Why the running boards top plastic is moving
Discussion in '5th Gen 4Runners (2010-2024)' started by otto, Oct 15, 2023.
  1. Oct 15, 2023 at 4:24 PM
    otto
    otto [OP] New Member
    otto
    2022 4Runner Limited
    I have a 2022 4Runner Limited and I just noted the running boards top plastic are moving. Does anyone know how to move them back into place?
  2. Oct 15, 2023 at 4:38 PM
    I don't have these kind of steps, so this is a random guess: I bet there are clips that hold the plastic step piece onto the frame of the step. If you can, look underneath and see if you can see inside the step from the bottom.
    Also, is it just happening on one side or both? Is the movement very noticeable? Like, does it slide with ease on its own, or do you need to 'try' to move it?
  3. Oct 16, 2023 at 5:43 PM
    otto
    otto
    I check under the steps and there some screws, however I lose one of the to see if the plastic would pop up but nothing. I am unsure if I can pry it out after I lose the bolts.
