Wheel options for KO2s? Don't want to go past 8 wide.
Discussion in '5th Gen 4Runners (2010-2024)' started by Scott/SandyUt, Dec 22, 2022.
  1. Dec 22, 2022 at 4:37 PM
    Scott/SandyUt
    Scott/SandyUt [OP] New Member
    2012 4runner Limited
    Stock /20 inch rims
    2012 Limited, currently running 275/55/20 on OE spoke wheels, ya 7in wide. They have 59,600 miles with 8/32-9/32 remaining. No issues...rubbing, irregular wear patterns.
    Have been excellent. Very good looking over OE. I know 7in is narrow, and not recommended. But the above disproves all of that.
    I want to stay with the KO'2s and this size. What are the proven wheel size options that have been run out here. Don't really want to go past 8 wide. I know this subject has been beat to death but I know someone can give me a great recommendation. Just a soon stay with the 7 in. stock 20in rim, but want options. Thx!
  2. Dec 22, 2022 at 9:37 PM
    What happens running 12.5 wide tires on narrow 7in wheels...
  3. Dec 23, 2022 at 7:00 AM
    To much air pressure.
  4. Dec 23, 2022 at 7:17 AM
    Yep, I watched that video recently, he said he runs the new tires at 46 psi. Way too high.
    And personally I think a 12.50 is too wide of a tire for these anyway, but that's just me.
    kmeeg likes this.
  5. Dec 23, 2022 at 7:27 AM
    Where did 12.5" width come from? 275/55-20 tires are 10.83" wide...or is that just to say people have been running even wider tires on a 7" wheel w/out issue?
  6. Dec 23, 2022 at 7:28 AM
    :D
  7. Dec 23, 2022 at 7:30 AM
    This is my Runner with Falken 285/70/17 MT’s with about 30,000 miles on them, i run 44 psi. in the front and 34 psi. in the rear. Unless i load it down, then i adjust the air.
    nimby, kmeeg and Slopemaster like this.
  8. Dec 23, 2022 at 8:58 AM
    Gstick
    Gstick New Member
    19' TRD OFF ROAD
    This is correct. When the center of the tread wears out 1st, its too much air pressure.
    When the outsides of the tread (both inner & outer) wear out 1st, its too little air pressure.
    Nano909 and SlvrSlug[QUOTED] like this.
  9. Dec 23, 2022 at 2:54 PM
    Fortuner
    Fortuner New Member
    CA
    2021 4Runner TRD Off Road Premium w/KDSS
    I’m running 285/70r17 on the OEM TRD pro wheels as well…have aired down to as low as 15-18 PSI on the trail with no issues. Normal street driving I run them around 36-38 PSI, or more if I’m loaded up. Rotating every 5K miles and they’re wearing perfectly.
    I personally know of someone running a 295/70r17 (11.6” wide) on the OEM TRD Sema wheel without issue as well.
    I wouldn’t sweat the width as much, but at the end of the day do what you’re comfortable with since you’ll be the one driving the truck!
    glwood54, SlvrSlug and Nano909 like this.
  10. Dec 23, 2022 at 4:41 PM
    If you read the last part of my post, you'll see I was just trying to clarify what you were saying. Sorry if you were insulted by a legitimate question, and no need for a condescending attitude.
    R1200Jedi and 08TXRunner like this.
