Wheel and Tire Setups
Discussion in 'Wheels & Tires' started by Backslider, Aug 25, 2017.
  1. Aug 25, 2017 at 9:22 PM
    Backslider
    Backslider [OP] Gun Nerd
    Tooele, Utah
    2017 T4r SR5 Premium ************ 2016 Tundra TRDor
    Spent all my gun money. =(
    I don't think these forums have a wheel and tire setup thread. This must be remedied.
    If you're willing to contribute, post a pic of your wheels and tires. List your suspension setup, wheel width and offset, and tire size, and any other relevant (or otherwise) information you'd like to provide.
    This has been very helpful for me with other vehicles in deciding on wheels, tires, and suspension.
    This is a 2" Bilstein 5100 on FBG adjustable coilover level, 5100s in the rear @ stock heigh, Black Rhino Sidewinder 17x9 +12. Cooper AT3 265/70r17.
    I am considering getting 275/70r17 BFG K02s tomorrow. I run K02s on my Tundra and I really like them - but my wife primarily drives the 4r and I'm wondering how she'll feel about them..
    Anyway, what do you guys have? Anyone out there with K02s in 275/70r17 on a 5th gen? I'd love to see all your setups!
  2. Aug 25, 2017 at 9:57 PM
    DrewMan
    DrewMan New Member
    2016 Magnetic Grey 4Runner Trail Premium
    Bilstein 5100 Series Shocks, Daystar 1.5" Rear Coil Spacer (Mid Left), Level 8 Tracker Pros 17x9, 275/70/R17 B.F. Goodrich TKO's, N-Fab Nerf Steps
    2016 Trail Premium w/KDSS, Magnetic Grey, Bilstein 5100 Series Shocks w/ Daystar 1.5" Rear Spacers, 17"x9" Level 8 Tracker Pro 6's, LT275 /70 R17 B.F. GOODRICH ALL TERRAIN T/A KO2's
    I kept OEM coils for now but adjusted front to keep factory vehicle rake. It's approximately a little over 2" lift and was very affordable.
  3. Aug 26, 2017 at 12:55 PM
    PVT Pablo
    PVT Pablo Ultra Junior Member
    Paul
    Chesapeake, VA
    2016 4Runner TRD Pro
    2016 4Runner TRD Pro with OEM TRD Shocks with Toytec's 2" spacer lift for TRD Pro Suspension. Falken Wildpeak AT3W in 285/70/17 SL with SCS Ray10's in 17".
  4. Aug 26, 2017 at 3:35 PM
    Backslider
    Tooele, Utah
    I recall you saying in another thread that you had to cut your mudflaps and/or fender liners to run 285s on a 2" lift - do you get any rubbing at all now?
    I passed on the K02s today, have some Wildpeaks on order in 285/70r17. I would love to hear that everything is going to be ok.
    Love your truck.. best color.
    PVT Pablo likes this.
  5. Aug 26, 2017 at 4:11 PM
    PVT Pablo
    Paul
    Chesapeake, VA
    Yes I did cut the mudflaps. There is a weird square protrusion that took about 5 minutes with a box cutter to remove. I still rub the cab mount at full steering lock in reverse. It's a very slight rub that I plan on fixing with a set of JBA upper control arms.
  6. Aug 26, 2017 at 4:14 PM
    Backslider
    Tooele, Utah
    So is it safe to assume that it rubs on the CM because your caster is too negative?
  7. Aug 26, 2017 at 5:34 PM
    PVT Pablo
    Paul
    Chesapeake, VA
    Absolutely. I had the same issue on my 2011 Tacoma. I know the rule of thumb is 3" and above requires aftermarket UCA's, but in my experience anything above 2" could surely use UCA's with more built in caster. Additionally, I feel like even with stock height suspension, the Tacomas, 4Runners and FJ's have too much bump steer and road wander which again is solved with aftermarket UCA's.
    Backslider [OP] likes this.
  8. Aug 26, 2017 at 5:53 PM
    Backslider
    Tooele, Utah
    And the list continues to grow..
    My Tundra is feeling neglected.
  9. Aug 26, 2017 at 6:43 PM
    Buggs
    Buggs New Member
    2015 Limited
    3" OME BP-51 with medium rear coils and TC UCA's. FN Six Shooter wheels 17"x8" 0mm offset. BFG KM2's 285/70R17. Just put them on so haven't had a chance to see if there is any rubbing. Also removed the rocker trim for extra clearance. 20170826_180527.jpg20170826_172846.jpg
  10. Aug 27, 2017 at 8:56 AM
    Bob
    Bob Member Staff Member
    Bob
    Stickied!
    jester243 and Backslider [OP] like this.
  11. Aug 28, 2017 at 9:44 AM
    brochacho
    brochacho New Member
    2018 Sequoia TRD Sport
    I think there is already a lift thread so I'll just stick to basic lift info with tire and wheel specs here...
    SCS Stealth 6 (17x8.5, 4.30"BS, -10mm offest)
    285/70/17 Nitto Ridge Grappler (load range C)
    2.5" front/ 1.5" rear lift
    Trimmed some plastic
    Kyblack76, Bullminner, PJAC and 4 others like this.
