Which ones have the front diff problem?
Discussion in '5th Gen 4Runners (2010-2024)' started by Scotty4run, Dec 26, 2022.
  1. Dec 26, 2022 at 3:10 PM
    Scotty4run
    Scotty4run [OP] New Member
    Hello all. I have read about this front diff needle bearing problem and can't tell if all 5th gen's have the potential for this problem or only certain years and/or trim levels (orp, TRD, etc.). I have a 2020 sr5, 6k miles, no mods. I have experienced no problems, just curious.
    Thank you!
  2. Dec 26, 2022 at 4:00 PM
    Your probably fine. I have a 18’ and haven’t experienced any issues with the drive train after 31k.
    Most people have this issue, within the first year of ownership.
  3. Dec 26, 2022 at 4:12 PM
    I’d say your chances are good that you wont get the noise now if you dont have it already. My 21 made the noise since new. Now that it has 40,000 miles, the noise pretty much has gone away.
    But if you live in a warm climate and move to a cold climate, you might get it. Mine made the sound when temps were cold (usually below freezing).
  4. Dec 26, 2022 at 4:20 PM
    Snake River
    Snake River New Member
    2022 Army Green 4Runner Off-Road Premium
    I have a’22’ ORP I purchased in May. Almost 14k miles with several miles in 4WD…not a peep. Works as its supposed to.
  5. Dec 26, 2022 at 4:27 PM
    I think all with the ADD front diff can have the issue or at least I haven’t seen any Limited owners specifically say they have issues.
  6. Dec 26, 2022 at 5:07 PM
    Do Limited 4Rs have the same front differential with the infamous needle bearing?
  7. Dec 26, 2022 at 5:27 PM
    It’s mostly the same but they are AWD so no ADD.
  8. Dec 26, 2022 at 6:01 PM
    Mass4runner
    Mass4runner New Member
    2023 TRD ORP
    My 2010 developed it at around 90k, and my 2019 developed it at around 26k and was replaced under warranty. Seems to me that they all have the potential to be problematic. Having said that, I have never heard of the issue going beyond an NVH issue to an actual failure of the diff.
  9. Dec 26, 2022 at 6:11 PM
    Not true. The 2wd ones don't. ;)
    icebear, Stoney Ranger and MeefZah like this.
  10. Dec 26, 2022 at 6:43 PM
    tblt44
    tblt44 New Member
    Todd
    Tampa
    2021 4 runner
    N/A
    So this happens early, no a lack of maintenence then
    Just hearing of this
  11. Dec 26, 2022 at 8:59 PM
    Agent_Outside
    Built 2011 T4R Limited
    The 4WD Limiteds don’t use the needle bearing design either.
  12. Dec 26, 2022 at 10:47 PM
    Mine was affected pretty much right away. I don't remember noticing it right when I got it, but it was within a week or two that I noticed the symptoms. This isn't always the case, though.
  13. Sep 26, 2023 at 1:16 PM
    Richy
    Richy New Member
    Richy
    2016 Gray 4runner Trail Premium
    2016 Trail, started making noise around 55k miles. I noticed slop on the driver's side where the cv axle goes into the diff, the passenger side has zero play. I did the swap out with the bushing from East Coast Gear Supply but the noise did not go away. I suspect it is the carrier bearing in the diff. Drove it about another 5k miles and the noise is getting worse and now there is play in the bushing on the driver's side - zero play when first installed. Looks like a front diff replacement for me.
  14. Sep 26, 2023 at 1:45 PM
    Matt83
    Matt83 New Member
    Northeast
    I had my front diff replaced somewhere between 6000-9000 miles for needle bearing noise. At 51,000 now with no issues.
  15. Jan 11, 2024 at 5:30 PM
    Steve40th
    Steve40th New Member
    sTEVE
    What do they have? The Limited
  16. Jan 11, 2024 at 7:10 PM
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
    2023 Supercharged 4Runner TRD
  17. Jan 12, 2024 at 6:29 AM
    Steve40th
    sTEVE
  18. Jan 12, 2024 at 6:37 AM
    Ripmo
    Ripmo New Member
    2022 Lunar Rock ORP
    Bilstein 5100 2” front Bilstein 5100 rear w/ 1” Cornfed spacer Sherpa Crestone roof rack RCI Skids and sliders Ironman UCA’s
    I thought I was in the clear after not experiencing the symptoms the first 17k miles. Then the temperature started dropping and I noticed it. I installed the ecgs bushing a week ago and all is good again.
