Why doesn’t the pro come with the trd intake
Discussion in '5th Gen 4Runners (2010-2024)' started by Jynarik, Aug 5, 2019.
  1. Aug 5, 2019 at 3:27 PM
    Jynarik
    Jynarik [OP] I like boobies
    Austin Texas
    2019 trd pro voodoo
  2. Aug 5, 2019 at 4:00 PM
    It doesn't do anything for performance :notsure:
  3. Aug 5, 2019 at 4:16 PM
    Charlievee
    Charlievee Not new member.
    Cost more and they have to modify the harness.
  4. Aug 5, 2019 at 4:19 PM
    Jynarik
    Austin Texas
    2019 trd pro voodoo
    Oh I know. I just think it’s funny that I have a trd pro, and it doesn’t have a trd pro intake.
    909Runner, WallyT4R and 4Runner fun like this.
  5. Aug 5, 2019 at 4:30 PM
    Charlievee
    But it does help the engine sound less like a blender add some headers and a mid pipe and it will almost sound like a real truck.
  6. Aug 5, 2019 at 4:58 PM
    4Runner fun
    Ryan
    Nebraska
    No answer. I saw it on a Tundra Pro (inside the stealership). Maybe a dealer thing. I saw our local stealership installing a pro rack & skid. I figured that they came that way!
    I did install it (TRD intake) this weekend though.
    No significant "performance" increase; but, it does allow the engine to breathe easier & adds a nice engine noise instead of the factory vacuum sound.
    It has a little but more punch mid range but nothing significant.
    An engine is a simple air pump. Unrestricted intake is better than torque tubes & tons of sound deadening materials.
    Simply physics. Just like drag coefficient. The difference is minimal till they all add up.
    Look at any 5th gen exhaust after the cat. Small as hell!
    Every cm helps (that is what she said)! Sorry. LolScreenshot_20190803-155118_Gallery.jpg
  7. Aug 5, 2019 at 5:02 PM
    4Runner fun
    Ryan
    Nebraska
    Modify the harness...
    I hope you are joking! You have to redirect some wires. Yes, you do have to cut a sheath off. It is silly easy; I promise.
    Strandskov and WallyT4R like this.
  8. Aug 5, 2019 at 5:25 PM
    Agent_Outside
    Built 2011 T4R Limited
    Because the TRD Pro trim is a just a glorified appearance package.
    HondaKen, WallyT4R and 4Runner fun like this.
  9. Aug 5, 2019 at 5:48 PM
    4Runner fun
    Ryan
    Nebraska
    With better shocks...
    Which could be just stickered!
    Since they are a wear item & most lift theirs...
    Still, the TRD intake should be OEM for the Pro's. Absolutely!
  10. Aug 5, 2019 at 5:57 PM
    4Runner fun
    Ryan
    Nebraska
    Does this look like a major modification?
    We wrapped the wires in electrical tape and then sheathing. Very easy. Hardest part was cutting the factory loom to not hit wires (we cut from the inside out...
    Patience is the only key to this install that is completely worth it.
    Just my $0.02
  11. Aug 5, 2019 at 6:22 PM
    Charlievee
    I'm aware, I have done it. Just thinking of a Toyota "tech" doing it makes me want to vomit.
    4Runner fun[QUOTED] likes this.
  12. Aug 5, 2019 at 6:25 PM
    Charlievee
    at a boy, good job!
  13. Aug 5, 2019 at 10:41 PM
    WallyT4R
    WallyT4R New Member
    Well a Toyota tech installs everything the PRO has on it at the port when it comes into the country. The only thing on the PRO (which is really a Offroad/Trail) that is installed at the factory is the special color.
  14. Sep 4, 2019 at 9:33 AM
    Compromised 4Runner
    Compromised 4Runner New Member
    2018 4Runner SR5
    Was wondering if you would not mind posting a pic of the area above the intake box? Now that I know the s&b intake will not fit my sr5, Thinking of either getting the trd or afe momentous gt intake. But have to be absolutely sure on it fitting.
  15. Sep 4, 2019 at 9:40 AM
    2016Pro
    Save your money, it wont add any performance
    WallyT4R likes this.
  16. Sep 4, 2019 at 9:45 AM
    It sounds cool though.
    WallyT4R and 2016Pro[QUOTED] like this.
