Winch Solenoid mounting location? / idea
Discussion in '5th Gen 4Runners (2010-2024)' started by Thacrow, Sep 26, 2022.
  1. Sep 26, 2022 at 10:40 PM
    Thacrow
    Thacrow [OP] New Member
    2021 ORP
    Speed holes
    I've got a Warn Zeon 12-s Platinum and this Warn power interrupter Solenoid:
    https://www.amazon.com/WARN-63001-Replacement-Solenoid/dp/B000OV4NT4
    Since it won't be fused, I'd like to mount this as closely to the positive terminal as possible.
    So I was thinking about getting one of those thick, wide aluminum battery brackets and then just mount the solenoid in the middle of the battery on that bracket. How could a solenoid get any closer to the positive than that?
    Can anyone shoot any holes in this idea or otherwise tell me how it's not a good one?
    Also - where are people mounting their solenoid power interrupter for the winches?
  2. Mar 1, 2023 at 12:04 AM
    Thacrow
    2021 ORP
    Speed holes
    Following up here's what I ended up with. Just shaped down a piece of metal i had laying around, welded it to the the battery bracket to bolt the solenoid to so I could have the shortest hot coming out of the battery as possible to try to be as safe as possible.
    grizzlypath and Frizzle77 like this.
  3. Mar 1, 2023 at 8:02 AM
    Obviously your solution shows superior intellect. I did something similar. :laughing:
    Mine mounts on the strap using the j bolt that holds the battery down.
  4. Mar 1, 2023 at 10:41 AM
    Thacrow
    2021 ORP
    Speed holes
    Hey I like your solution thank you for sharing! and your bracket shows a lot more craftsmanship than mine
  5. Apr 28, 2023 at 6:03 AM
    Sandbuster
    Sandbuster Breaking Wind
    Central Florida
    2019 TRD Offroad
    That is a clean looking setup - I like it.
  6. Apr 28, 2023 at 6:20 AM
    FN2187
    FN2187 Stormtrooper
    Earth
    2019 TRD ORP w/ KDSS
    I like both those options but unfortunately I'm not a welder. I do feel the need to finally get my blue sea systems battery switch mounted though - it's been in the garage a couple of years. Was thinking about this:
    https://c4fabrication.com/products/4runner-engine-bay-accessory-tray-driver-side-2010
    Was also weirded out that the winch cables (smittybilt x20 gen2) are some strange gauge wire that i don't think I can get. I assume I can go thicker but shouldn't go thinner for my jumper between switch and battery?
  7. Apr 28, 2023 at 8:34 AM
    No need to weld. I just overcomplicate things. It’s mostly channeling your inner 1st grade self in art class. Only with aluminum or steel sheets instead of construction paper.
    @Thacrow did it a bit more straightforward. A file, a jigsaw (or hacksaw) and a drill is all you really need. And time to noodle out a good way to make things fit. Otherwise, nothing wrong with the c4 plate.
    Yes, I would use a lead the same size or larger. Found mine at a Boating supply store. They had piles of pre made leads for trolling motors.
  8. Apr 28, 2023 at 9:11 AM
    Thacrow
    2021 ORP
    Speed holes
    Since you bring up the fuse box, here's what @munit85 and I did for a relay box.
    https://www.4runners.com/threads/relay-box-instead-of-fuse-block.27365/
    If you happen to be in the bay area I'd be happy to help you weld a plate to your battery bracket to mount a switch. And I have plenty of wire and ends laying around for that jumper / lead from battery to switch.
    Edit: per @McSpazatron you could totally just bolt a plate to the battery bracket. use a couple lock washers for sure. No need to weld as he said.
