Wires were detached from transmission connector
Discussion in '4th Gen 4Runners (2003-2009)' started by MannyAlz, Jul 8, 2021.
  1. Jul 8, 2021 at 5:15 AM
    MannyAlz
    MannyAlz [OP] New Member
    Manny
    4 Runner 2004 4.7 V8
    JTEBT17R040044768
    Some wires were detached from the connector. External harness to transmission. Need to get the correct colored wires.
    2004 4 runner 4.7 V8
  2. Jul 8, 2021 at 8:21 AM
    iamincrediboy
    iamincrediboy New Member
    South FL
    Cant even find a wiring diagram but to start you off its aptly called the "transmission wire", from what your pic looks like. You can try rummaging around a FSM in the A750F automatic transmission system area for the 2UZ engine. Otherwise only things to try to help is post #228 here https://www.tacomaworld.com/threads...-for-second-gen-4-liter-trucks.289913/page-12
    Or run through every DTC failure here to see which pinout might apply https://fjcruiserhub.com/docs/A750F-Automatic-Transmission-System.pdf
    Or very last last ditch effort is find a Toyota Master Tech.
    Bob likes this.
  3. Oct 5, 2021 at 7:25 PM
    T4Rbro
    T4Rbro New Member
    Matt
    2005 v8 4x4
    Stage 3 Icon suspension, toytec front, bilstein 5100 rear, FJ rear springs (air delete. Xreas delete), mild lift and level, steel winch bumper front full 3/8" steel skids beneath. Few other things coming.
    Hey man, dealing with a similar situation with mine but the wires are there they just bypassed the connector, drilled through the internal harness sealed plug and pulled wires then crimped them into the main harness. Found it whilst chasing fluid leaks... Wonder why it's leaking from above the pan seal.... Grrr
    Anyhow, did you dig up any wiring schematic resources? Colour codes for the internal harness to main harness? Anything useful?
    I can't even express my rage at this level of stupid ass-hattery!
  4. Oct 5, 2021 at 9:01 PM
    2003 or 2006 the same?
  5. Oct 6, 2021 at 9:32 AM
    iamincrediboy
    South FL
    Those manuals should just about be the same, though pretty sure Toyota changed just a few wire colors between the years. The pinouts should definitely be the same though. But between the FSM and the Haynes manual for the 4th gens you should be covered.