  17. Sep 4, 2019 at 9:48 AM
    M_RED
    M_RED New Member
    2019 TRD Pro
    Eibach 1.6in LIft springs and 0.25 in spacer in the front Eibach +200lbs load leveler system in the back RSG Angled Sliders
    I'm 99.99% positive this statement is false. (the exception being the predator side steps) The rest is 100% Tahara factory in Japan. I actually have a friend who is a manufacturing engineer there. First hand knowledge.
    2016Pro likes this.
  18. Sep 4, 2019 at 9:54 AM
    Compromised 4Runner
    2018 4Runner SR5
    The minimal performance gain (larger intake box to house the cooler air) is nice. So is the sound. But I am actually after making the engine run a little leaner. For better MPG. If my anti-life equation .... err.... CIA cost equation is correct, It will pay for itself in gas savings after 3 years.
    W / ((X% * CP) * CE)= years till money is made back
    $300 / ((5% * 37.5) * 52) = 3 years
    CP = cost of tank
    X% = percent better fuel efficency
    CE = tanks used per year
    W = cost of af cai
  19. Sep 4, 2019 at 10:21 AM
    2016Pro
    No it wont save mpgs either. Maybe If you get your ecu tuned you might see some mpg savings. Read up on the trd intake I dont believe they claim meaningful mpg gains.
  20. Sep 4, 2019 at 10:21 AM
    2016Pro
    Its for looks and sound only
  21. Sep 4, 2019 at 10:25 AM
    Compromised 4Runner
    2018 4Runner SR5
    Will look into it. I know s&b don't either. But every other cai manufacturer does. Posts I've seen report that it has as well. Still, once I know it fits will do some more research. Thanks.
  22. Sep 4, 2019 at 11:23 AM
    M_RED
    M_RED New Member
    2019 TRD Pro
    Any modern engine with a closed loop feedback on the 02 sensor will have no impact to mileage with new parts due to a change in A/F ratios because the engine will never "lean out"... Your ECU will keep everything in check and work to maintain a set air/fuel ratio. However, a less restrictive intake, and exhaust reduces the pumping loss of the engine, and that can see some minor fuel economy improvements...
  23. Sep 4, 2019 at 12:17 PM
    It's true. Pro's come off the line as TRD Offroads and are made to be Pro's when they hit port. They have installation teams that put all the Pro goodies on. The only thing that Tahara does on the Pro is spray the unique color (if it's one with a unique color).
    Check out the picture below. This is a Pro that has landed at Port. No TRD Pro badges, no Pro roofrack, no Pro wheels, no pro suspension (cant see that in the picture).
    thirdyota, WallyT4R and Agent_Outside like this.
  24. Sep 4, 2019 at 12:20 PM
    Well not entirely true it comes as an OR.
    The bumper valence is wrong color. Everything else yes is put on locally.
    and so much for that friend in engineering with first hand knowledge.
    WallyT4R, KSJ08 and Agent_Outside like this.
  25. Sep 4, 2019 at 12:27 PM
    Agent_Outside
    Rarely are people this totally and completely wrong, it's almost impressive!
  26. Sep 4, 2019 at 1:37 PM
    Yes but the OR is silver. So the Pros don't come completely as a OR.
  27. Sep 4, 2019 at 1:52 PM
    Kyblack76
    Kyblack76 New Member
    Layton, Utah
    18 TRD O.R
    Because the pro came with the other useless shit...
    HondaKen and WallyT4R like this.
  28. Sep 4, 2019 at 5:49 PM
    4Runner fun
    Ryan
    Nebraska
    I would gladly grad you another picture or post one I have. However, I don't understand your question about where. Is this a hood clearance issue?
    Trim shouldn't matter for a CAI.
    I need clarification & will be glad to help.
  29. Sep 4, 2019 at 8:23 PM
    Compromised 4Runner
    2018 4Runner SR5
    Sorry if it was confusing. Someone else was able to help me out. I needed to see from a top down view the area "past" the filter housing. Looks like the trd will fit my sr5 2wd. Thanks.
  30. Sep 4, 2019 at 8:27 PM
    4Runner fun
    Ryan
    Nebraska
    Good luck.
    It is a great system!
    Let us know if you have any more questions.
    It is an easy install. Take your time and follow the instructions.
    Enjoy!
