Will running boards stay out with doors closed?
Discussion in '5th Gen 4Runners (2010-2024)' started by Dougster, Oct 20, 2024.
  1. Oct 20, 2024 at 12:54 PM
    Dougster
    Dougster [OP] New Member
    Douglas
    SoCal Mountains and Valleys
    4Runner 2024 Limited Full time 4WD
    Can I find a hack that will let the running boards stay out with the doors closed? I want to stand on the running boards to load the rooftop cargo box with all the doors closed.
  2. Oct 20, 2024 at 1:15 PM
    To keep the power deployable running boards on a 2023 Toyota 4Runner permanently extended, locate the switch controlling the running boards (usually on the driver's side door panel) and set it to the "manual on" position, which will keep the boards deployed regardless of the door status; check your vehicle's manual for the exact location and operation of this switch.
    icebear, Captain Spalding and Mr.DRZ like this.
  3. Oct 24, 2024 at 10:41 AM
    Dougster
    Douglas
    I did try that switch. It doesn’t keep the running boards extended. The choices are only automatic (which always retracts when the doors close) or off (which never extends
  4. Oct 24, 2024 at 10:43 AM
    Dougster
    Douglas
    I tried stepping on the running boards prior to shutting the door, and if I stepped down hard, it locked the running board in the extended position. This is the result I wanted, but now I am wondering if this is in any way damaging the mechanism. Does anyone know?
  5. Oct 24, 2024 at 10:48 AM
    MWinkTRD
    MWinkTRD Basically Stock
    Max
    Southeast Alabama
    2023 MGM TRD ORP
    I had AMP Research power steps on my Silverado and that's how I cleaned/used mine to wash for over 5 years without any issues
    Dougster[QUOTED][OP] likes this.
  6. Oct 24, 2024 at 11:59 AM
    crob42
    crob42 New Member
    Los Angeles
    21 Limited
    Xreas delete. Bilstein 5160/6112 285 Toyos. BMC. Prinsu
    I just tried this. Put on auto. Open door. Switch to off with door open. Shut door. Magic.
    edited, I was wrong.
  7. Oct 24, 2024 at 12:34 PM
    Dougster
    Douglas
    Thanks for the suggestion. I guess I'll just use the step on method (while it is retracting) and hope it isn't damaging the mechanism.
  8. Oct 24, 2024 at 12:37 PM
    crob42
    crob42 New Member
    Los Angeles
    21 Limited
    Odd. Mine stays out and was excited to learn a new trick.
  9. Oct 24, 2024 at 12:38 PM
    Dougster
    Douglas
    My switch is labeled "Automatic" and "Off." No "manual on" position. Maybe a different year or model?
  10. Oct 24, 2024 at 12:43 PM
    crob42
    crob42 New Member
    Los Angeles
    21 Limited
    Ok. What’s odd is I was an idiot and was resting my foot on the step for my experiment and that was enough to trip the safety. So you are correct. It does stow in auto and no, my limited is not special.
