Will these tires fit??
Discussion in '5th Gen 4Runners (2010-2024)' started by Nemo, Feb 29, 2024.
  1. Feb 29, 2024 at 9:58 AM
    Nemo
    Nemo [OP] New Member
    Dave
    Oroville, CA
    2021 TRD OR Stock for now...
    Added all towing equipment
    The previous owner installed Falken A/T LT275/70R17 tires on my stock 2021 TRD OR about a year ago. (He also had a small front lift/leveler put on front end...) A friend is giving me his used Falken 285/70R17. Wondering what you folks think; will it rub? I see others putting on this size but most have been raised.
  2. Feb 29, 2024 at 10:40 AM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    What wheels?
  3. Feb 29, 2024 at 11:35 AM
    Nemo
    Dave
    Oroville, CA
    Stock wheels. For now...
  4. Feb 29, 2024 at 11:51 AM
    1SilverRunner
    Tejas
    Few different stock wheels offered on the 4R depending on your trim and year. Are you referring to these?
  5. Feb 29, 2024 at 11:58 AM
    Nemo
    Dave
    Oroville, CA
    Yes, same wheel.
  6. Feb 29, 2024 at 12:04 PM
    scottiezilla
    scottiezilla New Member
    I have those stock wheels with KO2 285/70/17
    BP-51
    BMC
    SPC UCAs
    N even spidertrax(think the normal 1.25”?)
    Fender liners either gone or pushed in
    Still had a lil rubbing
    Now that’s also with rokblokz but I drilled a hole in them n zip-tied them, bent back, to hole in frame
    still minor rubbing at full turn when backing out but nothing crazy
    it really all depends but you might have to at least play with your inner fender n ditch the flap
    we’re all built differently you know…
  7. Feb 29, 2024 at 12:49 PM
    HuskerRunner
    O,NE
    2023 SR5P
    How close are you now? Brand new you're only talking .5" wider.
  8. Feb 29, 2024 at 2:19 PM
    1SilverRunner
    Tejas
    I'm sure someone else here has those wheels with 285s and can chime in!
  9. Feb 29, 2024 at 2:28 PM
    Nemo
    Dave
    Oroville, CA
    With my right front wheel cranked all the way to the left there’s about 1/2” gap between the outside edge of the tire and the front fender. So I guess the tires I’m thinking of changing to might rub there esp w/ mud. Otherwise good I hope.
  10. Feb 29, 2024 at 3:45 PM
    i think they’ll fit just fine. I have 285/70/17 Falkens on a 2” lift with no trimming and still have all mudflaps.
  11. Feb 29, 2024 at 3:54 PM
    all little trim and heat gun massage may help clear more
  12. Feb 29, 2024 at 4:01 PM
    Nemo
    Dave
    Oroville, CA
    So the front corners of the front fenders will have to be trimmed. What's the best way? I kinda jacked my last 4runner with all my changes to speakers, some addons, but I want to keep this one nice.
    Also I guess I'll have to remove the front mud flaps as there's only about 1/2" clearance there now.
  13. Feb 29, 2024 at 4:05 PM
    razor knife, take a little off at a time. no need to remove the mudflaps. You can heat them up and push them back or drill a hole and zip tie back. I didn’t have to do anything to mine at 2 inches of lift. I guess I got lucky
    1SilverRunner likes this.
  14. Feb 29, 2024 at 4:09 PM
    Nemo
    Dave
    Oroville, CA
    Thanks for the info!!!!
  15. Feb 29, 2024 at 4:13 PM
    anytime!
