Which battery maintainer out of two?
Discussion in '4th Gen 4Runners (2003-2009)' started by johnf4x4, Mar 11, 2025.
  1. Mar 11, 2025 at 5:51 PM
    johnf4x4
    johnf4x4 [OP] New Member
    2009 4runner SR5, 2025 Tundra Platinum
    Sorry, I could not find an appropriate forum for this question, so asking you 4th gen gurus with experience
    I have two chargers/maintainers.
    The first one after it charged the battery to 100% it keeps constantly fluctuating from 13.4V to 13.55V non stop never dropping below 13.4V.
    The second one after charging the battery to 100% it drops to 12.7V and stays there forever.
    I have my 4runner which starting from the next week i'm going to use approximately ones a week for 5-10 mile runs during summer months and stay in the garage during winter 100% of time.
    Which one do you think is a good charger and behaves correctly for winter/long time maintainer?
  2. Mar 11, 2025 at 9:20 PM
    2019 TRDP w/Kangs brah!
    My choice would be something smart like a Ctek that can condition the battery as well as maintain charge.
  3. Mar 12, 2025 at 12:16 AM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    These work to charge or maintain any type of battery. I throw something like this on my 4runner while I am draining the battery testing stuff while the car isn't running.
    Thats really interesting though because 12.6 ot 12.7 is the battery voltage when topped off.
    sounds like the ither one id always trying to charge maybe?
    sounds like both would work?
    https://www.amazon.com/dp/B07W6B987...3_nIdjuL_mVQm-lOxr720xLbdXnZN_toaAhipEALw_wcB
  4. Mar 12, 2025 at 2:26 AM
    scottiezilla
    scottiezilla New Member
    Has been tried n true I’ve heard
    That’s a good idea
    I 2nd noco…have their jump starter n the genius 10 I believe…I don’t keep it on board but hook it up like once a week to keep things freshish
    Side note: 27f x2 power agm n also use a voltage booster…
    your battery selection may have sway in what you need???
  5. Mar 12, 2025 at 6:31 AM
    Buckaroo
    Buckaroo New Member
    2005 Ltd T4R 4WD V6
    Full SOC Battery voltage on a standard flooded battery is 12.6V. I think the one that drops to 12.7V is doing it's job correctly. The other one is charging continuously.
  6. Mar 15, 2025 at 10:09 AM
    johnf4x4
    Here is what I found:
    For maintaining a 12-volt battery, a good voltage range for a battery maintainer is typically between 13.1 to 13.8 volts.
    Here's a more detailed breakdown:
    • Float/Maintenance Voltage:
      A battery maintainer should ideally keep the battery at a "float" or "maintenance" voltage, which is usually around 13.1 to 13.8 volts.
    So, the one which runs 13.4v-13.55v is the correct one.
  7. Mar 15, 2025 at 11:03 AM
    Ripper238
    Ripper238 New Member
    2019 TRD OR
    Sounds like the 1st one is for AGM batteries and the second is for a regular battery.
    So the question is what kind of battery do you have? And what model chargers?
  8. Mar 15, 2025 at 12:33 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    Get a motorcycle trickle charger that works for AGM, standard, lithium, deep cycle and youre covered.
