Windshield Wiring Channel
Discussion in '5th Gen 4Runners (2010-2024)' started by RFB, Apr 9, 2022.
  1. Apr 9, 2022 at 10:34 AM
    RFB
    RFB [OP] New Member
    Jailbreak
    2019 trd pro
    metaltech slider, front bumper 4 in lift UCA/LCA panhard
    I know KC makes a rubber channel to allow you to run wiring down windshield I have it Ive used it its "ok" anyone know of a better option? I have several wires coming down and the KC just isnt tickling my Pickle. lemme know. Thank You
  2. Apr 10, 2022 at 2:26 PM
    rageandlove
    rageandlove New Member
    I just ran wires down the gutters on either side.
    Nice and clean. One has 2 wires inside, one has 3, so I was able to get 3 different switched lights up there.
  3. Apr 13, 2022 at 8:23 AM
    Scoobyvroom
    Scoobyvroom New Member
    2020 Tundra
    Looks nice. I see the passenger side has 18awg. Is that a two or three conductor? You happen to know what the OD of the wire is that fits?
  4. Apr 13, 2022 at 9:47 PM
    rageandlove
    Scoobyvroom likes this.
  5. Apr 14, 2022 at 6:05 AM
    MrSmartypants
    MrSmartypants New Member
    '17 4R TRD Pro
    I got some 18-2 from Amazon last week. It was about 4.3mm OD
  6. Apr 14, 2022 at 6:31 AM
    Henry J
    Henry J The truth is out there, just use the search bar…
    Would 18-4 fit in that gutter? I have 2 different pairs of 2 way DD’s off the back I’m still trying to figure out.
  7. Apr 14, 2022 at 7:18 AM
    MrSmartypants
    '17 4R TRD Pro
    I think it's gonna stick out and not really fit in there. A single 18-2 probably fits well, but an 18-4 will likely be around .30" dia. The 18-4 might fit in the KC wire hider (8MM ID or .314").
  8. Apr 14, 2022 at 7:24 AM
    Henry J
    Thank you! My brother wanted to run them down the back and thought I was being an idjit, looks like he was right.
  9. Apr 14, 2022 at 10:41 AM
    T4R13
    T4R13 New Member
    Clarksburg wv
    19 sr5p
    Standard cb coax cable fits it perfectly, I’d say as long as it’s a contained wire set you could fit 1/4” diameter in there. Or a single 8guage wire
  10. Apr 14, 2022 at 9:00 PM
    rageandlove
    I disagree. The 18-2 and 18-3 are exactly the same diameter. You should just buy 18-4 from Amazon and see. You can return it.
    Or run one up either side of the windshield. That's what I did. I have 3 different set of switch lights up there.
  11. Apr 15, 2022 at 4:16 PM
    RFB
    RFB [OP] New Member
    Jailbreak
    2019 trd pro
    So I wish this thread stayed on point, if I could have run my wires down the windshield I would have, I used KC on both sides but wanted an alternative that fit better.
  12. Apr 15, 2022 at 5:54 PM
    rageandlove
    Sorry we disappointed you. The original post was for “other ideas” so we tried. There was no about “don’t tell me about about windshield gutters” criteria. Most of us aren’t mind readers.
    Other options that are in the other threads on the topic.
    1 drill a hole in your roof and use marine hardware
    2 run it to the back out the rubber boot that passes wires between the hatch and then body.
    Henry J and T4R13 like this.
  13. Apr 16, 2022 at 5:14 AM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    What exactly isn't the wire hider doing for you?
  14. Apr 16, 2022 at 12:45 PM
    spyder918
    spyder918 501st Unit: GGG
    2019 TRD ORP MGM
    A little off topic but those of you who run wires on the roof do you wrap the connections or wiring in anything like tesa or electrical tape?
  15. Apr 16, 2022 at 1:59 PM
    achtung6
    achtung6 New Member
    What roof rack are you running? Thanks!
  16. Apr 16, 2022 at 7:53 PM
    rageandlove
    See my link above - the stuff I got from Amazon had the wires already wrapped in a black jacket so no need.
    Sherpa Crestone. Sherpa makes great stuff.
    achtung6 likes this.
