Wheel bore size question?
Discussion in '5th Gen Builds (2010-2024)' started by ToyotaRDie, Dec 26, 2021.
  1. Dec 26, 2021 at 9:14 AM
    ToyotaRDie
    ToyotaRDie [OP] New Member
    So I am looking to get some wheels but I’m confused about The bore size. I am looking at the black rhino stadium wheels 17×8 1/2 inches. In the website when I insert my vehicle type, it says that it fits. But the bore size for a 2015 4runner is 106 mm and these rims are 112 mm. My question is does it really fit properly? Is it even recommend it? I don’t see how he can, being that it’s bigger than the bore size of the vehicle yet the website says it does. Can someone make sense of this? Thank you
  2. Dec 26, 2021 at 9:31 AM
    Brawwp
    Brawwp New Member
    Jason
    Harker heights, TX
    2022 TRD Pro white
    Buy hub centric rings. I was looking into this a while ago for a different vehicle. I was told they do that to fit more vehicles, and to just buy metal hub centric rings for your bore size. They can be found online.
    Thatbassguy and ToyotaRDie[OP] like this.
  3. Dec 26, 2021 at 1:43 PM
    As @Brawwp mentioned, there are adapters available.
    I have Stadiums, and no issues with balancing or wobble. I did lose one of the adapters, but it hasn't caused any trouble. I assume it fell out during a rotation and I just didn't notice.
    There aren't many options for wheels the come in the proper bore, so I just got what I liked. I've been on aftermarket wheels for about 65K miles and have no complaints.
    Here's a picture from the day I installed mine:
    SR5 Limited and Dabigono like this.
  4. Dec 26, 2021 at 9:25 PM
    ToyotaRDie
    Which size metal hub centric rings did you use, being that I am getting the same 112mm wheels that you have?
  5. Dec 26, 2021 at 9:32 PM
    To be honest, I don't know. They were provided by the off-road shop I bought them from.
    I will say that these wheels and tires have always been perfectly smooth, except when I had gobs of mud lodged in the wheels. :D
    ToyotaRDie[QUOTED][OP] and 7385 like this.
  6. Jan 7, 2022 at 7:53 PM
    ICEMAN600
    ICEMAN600 New Member
    What offset did you choose for that stadblack rhino? And what tire size are you running?
  7. Jan 7, 2022 at 8:37 PM
    I have the 0 offset version. Those tires are 295/70/17.
