Wheel bearing help
Discussion in '3rd Gen 4Runners (1996-2002)' started by Yoda_outcast, Dec 23, 2021.
  1. Dec 23, 2021 at 2:16 PM
    Yoda_outcast
    Yoda_outcast [OP] New Member
    Danny
    2000 2wd 4runner
    Hello.
    I have a 2000 2wd limited 4runner I recently lost a front wheel bearing witch was fun to replace. Apon reassembling I realized there was a crush nut that pre loads the hub to the bearing I have searched every for what the torque spec is for it an I have came up with nothing. Does anyone have an idea what I need to torque it to ?
  2. Dec 23, 2021 at 9:39 PM
    Tim does a very detailed video of this job.
    https://www.youtube.com/watch?v=Dj-2IzO9RFk
    I have had the steering knuckle off my car but I can't picture in my mind what you are referring to. Can you find a picture on the internet?
  3. Dec 23, 2021 at 9:45 PM
    The Axle nut is supposed to be torqued to 174 ft-lbs.
    That's the only nut I know of that would affect the wheel bearing.
  4. Dec 26, 2021 at 12:22 PM
    Timmy!
    Timmy! New Member
    Tim
    He has a 2wd drive so no CV axle nut. His bearing is pre-loaded using a lock nut on the back of the bearing just like a rig with manual hubs would. In the video below, the FSM manual calls for a spec of 205 ft-lbs for that hub shaft locknut.
    https://www.youtube.com/embed/TZ2sOfVrnhU
  5. Dec 27, 2021 at 6:39 PM
    Oh, forgot there are still 2WD ones out there :)
