Wheel Spacers
Discussion in '4th Gen 4Runners (2003-2009)' started by Ruthven13, Sep 5, 2020.
  1. Sep 5, 2020 at 6:43 PM
    Ruthven13
    Ruthven13 [OP] New Member
    2003 Limited V8
    For those of you running the Spidertrax wheel spacers what size are you using? For now (and probably forever!) I will be running the stock size 265/65R17 Fallen AT3W tires which I absolutely love! I just thing the 1.25" spacers would just make look a bit cooler along with the 2.5" front leveling kit. I have a 3" difference front to rear so it should be no problem. Also have the factory RAS which I like. Out of curiosity (again!) Is it possible to get any extra lift, <2", out of that setup in case I decide to shake things up in the distant future?
  2. Sep 9, 2020 at 2:44 PM
    FJredux
    FJredux New Member
    Philippe
    San Diego, CA
    2020 4Runner Venture
    1.25" wheel spacers, 2" lift, Raceline wheels, BFG AT 285/75R17
    I just put 1.25" spacers on, with a 2 inch dealer lift. The tires rub! I am running BFG AT 285/75R17. I hope my dremel and some careful trimming will solve the issue.
  3. Sep 9, 2020 at 2:52 PM
    Jynarik
    Jynarik I like boobies
    Austin Texas
    2019 trd pro voodoo
    I have spider 1.25
  4. Sep 10, 2020 at 6:40 AM
    FJredux
    FJredux New Member
    Philippe
    San Diego, CA
    Did your tires rub? What lift do you have?
  5. Sep 10, 2020 at 6:43 AM
    Jynarik
    Austin Texas
    2019 trd pro voodoo
    yes, just use some heat and push the front plastic back and some minor trimming. You may still rub on the body at full turn, so I’m having to do a body mount chop (plasma cutter here we come)
    Londonrain likes this.
  6. Oct 2, 2020 at 9:23 PM
    Londonrain
    Londonrain Trigger
    Heather
    Rancho Cucamonga, CA
    2004 4th Gen 4 Runner
    Demello Bumper Original Version Demello Rock Sliders (Not produced anymore) Baja Designs Fog lights Baja Designs Ditch lights KC lights turn signals Onboard ARB Compressor Rough Country-Black Series Cree 30" Light bar with DRL Rago Fabrication mounting hardware CB/Ham Radio with PA system Big Bad Max air horn Spec D headlights Runner lights on sides of bumper 3 light set up center grill JBA upper control arms Icon Stage 2 lift kit (with icon socks) front and back Body Mount Chop (BMC) Fender Liner
    We have 1.25 with a 2inch lift. We took it to a local place and got the body chop mod, trimmed the fenders back a good bit on the inside. We hammered the bump back and cut that down as well. The only time it rubs is when it’s a extreme turn or loaded down with gear and 3+ people. Otherwise no rub even when off-roading
    We do notice though we might need to do the back because when we take it to get washed and they put it in the rails at the hand wash place it acts wonky because the front tires sit out further lol
  7. Nov 23, 2020 at 1:48 PM
    mtnbiker67
    mtnbiker67 New Member
    Scott
    2020 TRD
    I have a 3" lift, run 285/70/17's and I get rub on driver side mostly on cab. Hesitant to do a body chop on a new vehicle. Dealer put spacers on I discovered. Going to remove them to help with the rub.
    I'm guessing that should help?