  19. Jan 12, 2024 at 8:09 AM
    I'm not completely sure what the needle bearing does but since I read the needle bearing issue tends to show up in 2WD and lessen/go away in 4WD, the Limited's front axle - being engaged permanently - just won't have parts spinning quickly next to stuff that isn't like a part-time 4WD model in 2WD.
  20. Jan 12, 2024 at 8:47 AM
    Steve40th
    sTEVE
    Okay that makes sense. If the part is engaged all the time, it's not spinning freely and then having to engage periodically
  21. Jan 12, 2024 at 9:31 AM
    None. The CV inner shaft is supported by the diff carrier. In a full-time 4WD arrangement, there's no relative rotation between the CV shaft and the diff carrier in straight line driving. When cornering, the CV shaft rotates on the journal surface of the diff carrier. With part-time 4WD and ADD, the front diff is effectively differentiating 100% of the time in 2WD, so in Toyota's opinion the CV shaft needs to rotate on a rolling-element bearing.
  22. Jan 12, 2024 at 9:54 AM
    Yobruhitsme
    Yobruhitsme New Member
    Denver
    Ineos Grenadier
    I am pretty sure the actual number of reported problems is less than actual number of units having this issue.
    Many people are simply numb to the symptom of this needle bearing issue. Especially with a spectrum of symptom severity
  23. Jan 12, 2024 at 9:58 AM
    Yobruhitsme
    Denver
    Ineos Grenadier
    Have you noticed any MPG drop with the bushing ?
  24. Jan 12, 2024 at 9:59 AM
    Yobruhitsme
    Denver
    Ineos Grenadier
    is the amount of play( CV into the diff), greatly reduced with the new diff?
    also, how severe was the symptom, for dealer to properly diagnose it? My 4R at 500miles is demonstrating this periodically. If I turn the radio volume up to normal listening level, the music will consistently mask the noise. Vibration is still there, but no longer magnified by the complimentary rumble sound
  25. Jan 12, 2024 at 11:46 AM
    Ripmo
    Ripmo New Member
    2022 Lunar Rock ORP
    Too early to tell, I’ve maybe driven 50 miles since without any attention to mpg shown on the dash.
  26. Jan 12, 2024 at 12:00 PM
    Yeah the problem is infrequent enough for Toyota not to do any significant design changes to the front diff in 21 years. My 2010 SR5 at stock height doesn't have this problem at 148k. My 2018 Tacoma lifted 2.7" didn't have this problem. Buddy with 3" lifted 2019 Tacoma had no issues for 63k.
  27. Jan 12, 2024 at 12:10 PM
    LunarTR4
    LunarTR4 New Member
    22’ TR4 ORP LR
    2022 ORP with 2.75" lift in the front. Developed the needle bearing sound around 12k miles. Changed for the ECGS bushing around 16k miles. Haven't heard it since, play in CV is greatly reduced.
    Toy4X4 likes this.
  28. Jan 12, 2024 at 12:41 PM
    Yobruhitsme
    Denver
    Ineos Grenadier
    Any mpg drop after the bushing ?
  29. Jan 12, 2024 at 12:45 PM
    LunarTR4
    LunarTR4 New Member
    22’ TR4 ORP LR
    maybe 0.5 mpg? Since I already had lift and 285s, didn't really care. Just wanted the noise gone LOL. Since then, I have also gotten OTT tune so whatever MPG I lost I got back and some.
    Yobruhitsme likes this.
  30. Feb 16, 2024 at 5:12 PM
    Ripmo
    Ripmo New Member
    2022 Lunar Rock ORP
    Now that I’ve put around 1,000 miles on since replacing the needle bearing, I can say my 80 hour average on my display didn’t change from the 17.4 mpg it was showing before the swap. I’ve also monitored both city and highway driving, and m still getting around 16 mpg city and around 21 mpg highway. This is with a 2” lift, Sherpa roof rack, sliders, and stock sized Wildpeak tires.
    Toy4X4 likes this.