  12. Aug 28, 2017 at 2:33 PM
    Backslider
    Tooele, Utah
    I found a great deal on a new set of K02s in 275/70r17. Picked them up and got them mounted and balanced today. HUGE improvement.
  13. Aug 28, 2017 at 7:52 PM
    A list of wheels that don't fit over the 4 runner brakes would also be helpful. I don't think that any of the 16" Toyota wheels will fit. Does anyone know if any of the 17" Tacoma wheels will fit?
  14. Aug 29, 2017 at 9:36 AM
    brochacho
    17" Tacoma wheels should fit just fine. My only concern would be the back spacing and offset. What Tacoma wheels are you specifically looking at?
  15. Aug 29, 2017 at 5:40 PM
    Backslider
    Tooele, Utah
    That would be great - I don't know if a comprehensive list exists, but by contributing to this thread we can gather the data and share experiences, save future owners a whole lot of time and headache. =]
  16. Aug 29, 2017 at 6:38 PM
    I've heard that the 3rd gen 17" Tacoma sport wheels won't fit over the 4runner front brake calipers. I haven't tried this myself so I'm not positive that this is correct.
  17. Aug 29, 2017 at 6:56 PM
    4RN4FUN
    4RN4FUN New Member
    The Land, Ohio
    2016 White SR5 Premium
    17x9 wheels and 285/70/17 tires
    Backslider [OP], DrewMan and BigSky1 like this.
  18. Aug 30, 2017 at 8:55 AM
    JBTRD
    JBTRD Hunting, Fishing, Lovin' Everyday
    Jeremy
    Lox, FL
    2016 trail
    16 Trail with TRD Pro wheels and suspension. I added a 3 in readylift and run 285/7017 Toyo Open Country, i have put a hard 10k and have very little tread wear.
    *some pics are old and are missing some mods that contribute to set up.
  19. Sep 19, 2017 at 6:10 PM
    allthescottsweretaken
    allthescottsweretaken New Member
    Scott
    16 Trail
    Just ordered some SCS Ray10s. Wondering if anyone knows anything about decent snow tires? I can't find anything larger than a 265/70r17 as far as snow tires go, but I figure those will look a little silly with a 2" lift. I was planning on keeping the stock rims for a tall and skinny snow tire. Any recommendations?
  20. Sep 19, 2017 at 6:13 PM
    Backslider
    Tooele, Utah
    I have 2" up front and they did look a little small. I'm pretty happy with the 275/70r17s I picked up. I think a good AT tires is totally adequate instead of a dedicated snow tire,but that's just my opinion.
    Post pics when you get your wheels - I love all the SCS stuff I've seen!
    mcharfauros likes this.
  21. Sep 19, 2017 at 7:17 PM
    Scott
    16 Trail
    JBTRD good looking rig. Where did you pick up those orange running lights in the grill? I've been searching for those.
  22. Sep 20, 2017 at 5:39 AM
    JBTRD
    Jeremy
    Lox, FL
    2016 trail
    Barcelona Trail and Wootang like this.
  23. Sep 20, 2017 at 8:40 AM
    SeanDub
    SeanDub New Member
    Sean
    2017 Tacoma DCLB OR, 2017 T4R SR5 Premium
    Icons and 33s
    Method NVs 17x8.5 0 offset and 285/70r17 Goodyear Duratracs, Icon Stage 1 Suspension
  24. Sep 20, 2017 at 8:56 AM
    Backslider
    Tooele, Utah
    Gola Rack?
  25. Sep 20, 2017 at 8:59 AM
    SeanDub
    SeanDub New Member
    Sean
    Icons and 33s
    I actually have no idea, I transferred it from her old 4runner to her new one. I doubt she remembers, but I'll ask.
  26. Sep 29, 2017 at 11:46 AM
    Backslider
    Tooele, Utah
    Added 1.25" Spidertrax today which essentially makes my offset -19.75. I get some rubbing on the front bumper at wheel lock in reverse, and when turning while moving forward and the springs compress.
    Considering a CMC, or possibly just changing my wheel/tire setup to get me closer to -12.
  27. Oct 1, 2017 at 10:21 AM
    Backslider
    Tooele, Utah
    With wheel spacers. I really love the way it looks now.
    Kyblack76, MellyMel and Erdos60 like this.
  28. Oct 9, 2017 at 11:32 AM
    Wingjammer
    Wingjammer New Member
    Jon
    2004 SR5 4WD- V6 Blackout
    Blackout HL, TL. LED throughout. Plasti-dip emblems and some trip pieces Looking for lift, level, tires, bull bar...
    Anyone know how big you can go on 4th gen stock wheels. I have a 2004 SR5 with 17" wheels. Has 265's now. Was looking to jump up after lift/level, but didn't know how wide the wheels will carry. Hoping to go up to a 285 so the ratio doesn't need to be over 70 for height I want.
  29. Dec 10, 2017 at 9:05 PM
    Backslider
    Tooele, Utah
    Add your wheel, tire, and suspension setups!
  30. Dec 31, 2017 at 5:21 PM
    Erdos60
    Erdos60 Putting the "rad" in Colorado since 1970.
    Brian
    Fort Collins/Loveland Colorado
    2018 Black SR5 Premium
    None
    Anymore info on specific wheel/tire combo?
    Did it require a lift/suspension change?
