Wildpeak 265's w/ Bilstein 1.75" front lift, 0.75" rear spacer
Discussion in '5th Gen 4Runners (2010-2024)' started by SanJuan, May 22, 2023.
  1. May 22, 2023 at 6:57 PM
    SanJuan
    SanJuan [OP] New Member
    Will this look okay or will there be too much of a gap in the rear wheel well with a slight rear lift? Anyone with a similar set up that can share pics? Wildpeak 275 and 285's are too heavy for my liking so I'm looking to stick with 265's. Thanks everyone.
  2. Jun 3, 2023 at 5:08 PM
    heres mine with a 2” front and 1.5 rear lift on 285’s.
    dump the 265s and upgrade
    Spearhead and Gharddog03 like this.
  3. Jun 3, 2023 at 5:09 PM
    Heres a pick wiith same lift on 265s
    Ripper238 likes this.
  4. Jun 5, 2023 at 9:55 AM
    Smnst
    Smnst New Member
    Are you running factory upper control arms with this lift? I am about to go up 2" in front with the 6112s and am wondering if I can get away with the factory UCAs.
  5. Jun 5, 2023 at 10:02 AM
    yes, factory uca’s. Alignment is perfect and nothing is maxed out
    Smnst[QUOTED] likes this.
  6. Jun 5, 2023 at 10:30 AM
    RuggedJay
    RuggedJay New Member
    How much of a drop in MPG after you did this???
  7. Jun 5, 2023 at 12:25 PM
    1-3 mpgs tops. Just came back from NJ- 130 mile trip, 2 adults, 1 kid and full tank of gas when I left. I averaged 18.7 mpg doing 75-80 mph and some stop and go around Phila I95 area. Tires were at 36 psi hot.
  8. Jun 5, 2023 at 12:53 PM
    Chris In Milwaukee
    Chris In Milwaukee New Member
    Chris
    2.5/1.5 with 265s. It should look just fine. :)
    Garlic, Spearhead, Idayota and 2 others like this.
