Which Dongar Adapter for 2021 ORP?
Discussion in '5th Gen 4Runners (2010-2024)' started by White TuRD, Dec 31, 2025.
  1. Dec 31, 2025 at 7:19 AM
    White TuRD
    White TuRD [OP] New Member
    SC
    2021 TRD ORP
  2. Dec 31, 2025 at 7:53 AM
    Guppy1301
    Guppy1301 New Member
    Silver 2019 TRD ORP
    Bilstein 6112/Icon 2" rear TSO bumper 285 MT Baja Boss Northstar x2 Voltage pro booster
    White TuRD[OP] likes this.
  3. Dec 31, 2025 at 7:55 AM
    might be a poorly written Amazon description but did you notice it says "Check Compatibility before ordering" and down below it doesnt list the 4R at all?
  4. Dec 31, 2025 at 8:42 AM
    White TuRD
    SC
    2021 TRD ORP
  5. Dec 31, 2025 at 8:45 AM
    White TuRD
    SC
    2021 TRD ORP
    This makes sense, But I thought all 2021s had the same TSS with camera. I know mirrors can be different; in my case I do not have a plug on the back of my mirror. Figured there was maybe two options to tap into switched vehicle power... if an option extists to avoid tapping into a safety system, generally that is the better way to go.
  6. Dec 31, 2025 at 10:52 AM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
  7. Dec 31, 2025 at 1:19 PM
    White TuRD
    SC
    2021 TRD ORP
  8. Dec 31, 2025 at 2:30 PM
    2020+ is TSS, same across trims
  9. Jan 1, 2026 at 6:49 AM
    White TuRD
    SC
    2021 TRD ORP
    @Thacrow
    Just to confirm, your ORP rear view mirror does not have a connector on the backside, correct? (mine does not)
    You plugged the Dongar adapter into the harness under the headliner, correct?
  10. Jan 1, 2026 at 9:36 AM
    White TuRD
    SC
    2021 TRD ORP
    Clarification from Dongar customer service:
    “There’s no difference in application between the DCA-10 and DCA-12T aside from where they connect. The DCA-10 plugs into the mirror harness, while the DCA-12Tconnects to the TSS module. Both adapters are compatible with your 2021 4Runner.”
  11. Jan 1, 2026 at 10:47 AM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    Correct. Plugged dongar behind headliner after removing the crawl control knobs and headliner lights/buttons.
    However the stock cable is in fact by the mirrors. When adding the dongar you need to pull it up into the headliner so it looks clean with less stuff hanging down. I zip tied the dongar about the headliner with some other wiring.
    Sorry this was the one time I didn't take pics.
    Edit: for anyone reading, the plastics covering the wiring on the mirror and box next to the mirror on the windshield just slide right off either up or down. They DO NOT pull straight off outward. They slide easily off.
  12. Jan 1, 2026 at 12:42 PM
    NOT THE ANSWER TO THIS POST.
    But wanted to share that I like this product. I installed Dongar 7 pin one to my 2019 4runner. Easy install and neat.
    Thacrow likes this.
  13. Jan 1, 2026 at 1:39 PM
    Guppy1301
    Silver 2019 TRD ORP
    My 2019 TRD ORP took the 10 pin Dongar. Is there different rear-view mirrors between the 2019 trims?
  14. Jan 1, 2026 at 1:45 PM
    I don't have a clear pic. Hope this kinda show how my 2019 Limited mirror wire look.
    Thacrow likes this.
  15. Jan 1, 2026 at 1:54 PM
    Guppy1301
    Silver 2019 TRD ORP
    My bad, mine is a 7 pin, also. Was trying to go from memory.
    kmeeg likes this.
