wheel spacer bore concern
Discussion in 'Wheels & Tires' started by matterrooney, Apr 21, 2025.
  1. Apr 21, 2025 at 6:34 PM
    matterrooney
    matterrooney [OP] New Member
    Mattie
    99 4runner
    I just got my spacers and went to install. Amazon confirmed 106mm bore was proper size for my vehicle. However, I went to install and the fit the hub, but right against the inner face of the hub, the ID steps up for about 1/4 inch to 108mm, preventing the spacer from seating against the face of the hub. The step leaves a gap between spacer and hub face. Is this normal ??
    Sorry to throw in a most likely beat to death topic, but I can't find the answer any where else
  2. Apr 21, 2025 at 7:28 PM
    Definitely should sit flat. Look into Bora brand spacers. They were relatively inexpensive and worked well when I had them.
  3. Apr 22, 2025 at 6:09 AM
    matterrooney
    Mattie
    99 4runner
    Thanks for the reply Whippersnapper02...
    As a mechanically inclined fellah, I was 100% thinking the same. I will look into your suggestion.
  4. Apr 22, 2025 at 6:11 AM
    Bora, not bra but feel free to look under a bra. :rofl:
  5. Apr 22, 2025 at 2:12 PM
    send back and get spacers from a reputable source not through Amazon
  6. Apr 27, 2025 at 2:00 PM
    Cajunchuck
    Cajunchuck New Member
    Arkansas, USA
    2023 TRD ORP
    BFG KO2, stock size RCI 20 degree sliders RCI engine/trans skids
    I tried the cheap Amazon spacers. KSP I think or something like that. Tolerated them almost a month then returned them as I couldn't take the shakes from 55-62 MPH anymore. Lesson learned. If I need more "poke" I'll get it with the wheels not spacers.
  7. Apr 27, 2025 at 2:03 PM
    Cajunchuck
    Arkansas, USA
    2023 TRD ORP
    Plus mine caused a pretty gnarly rub at full lock in reverse.
  8. Apr 27, 2025 at 3:15 PM
    This is the type of job where your goal shouldn’t be to save money. As others have mentioned, go with a good/known brand.
