Wiper Blades for Snow/Ice?
Discussion in '5th Gen 4Runners (2010-2024)' started by Rocko9999, Nov 3, 2023.
  1. Nov 3, 2023 at 8:45 AM
    Rocko9999
    Rocko9999 [OP] New Member
    2011 Limited
    Anyone have a good rec for wiper blades that do well specifically in snow/ice?
  2. Nov 3, 2023 at 8:56 AM
    CalcityRenegade
    CalcityRenegade New Member
    Matt
    2023 T4R ORP KDSS
    Following out of curiosity. I tried the Toyota winter blades on my Tacoma and noticed no difference in performance.
  3. Nov 3, 2023 at 9:10 AM
    I bought Scrubbable wipers but haven't tried them and also there's no snow in my area.
  4. Nov 3, 2023 at 12:05 PM
    Rocko9999
    2011 Limited
    Did they do poorly in snow/ice?
  5. Nov 3, 2023 at 1:13 PM
    CalcityRenegade
    Matt
    2023 T4R ORP KDSS
    I don't like to say poorly, but no better than the original wiper blades. My 4Runner is better though thanks to the heated windshield element where the wiper blades sit.
  6. Nov 3, 2023 at 2:02 PM
    steelevo
    Utah
    I just use the OEM inserts. I let the winter destroy them, then put a fresh set in when spring comes around.
    Just make sure that you're using a good winter windshield washer fluid. This will make the most difference. Also, keep using the winter formula in the warmer months. This will reduce the chance of dilution of the winter formula when you need it.
    LuLu and Rocko9999[OP] like this.
  7. Nov 6, 2023 at 8:01 AM
    Rocko9999
    2011 Limited
    Thanks. What fluid do you like?
  8. Nov 6, 2023 at 8:35 AM
    backpacker
    backpacker New Member
    2023 TRD ORP
    On other vehicles, I've done well with old-school ANCO winter blades, the kind with all the springs encased in flexible rubber.
    The specific problem they address for me is driving for a long duration in snowstorms where enough snow and ice accumulates in the springs to impair their range of motion, causing a portion of the blade to lift away from the windshield. I've tried beam-style winter blades, too, and they generally work pretty well, but just a tiny bit of ice between the segments can cause the same thing. It's not as easy for that bit of ice to form, but it does happen eventually in the right conditions.
    ualfltdispatch and Rocko9999[OP] like this.
  9. Nov 6, 2023 at 8:36 AM
    Same story for me. In the past I have used RainX Hybrid (forgot the exact name), Bosch Icon, Bosch Envision. To me the OEM rubber inserts works best.
    It was pretty easy to replace and I purchased from the dealership parts store. I don't know how to order online. I just asked the parts store for 2021 4Runner wiper rubber inserts.
    https://youtu.be/dddH41a482U
  10. Nov 6, 2023 at 10:05 AM
    Bosch Icon is slightly better and vastly more expensive. I run them on all my vehicles because they look cool :cookiemonster:
  11. Nov 6, 2023 at 3:28 PM
    steelevo
    Utah
    I just use the cheap Walmart Supertech winter blend. You can usually tell by the color if it's good or not. The darker blue it is, the more winterized it will be. Pass on light blue.
    Rocko9999[QUOTED][OP] likes this.
  12. Nov 6, 2023 at 3:40 PM
    Nevin
    Nevin New Member
    Puyallup, WA.
    2022 TRD ORP
    PPF, Tint, Black out badges/Valances. Bilstein 6112's & 5100's
    Why the heck is this guy using his hood as a work bench. I cringe through the whole video.
  13. Nov 6, 2023 at 6:52 PM
    Old goat
    Old goat Trout chaser
    Hudson Valley NY
    5th gen
    Rocko9999[OP] likes this.
  14. Nov 6, 2023 at 8:36 PM
    That can get pricey.
  15. Nov 6, 2023 at 10:22 PM
    Trekker
    Trekker Regular Member
    1997 3rz 5spd
    Get wipers that use silicone blades. I have the PIAA super silicone, but there are other well rated ones too. The silicone ones cost more, but they last so much longer you'll get back that money. I've been using mine for 3 years in Washington where it rains and ices, spent a summer in NJ (more rain), and they still don't streak.
    The silicone also aids in beading water, when driving back from NJ my passenger remarked that water beaded really well on my windshield. I didn't even have to use the wipers! They also never squeak like rubber blades.
    The beam style seems to be less prone to freezing stiff then the old style. Mine are the old style blades, I've only had them freeze stiff once because I parked outside, and they thawed during the drive from engine heat. I find they wont freeze stiff if you leave them up when parked outside, a habit you should do already for other reasons too. A bottle of deicer is good if you do have issues with ice freezing them solid.
    If you live in a place where you get snow/ice, you need a good ice scraper. No windshield wiper will survive long if you run them over a bunch of rough ice, you have to give it a smooth surface. Only if the icing is very light (so light that it makes the glass look matte without being rough) is it okay to use a deicer only. I use RainX, but any winter rated fluid will do. The deicing is a side affect of the fluid being meant not to freeze in your reservoir.
    I don't think Vodka would do your paint finish a favor, but it will work.
  16. Nov 7, 2023 at 6:16 AM
    Cheap vodka?
    Tank010[QUOTED] likes this.
  17. Nov 7, 2023 at 7:53 AM
    Rocko9999
    2011 Limited
    My brother swears by spray bottle with half rubbing alc. half water for de-icing locks, windshield, etc.
  18. Nov 7, 2023 at 8:23 AM
    backpacker
    2023 TRD ORP
    Those are the beam-style winter blades I've used the most. They're not totally immune to ice problems as noted in my post above, but they're usually quite effective.
  19. Nov 7, 2023 at 9:17 AM
    Well69
    Well69 New Member
    2022 Limited 4Runner
    I use kimblades they are pricey, but they're silicone and they have a different shape that most blades. I wish they made one in a size that fit the rear wiper
  20. Nov 7, 2023 at 10:01 AM
    joshdub
    joshdub New Member
    2020 TRD ORP
    Aside from the alcohol stripping any protectant off the paint, a jug of washer fluid is a at most $5. That's an awful lot of work and finish damage to save a couple bucks
    307WY likes this.
  21. Nov 7, 2023 at 10:23 AM
    joshdub
    joshdub New Member
    2020 TRD ORP
    Vodka is a solvent. While the ethanol may be relatively diluted by the time you're mixing it with water it will still breakdown any waxes or sealants that are protecting your paint and trim.
    307WY likes this.
  22. Jun 22, 2024 at 10:48 AM
    justaman333
    justaman333 New Member
    97 Toyota 4Runner
    How long have they lasted you? I'm in Colorado. Never heard of these until today so thank you.
  23. Jun 22, 2024 at 11:33 AM
    Well69
    Well69 New Member
    About 2 years so far. No regrets. They're over priced, but they are the best.
