Where to lift from to separate the upper ball joint
Discussion in '5th Gen 4Runners (2010-2024)' started by Ctreg, Jan 14, 2024.
  1. Jan 14, 2024 at 6:49 AM
    Ctreg
    Ctreg [OP] New Member
    Lca or frame?
  2. Jan 14, 2024 at 7:02 AM
    2020 4Runner
    2020 4Runner New Member
    Fl
    If you are trying to separate the upper ball joint from the spindle, don't jack it up to do it. Leave the nut on a few turns and hit it a few times with a small sledge hammer. A 10lb should work. Hit the side of the spindle area where the ball joint bolt goes through.
    djwantke likes this.
  3. Jan 14, 2024 at 7:25 AM
    Ctreg
    Ok sounds good. I was going to take off the tire. So I guess if I jacked from the lca it would simulate the tire being on the ground. Gotta put a new boot on the upper joint is all.
  4. Jan 14, 2024 at 10:16 AM
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
    2023 Supercharged 4Runner TRD
    Don't 4Runners just balance on three wheels ;)
  5. Jan 14, 2024 at 10:20 AM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    Watching Thread
    Thanks OP
    I'm slowly gathering the balls to install SPC new and improved Sealed balljoint replacement kit
  6. Jan 14, 2024 at 1:07 PM
    Ctreg
    I did it lol was nervous too never done suspension stuff before. I figure if I'm going to run my rig off road I best learn to fix suspension things. Had to wack it with the hammer pretty hard a few times then it came right off. The metal rretainer ring that came with the boot was garbage so I zip tied it seems pretty damn solid now. The only trouble was the ball join bolt (stud) twists when reinstalling the castle nut. I just held it in place with a pry bay as best I could to tighten. I think the little flange bends came from what ever I hit that wrecked the boot. TEMP_20240114_112958_HDR.jpg
    McSpazatron and djwantke like this.
  7. Jan 14, 2024 at 2:20 PM
    Is that flange part of the original boot?
    Did you end up separating it with all four tires on the ground? I took mine off to attempt to remove my shock a while back, and never would have thought to leave it on the ground. I would have been afraid of something shifting on me.
    Also, the curiosity is killing me! How did that boot get trail damage all the way up there? Was it a tree branch? We need stories man! :D:boink:
  8. Jan 14, 2024 at 2:49 PM
    Ctreg
    No idea how it got damaged prolly in some deep mud with debris in it maybe a rock flew up. The flange thing is attached to the ball joint as far as I could tell. I don't think it's going to cause any problems being slightly bent it might be meant to hold the grease in somewhat. I jacked it up from the lca and it went back togather pretty easily and I tightened the bolt and put in a new cotter pin. Good as new lol.
  9. Jan 14, 2024 at 3:24 PM
    Hmm, interesting. I don’t have experience with these boots, but it almost looks like it was originally part of the old boot. Or at least meant to be interface with it.
    Possibly pressed into place by the spindle when it gets torqued?
    Did you use a new OE boot? Any possibility it also had a flange like this inside of it?
  10. Jan 14, 2024 at 3:43 PM
    Ctreg
    The new boot didn't have any metal parts so I just put the new one over that metal part. The ball joint itself at 43k miles looked and felt almost new.
    McSpazatron likes this.
  11. Jan 14, 2024 at 4:45 PM
    @2020 4Runner
    thanks
    Ima try bj replacement install
    so ur sayin leave wheel on, and then keep which nut on a few turns, top or bottom nut?
  12. Jan 14, 2024 at 6:51 PM
    2020 4Runner
    Fl
    The wheel will need to be removed. You will want to loosen the nut but leave it on a few threads so that everything doesn't come apart once the ball joint releases from the spindle. Once the nut is loosened but left on, you will want to hit the circled area. You will know once the ball joint separates. After it separates then you will be able to push the UCA down enough to finish removing the nut.
    djwantke[QUOTED] likes this.
  13. Jan 14, 2024 at 7:26 PM
    @20204Runner Big thanks brother
    Same exact deal for SPC UCA, with nut on top and grease zerk?
    I've marked up the location/direction to wack my knuckle, is this correct guys?
  14. Jan 14, 2024 at 7:48 PM
    2020 4Runner
    Fl
    The lower nut at the arrow is the one that you want to loosen but leave on. The top nut at the zerk fitting is used for alignment and holding the ball joint in the UCA.
  15. Jan 14, 2024 at 7:49 PM
    Yes that's what everybody says to do in Youtube videos. Example of how hard you may have to wail at it.
    I never had luck there. I thread the castle nut on backwards until the base of the nut is flush with the pin, then hammer on the end of the pin
  16. Jan 14, 2024 at 7:54 PM
    2020 4Runner
    Fl
    Yes, that can be done too as long as it's flush to prevent thread damage or mushrooming the stud itself.
  17. Jan 14, 2024 at 8:04 PM
    You guys rock
    Sorry for thread jacking
    Kiddos almost to bed, then it's time
  18. Jan 14, 2024 at 11:41 PM
    No hammer needed, separator tool worked
    :boom:
    2020 4Runner likes this.
  19. Jan 15, 2024 at 2:06 AM
    One SPC was done tnite, second in the morn
