Wiring a DC to DC 20 Amp charger for a small travel trailer.
Discussion in '5th Gen 4Runners (2010-2024)' started by OtisSkye, Jul 9, 2023.
  1. Jul 9, 2023 at 4:31 PM
    OtisSkye
    OtisSkye [OP] New Member
    2018 4Runner
    I’d like to wire a DC to DC charger adjacent to the battery box on my small travel trailer. The wiring is pretty straightforward. Positive and negative 8 gauge wires running from the vehicle’s battery to an Anderson outlet at the rear bumper. My question is about the “ignition” wire that would run from the under hood fuse box to the outlet at the bumper. The purpose is to prevent charging the auxiliary battery if the vehicle isn’t running. They sell a fuse with a pigtail that would go in an empty fuse slot in the fuse box. I’m not sure what Amp fuse I should use and what’s an appropriate empty slot that wouldn’t be energized unless the vehicle is running? Any suggestions would really be appreciated.
    Thanks
  2. Jul 9, 2023 at 8:37 PM
    UncleShorty
    UncleShorty New Member
    I'm about to put an auxiliary 12 V power outlet on my passenger side. I want it to be powered when the key is "ON", only. I'm going to run my power feeder from the battery, through an SAE disconnect and fuse to a 20 amp rated relay. I'll use an Add-A-Fuse from circuit 13, the seat heater feed, to energize the relay coil when the key is on.
    A similar set up would work for you. The relay coil takes very little current. Just fuse it for the wire size between the added fuse and the coil.
  3. Jul 9, 2023 at 9:27 PM
    Cowboy59
    Cowboy59 Enjoy the Adventure
    N. Florida
  4. Jul 10, 2023 at 6:28 AM
    UncleShorty
    $1265 vs $50?
