTRCR13
    DIRTRCR13 New Member
    Jerm
    The 405
    '16 Sierra Romeo Cinco
    At 5,000 miles, your Runner isnt even broke in yet... If you feel like checking, pull the check plug on the tranny pan and take a sample of fluid when the vehicle is at normal operating temp ( you can drive it around for 10-15 minutes easily to accomplish this). If its brown to black in color, get it flushed. if its blood red to brown, a simple drain and fill may be all you need. If its bright red, you are fine. But I doubt you did any damage. If you feel the need to add some additional cooling and a little more capacity ( 1/2-3/4 qt), get an air cooler, run it off of the return line of the radiator cooler and put it in front of the a/c condenser where it will get good air flow. But I think you are ok...
    Were you out by Roanoke or further west?
  16. Jun 13, 2022 at 7:17 PM
    If the AT overtemp warning didn't pop up, you're fine.
  17. Jun 14, 2022 at 5:21 AM
    ecoterragaia
    Central Virginia
    2021 SR5 4WD
    Thank you for the excellent advice, much appreciated. This is the heaviest thing I plan to haul with the 4R for a while, so might hold off on considering a trans cooler for now. Yours and others' replies makes me feel like it's not a big deal.
    We were actually north of Roanoke on Lake Moomaw, and stayed in Warm Springs. Beautiful area, lots of rural mountain countryside.
    DIRTRCR13[QUOTED] likes this.
  18. Jun 14, 2022 at 6:14 AM
    PJSnow
    PJSnow New Member
    PJ
    New York
    2018 Cavalry Blue TRD Pro
    I recently installed heat wrap around the transmission lines that run next to the cats. I got the idea from RC Fabrication on Instagram. This is not a replacement for a transmission cooler but I'm sure it will help keep the temperature in check on the very hot days. Here are a few photos:
    GrantA and ecoterragaia[OP] like this.
  19. Jun 14, 2022 at 8:08 AM
    TrailGuy2016
    TrailGuy2016 New Member
    2016 Trail Premium, Silver
    There is, and that was going to be my question.
  20. Jun 14, 2022 at 8:19 AM
    Yoytota
    Yoytota New Member
    FL
    SR5 4X4
    Last time I experienced that was on a new tundra that had a loose sensor that was misting oil in the engine bay. You could smell it but it wasn't smoking or anything
  21. Jun 14, 2022 at 8:21 AM
    Yoytota
    Yoytota New Member
    FL
    SR5 4X4
    Toyota came and hauled it off to the dealership tighten the sensor topped it off with oil and said it was good to go
  22. Jun 14, 2022 at 8:48 AM
    ARB1977
    Anthony
    Well damn I’ll have to look at my Tacoma’s cooler lines.
  23. Jun 14, 2022 at 9:46 AM
    Just do this. I will at some point:
