Why no hybrid rear bumpers?
Discussion in '5th Gen 4Runners (2010-2024)' started by Charlievee, Dec 15, 2024.
  1. Dec 15, 2024 at 2:36 PM
    Charlievee
    Charlievee [OP] Not new member.
    Why do rear bumper option suck so bad on the 5th gen? Unless i'm missing something, we get hitch mounts and million pound gravel scoops. Where is the clean minimalist bumper?
  2. Dec 15, 2024 at 2:51 PM
    The bumper options suck because of the sensors for the RCTA and Blind Spot monitoring system. If you go with a full steel bumper you have to rip all that stuff out and manually disable it. Most people don't want to give those features up.
    evank likes this.
  3. Dec 15, 2024 at 3:08 PM
    Charlievee
    Don't think i have that nanny stuff on a 2018.
    Stoney Ranger likes this.
  4. Dec 15, 2024 at 3:16 PM
    Check out Nguyen Works, they make the cleanest minimalist rear bumpers out there.
  5. Dec 15, 2024 at 3:31 PM
    BLKNBLU
    BLKNBLU New Member
    2019 Nautical Blue OR
  6. Dec 15, 2024 at 3:31 PM
    Agent_Outside
    Built 2011 T4R Limited
    5th gen’s production started like a decade before they started to get the driver assist stuff, that’s definitely not the reason.
  7. Dec 15, 2024 at 3:38 PM
    Charlievee
  8. Dec 15, 2024 at 4:01 PM
    Up, down and all around!
    Nguyen Works def is in the 'thin' department, another is the Welded Hybrid by Extreme Terrain. While the majority of the other bumper designs are thick for ultimate bash protection I tend to think of it more as rear collision protection.
    As far as the BSM sensor is concerned, Victory 4X4 makes a relocation bracket kit.
  9. Dec 15, 2024 at 4:01 PM
    BLKNBLU
    BLKNBLU New Member
    Glad to help. I had not heard of them either and stumbled across them somewhere here on the site.
  10. Dec 15, 2024 at 4:01 PM
    Hungryhawk
    Hungryhawk New Member
    Southern CA
    2017 SR5
    Has anybody viewed a similar minimalist front bumper product that ony needs slight trimming of factory front bumper? Winch mount not necessary.
  11. Dec 15, 2024 at 4:15 PM
    Keep in mind that the focus on front bumpers has been on improving approach clearance, adding bash protection and winch mount capabilities. These full width designs pretty much chop the lower half of the plastic bumper cover area. The least obtrusive front bumper designs revolve around the 'Covert' style that only requires cutting of the center valence area. Optionally folks perform the 'Viper' cut with these bumper types in order to open up clearance to the front tires.
    BLKNBLU likes this.
  12. Dec 15, 2024 at 4:31 PM
    BLKNBLU
    BLKNBLU New Member
    Photon_Chaser likes this.
  13. Dec 15, 2024 at 9:25 PM
    :rofl:
    So true, you would think they would design them a bit more thoughtfully for the amount of money they go for.
    I liked that “bumper” a lot. But I don’t like that you have to weld it to the frame/rear crossmember, and I really don’t like the interface of the bumper/crossmember weld either. Just tubes welded to the middle of the flat face of the crossmember. A properly done weld will hold, but it will probably hold enough to tin-can the flats and cause permanent misalignment.
    Although, technically, once you’ve crossed over into welding…nothing is truly permanent if you’re willing to cut steel and re-fabricate new crossmembers…it’s just a lot of time and money to do so.
  14. Dec 15, 2024 at 10:42 PM
    Pavo
    Pavo New Member
    Check out outgearlsolutions in Santa Ana Joe the owner just came out with a bumper that works with bsm
  15. Dec 15, 2024 at 11:39 PM
    Hungryhawk
    Southern CA
    2017 SR5
    My desired front metal bumper is for protecting my truck's front end & wheels from suburban parking & crazy drivers, driving through brush, pushing a disabled vehicle out of my way. A front 2" receiver for utility platforms, and receiver mounted winch base, Since I do not plan difficult Rock crawling.
  16. Dec 16, 2024 at 2:43 AM
    2021venture
    2021venture New Member
    Todd
    2021 Venture
    I am very happy with 80%. Cutting the cross member was not an option or losing factory receiver hitch. If ever needed to remove cutting/grinding it off is feasible. Mine was installed by a great welder which shows.
    C4 low profile for the front. Both I tried to keep weight down and keep factory lines of vehicle.
  17. Dec 16, 2024 at 4:54 AM
    tk421
    Tyler
    DFW Texas
    2023 Limited 4Runner
    Thank you for the note about the relo kit for the BSM. Added link if needed. Also I see a lightweight and gorgeous bumper by Victory 4x4 that I now need. It's on sale and damn near half the price of others I have seen like it. It's also got a hitch which I need and even though I see they say it's not SAE tested it's the best "non guarantee" manufacturers note I've seen. I'm not pulling an Airstream, but at times may pull a small lightweight trailer from time to time.
    Edit: I can rig up relocated prox mounts easily with this and buy the swing outs later. Nice.
  18. Dec 16, 2024 at 7:30 AM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
  19. Dec 16, 2024 at 12:43 PM
    joshdub
    joshdub New Member
    2020 TRD ORP
    What about the previous 12 years of 4runner production that didn't have any of those features?
    Most 4runners do not have RCTA or BSM
  20. Dec 16, 2024 at 1:24 PM
    Didz
    Didz New Member
    2020 AG pro
  21. Dec 16, 2024 at 1:40 PM
    Stoney Ranger
    Dave
    Driftless Area
    '18 SR5 Nauti Blue
    Here's the Nyguyen Lo-Pro. I bought it raw metal, then painted to match. The aux lights are in factory holes that were hogged out. There is a nice flat spot on the frame to weld recovery points. There is a rear X-member delete option, but you will lose the trailer hitch forever. The x-member gets sawz-alled. Pics in the link show the delete option, but here's my ALF.
    https://nguyenworksusa.com/shop/ols/products/5th-gen-4runner-plated-low-rear-bumper
    AP1GczPXwHC3FN1v3e2a0FsLRLDJ3-zZFD8RVzwu_cf5161417a7a37b0d976486758b61d384f58d678.jpg
  22. Dec 16, 2024 at 2:17 PM
    Something caught my eye checking on couple on rear bumpers...
    Bumper 1 -
    Bumper 2 -
    Also -
    I've seen posts owners having problems with insurance having winches. I wonder if any trouble with insurance having rear bumper.
    Just a thought....
  23. Dec 16, 2024 at 2:48 PM
    BLKNBLU
    BLKNBLU New Member
    Thanks for that. Does this have both maintain and delete X member options for installation or did you have to cobble something to keep it.
  24. Dec 16, 2024 at 2:52 PM
    I didn't think about that. I was wrong.
  25. Dec 16, 2024 at 3:22 PM
    I believe that's because manufacturers that I know of offhand do not perform crash safety testing and/or testing of the hitch conforming to SAE J684, NHTSA and DOT standards. Competent weldment and stress design can meet certain criteria and or reasonable stress loads but in order to certify means a great deal of effort is necessary to prove a single manufactured article meets the above standards. So for weldments alone a manufacture would need to have on staff a Welder, Welding Inspector and a Welding Engineer...the latter two should be certified.
    kmeeg[QUOTED] likes this.
  26. Dec 16, 2024 at 3:47 PM
    Stoney Ranger
    Dave
    Driftless Area
    '18 SR5 Nauti Blue
    You keep the hitch if the factory x-member isn't cut off. The hitch skid set-up is pretty obvious in my pic. The part that has the aux lights is the factory frame of the 4Runner. I unbolt the hitch and put the spare on the roof when I hit the trails. The bumper is held on by 10 bolts and 3 brackets.
    Here's an install video.
    https://www.youtube.com/watch?v=RkbTZ3LK7NM
    Old Tanker likes this.
