Wheel Spacers decision!!!
Discussion in '5th Gen 4Runners (2010-2024)' started by stunner_4runner, Feb 5, 2021.
  1. Feb 5, 2021 at 4:13 PM
    stunner_4runner
    stunner_4runner [OP] New Member
    Raymond
    2020 4Runner SR5 4WD
    Radflo Stage 3 Lift Kit- 2.5 Extended Front & Rear RR Adjustable Coilovers Total Chaos Upper Arms ARB rear medium springs 3” Aiden James Switchback Fog Bezel Lights 4Runner Lifestyle Amber Raptor Grill Lights Trail Standard Offroad Satin/Matte Black TSO Pro Grille with 4Runner Letters Baja Designs WC Amber Fog Lights Baja Designs XL Sport Amber Ditch Lights with Cali Raised Ditch Light Brackets 2 Baja Designs LP6 Amber Behind the grille lights 2 SNS Designs 5" Amber Behind the grille lights N-FAB behind the grill lighting mount Pedal commander Jet Performance Mass Flo Air Sensor 315/70/17 Cooper STT Pro Fuel Rims Custom Magnaflow exhaust with Series 50 Flowmaster Muffler Alpharex Nova Midnight Black Headlights AFE Momentum GT Dry Filter CAI BantamX Touchscreen for Universal with sPOD Alpharex PRO-Series LED Tail Lights Jet Black Mid-Atlantic Off-Roading Full Length Roof Rack Outgear Solutions Low Key Front Bumper 4WDKING 30’ LED Light Bar for the Bumper RSG Front Skid Plate
    Hey Everyone,
    Looking into getting some Front and Rear wheel spacers for the Runner. I was at first thinking 1.25 Spidertrax, but now like either the 1.5 or 1.75 Bora’s. I am running 285/70/17 with 17’ Fuel Krank rims. Suspension is Radflo 2.5 EXT Front and rear COs with Remote Resi’s Fully Adjustable, Total Chaos UCAs, and ARB 3’ Rear springs.
    Do any of you currently have 1.5 or 1.75 wheel spacers and if so, can you please post pictures of your Runner and guide me towards making the correct decision?? Thanks everyone.
  2. Feb 5, 2021 at 4:32 PM
    Jynarik
    Jynarik I like boobies
    Austin Texas
    2019 trd pro voodoo
    What offset do the fuel wheels have?
    these are 1.25 spider
  3. Feb 5, 2021 at 4:43 PM
    Mtbpsych
    Mtbpsych New Member
    Suspension has nothing to do with installing spacers..just saying lol
  4. Feb 5, 2021 at 5:14 PM
    stunner_4runner
    Raymond
    Good to know thanks Mtbpsych!! Jynarik, nice looking Runner. Not too sure of the offset, I bought the Runner brand new from the dealer with the rims and tires already on. I am sure I can figure it out though. Thanks for posting the pic.
  5. Feb 5, 2021 at 5:15 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    What are the spacers for? Are you just trying to get more poke? If your wheels already have a good offset for your setup, adding spacers is only going to hurt it.
    stunner_4runner[OP] likes this.
  6. Feb 5, 2021 at 5:29 PM
    stunner_4runner
    Raymond
    Just for a more aggressive look. See lots of Runners on here with the 1.25 Spidertrax’s and love the look. Saw a few with 1.5 Bora’s and looked great too!!
  7. Feb 5, 2021 at 5:43 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    I gotcha. Yeah man to each their own but my personal opinion is to only use spacers to run stock or stock offset wheels to run a bigger tire and not rub on the UCA.
    If you're not rubbing on the UCA or anywhere else, I'd be hesitant to run spacers as they will likely make you rub.
    Again it's your rig so if you want spacer than rock on, just figured I'd throw my two pennies in and be a nay sayer haha.
  8. Feb 5, 2021 at 5:49 PM
    mtnbiker67
    mtnbiker67 New Member
    Scott
    2020 TRD
    I took them off. Dealer had installed them with TRD rims. Looks great and all but even with lift and UCA's, it rubbed really bad on body mount. Don't want to chop the body mount. I want function over looks.
  9. Feb 5, 2021 at 5:50 PM
    NABeast
    NABeast New Member
    Paul
    2016 QS Pro
    I would only run front and rear spacers with stock wheels. Usually the wheels have enough offset to fit good with some poke. But after lifting an IFS toyota the front track width does get narrower, i run bora 3/4” on the front only with my scs 8” wide wheels. Matches the rear about perfect.
  10. Feb 5, 2021 at 6:16 PM
    NABeast
    NABeast New Member
    Paul
    2016 QS Pro
    What size tires? And OEM wheels without spacers? You should have the alignment done and max out the caster. Basically set the rear cam on the front lower control arm all the way towards the outside and and adjust the camber with the front cam bolt, that should give you more clearance. And body mount chop doesn’t hurt function.
  11. Feb 5, 2021 at 6:35 PM
    mtnbiker67
    Scott
    2020 TRD
    285/70/17 KO2's on Stock TRD rims. I'm using Dobinsons UCA's. Without spacers I get zero rub. Wheels great. Just doesn't have an aggressive stance.
    Ya, I know BMC isn't a big thing. I'm just having a hard time wrapping my head around cutting my new truck. Local shop here does amazing work on BMC's. Looks factory.
  12. Feb 5, 2021 at 7:08 PM
    NABeast
    NABeast New Member
    Paul
    2016 QS Pro
    Right on. With spacers on the front it may rub, i would try to maximize the front caster to help clear. But then there’s the front fender liner clearance.
  13. Feb 5, 2021 at 7:13 PM
    stunner_4runner
    Raymond
    Thanks so much everyone. You have been a lot of help!! I appreciate it!
  14. Feb 6, 2021 at 8:42 AM
    DallasTRDPro
    DallasTRDPro New Member
    Dallas
    2021 Honda CRV...UGH!
    Spacers on I rubbed bad with stock wheels. With them off, I have no rubbing.
    mtnbiker67 likes this.
  15. Feb 6, 2021 at 10:02 AM
    NABeast
    NABeast New Member
    Paul
    2016 QS Pro
    I would do what you feel comfortable doing. I don’t mind a little trimming and cutting. I was just trying to offer suggestions.
  16. Feb 7, 2021 at 6:25 AM
    I have 1.5” wheel spacers on the front with stock Off-road wheels. My caster is set at 3.6 degrees and I don’t rub on the body mount with 285s. I needed to trim the front fender flare and move the fender liner forward to eliminate rubbing.
    However, I think I’ve pushed my offset to the limit with this set up. If your aftermarket wheels already have offset, you very well could be doing a body mount chop and the fender liner mod. Not a big deal though.
    SlvrSlug and NABeast like this.