  9. Apr 28, 2023 at 4:11 PM
    FN2187
    FN2187 Stormtrooper
    Earth
    Appreciate the offer but I'm on the other side of the country. Didn't think about bolting to the battery bracket - lots of good ideas. There are two metal fabricators nearby that I can probably grab some scrap pieces of sheet to make something for free. Gotta wait for a dry weekend though, this one's shot with rain
  10. Apr 28, 2023 at 4:59 PM
    Thacrow
    2021 ORP
    Speed holes
    i just used the back of a large metal electrical plug outlet i had laying around. could walk around home depot and see if there's a cheap piece of metal
  11. Apr 29, 2023 at 10:26 AM
    yeah, most hardware stores have a bin where they sell lengths of all sorts of angle, channel, sheet, tubes etc. If you only need a small piece, its the cheapest way.
  12. May 5, 2023 at 11:02 AM
    LA260
    LA260 New Member
    Love your setup. Which switch are you using?
  13. May 9, 2023 at 2:48 PM
    Han4Run
    Han4Run New Member
    2019 4Runner Pro
    Here’s my setup with c4 panel and blue sea switch.
    skistoy and McSpazatron like this.
  14. May 9, 2023 at 5:04 PM
    FN2187
    FN2187 Stormtrooper
    Earth
    Nice setup! I see you have your diff breather mod attached there as well - that's something else I'd like to do once I catch up with all the stuff I already have waiting to install
    Han4Run[QUOTED] likes this.
  15. May 9, 2023 at 11:41 PM
    LA260[QUOTED] likes this.
  16. May 10, 2023 at 12:04 AM
    Thacrow
    2021 ORP
    Speed holes
    LA260 likes this.
  17. May 10, 2023 at 9:32 AM
    LA260
    LA260 New Member
    Yeah I noticed that too. For my winch (Warn Evo 10S) the max amp is 358A. I think this switch will be fine. 350A Continuous Rating.
    https://www.amazon.com/Blue-Sea-Sys...ies+on+off+battery+switch,aps,129&sr=8-3&th=1
    Thacrow[QUOTED][OP] likes this.
  18. May 10, 2023 at 11:00 AM
    Yeah, I bought this one because it was the closest thing I could find and trust at the time. I figure, my vr1000s is not going to be pulling max all the time on a pull. And it gets to max it probably wont exceed the 750 aml 10 second rating.
    I couldnt find specs on the solenoid warn sells. Anybody know the max amp rating?
  19. May 10, 2023 at 4:50 PM
    Thacrow
    2021 ORP
    Speed holes
    I emailed and called warn and couldn't find anyone who worked there who knew. Looked a lot online and couldn't find anything. They only sell one so I figured it's probably built to work with anything they sell. I don't think it has a rating.
    I pulled the rear end of this Ram sideways out of ruts. Tires were burred to the frame. So we were pulling sideways right into walls of the ruts until it slide out. Winch was going pretty darn slow. probably had near max amperage going. Warn solenoid has been holding up just fine (though I do carry a spare and have enough slack to directly wire the winch), and as I've been saying my winch pulls 446 amps max.
    Han4Run likes this.
  20. May 10, 2023 at 5:20 PM
    Thanks for sharing that info and your winching experience. I’m not sure how a switch or a solenoid would fail if overtaxed. Does it melt the leads to the posts, or is it the switching mechanism that welds itself down in the on position? My guess is that the failure would be closed (meaning you couldnt switch the battery connection off). Maybe it could act like a fuse of sorts though…just interesting to ponder.
    Either way, I think it’s good to always use the winch carefully, and with an eye to reduce the potential for loads as much as possible. Not only for the health of the electrical system, but to manage the amount of energy in stored up in the line/shackles should something break.
    The mechanical simplicity of disconnecting the lead from the battery has it’s advantages. Nothing to break. But I like the idea of a switch, since I dont have mess with making an electrical connection while potentially muddy, tired, with poor footing, etc.
    Hold on a minute… @MeefZah … kinda joking but not joking, would we have to worry about the amp rating of a wingnut?
  21. May 10, 2023 at 5:33 PM
    Thacrow
    2021 ORP
    Speed holes
    The way electricity works it doesn't go through the wing nut so it's resistance wouldn't heat it up because there would not be any.
    I think the solenoid would fail the same as starter solenoids fail. They just stop working.
    McSpazatron likes this.
