Which vacuum line for Sea Foam?
Discussion in '2nd Gen 4Runners (1990-1995)' started by NMRunner, Feb 22, 2019.
  1. Feb 22, 2019 at 4:54 AM
    NMRunner
    NMRunner [OP] New Member
    Max
    I was wondering if anybody know which vacuum line to put seafoam in?
  2. Feb 22, 2019 at 8:05 AM
    Sruskz
    Sruskz New Member
    91’ 4 Runner
    Lifted, 33’s
    I am unaware but there is a video of a guy doing it on his 93 4 runner on youtube.
    NMRunner[OP] likes this.
  3. Feb 22, 2019 at 9:52 AM
    Linuxr
    Linuxr New Member
    VA
    I used to use seafoam on my Nissan Maxima and used the brake booster line.
  4. Feb 22, 2019 at 9:09 PM
    NMRunner
    Max
    Any chance you have a link I looked but couldn’t find it?
  5. Feb 23, 2019 at 4:36 AM
    WanderlostOverland
    WanderlostOverland New Member
    We produced a video showing how we did it to our FJ. I believe our 4R has the same vacuum port. It comes in at 1:30.
    Just be sure to put it in VERY slowly, just a few drops at a time or you risk damaging the pistons and/or valves.
    https://youtu.be/49EODA5VYJY
  6. Feb 23, 2019 at 5:24 AM
    HoBoDanny
    HoBoDanny Dude...
    Daniel
    Kentucky
    2004 SR5 V6 4WD 4Runner
    Things I’ve seen in posts and videos most commonly show using the brake booster line.
  7. Feb 23, 2019 at 5:29 AM
    NMRunner
    Max
    Thanks for the video!
  8. Feb 23, 2019 at 5:40 AM
    NMRunner
    Max
    That’s what I have also. I guess that’s the one thanks for the response.
    HoBoDanny[QUOTED] likes this.
  9. Feb 25, 2019 at 2:24 PM
    atgparker
    atgparker Cal Poly, ETME 1988
    Andrew
    Mission Viejo, CA
    1991 White 4Runner 3.0 L
    Spend your money on frequent oil changes and let the detergents in the oil do their job. These products are a joke. I owned an 1982 4X4 with a 22R which was pre-OBDI. I changed the oil & filter every 2.5 K miles for 16 years. I ran a Hayden oil cooler with remote filter, a Doug Thorley Tri-Y-header, and the Downey Off-road dual side draft Mikuni's and muscle CAM kit for a time during college (2 years of the 16 I ran this truck that way). In doing all this the inside of that engine was as clean as the day I bought it from the Toyota dealer in Poway, CA. I did a valve job on it at 120K but it probably didn't need it and put over 200K on it. I still have that engine and head on hand in my garage but had given the truck to a family member with a new LC motor in it, with some regret now as I find myself back in a Toyota again. The trick is to get all that combustion bypassed gas out of your oil. Long drain interval synthetics are counter productive to that end so don't waste your money on them either! After 30 or 40 K miles your rings are passing more combustion gas blow-by. Go figure!
  10. Feb 25, 2019 at 4:28 PM
    NMRunner
    Max
    Thanks for you input
