Will 8 inches wide wheels with a 10mm offset fit?
Discussion in '5th Gen 4Runners (2010-2024)' started by Sly, Mar 24, 2024.
  1. Mar 24, 2024 at 6:48 PM
    Sly
    Sly [OP] New Member
    Canada
    Hi, I am planning to replace the tires and wheels on my 2022 TRD Off-Road 4Runner. I aim to equip it with Toyo Open Country III tires. I've found a set of used XD Series XD811 17" wheels, which are 8 inches wide with a 10mm offset. Will these wheels be compatible with my vehicle without causing any rubbing, affecting handling, or stressing the components? I also need to know if these wheels will extend outside the fenders, as I think it's illegal where I live in Quebec, Canada.
    I tried to figure it out using this website, but I lack the minimal required tire knowledge to find my answer. Thanks
  2. Mar 24, 2024 at 7:04 PM
    It'll fit, but you'll rub a little more than you would with stock sized tires.
  3. Mar 24, 2024 at 7:06 PM
    Sly
    Sly [OP] New Member
    Canada
    Thansk. Will it rub because of the tire, the wheel width or the offset?
  4. Mar 24, 2024 at 7:26 PM
    Is that a positive or negative offset?
    Stock wheels generally have a small positive offset. +10 shouldn't rub with Stock size tires. -10 wheels will almost certainly rub, even with stock size tires.
    ThatOneGuy and SlvrSlug like this.
  5. Mar 24, 2024 at 7:33 PM
    Sly
    Sly [OP] New Member
    Canada
    It's +10mm offset. Thank you
  6. Mar 24, 2024 at 9:40 PM
    I would think who your buying the rims from could provide the compatibility specification to ensure they will work on the 4Runner.
    1SilverRunner likes this.
  7. Mar 28, 2024 at 2:42 PM
    JSP127
    JSP127 New Member
    I have -18 offset on 8.5" wheels and just barely rub while full lock in reverse. Very minor trimming of the front bumper edge and push the liner in a little. The stance is much better though. If you want a little more stance, I'd go with 0 offset or more.
  8. Mar 28, 2024 at 6:52 PM
    bronzestar1
    bronzestar1 New Member
    2023 Limited magnetic gray with redwood interior
    275/55-20s, Airaid CAI, Summit muffler, oil catch can
    Go to "willtheyfit.com", and play around with different tire sizes and wheel specs (to include offset). This site has helped me numerous times figure out if a different aftermarket setup will work on a variety of vehicles that I've owned.
  9. Mar 29, 2024 at 9:04 AM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    Hey OP
    Welcome here, from BC!
    This forum is excellent I like it a lot. Better information and faster more reliable answers from real world 5th gen owners.
    Stock setup but upgraded 8" wide wheels with 265/70 Toyos won't rub. Even if it was -10mm, it would be minimal.
    Your +10/8" wheels especially, and even -10 wheels, won't put stress on anything.
    Handling totally fine.
    +10/8" won't poke at all, and won't be flush. -10 won't be flush either but close.
    GOODLUCK
    TRD Offroad 7.5" wide, +15mm offset
    SR5 7" wide, +15mm offset
    TRD Pro 7" wide, +4mm offset
    I went to 9" wide wheels, 0 offset, LT285/70's, 1.25" spacers pushing wheels to -32mm offset :devil:
  10. Aug 29, 2024 at 3:51 PM
    Jobin918
    Jobin918 New Member
    Tire size? I’m looking at 17x8.5” but not sure if I want to run 0 or -12 offset. Still on stock suspension for the time being so may just stay with 265/70 but I really want a 275/70 but afraid the offset is going to cause more rubbing than I’d like!
