Wheel and thrust angle issue
Discussion in '5th Gen 4Runners (2010-2024)' started by PLD, Apr 11, 2022.
  1. Apr 11, 2022 at 8:46 PM
    PLD
    PLD [OP] New Member
    PL
    2015 4Runner SR5 P
    Lift kit
    Hello. I have a 2015 SR5. Have an issue with the thrust and the front right wheel. (Not sure if they are related.)
    Have a rumbling from the front wheel. Dealership says it can be bearing or CV.
    The thrust issue was first at -00.18. With various alignments, the trust varies from -00.03 to -00.10. The dealership says the preferred thrust is 00.00.
    My questions:
    Has anyone dealt with the front wheel rumbling? Was it the bearing or CV?
    Is it common to have the thrust angle off on 4Runners?
    Thanks
  2. Apr 11, 2022 at 10:00 PM
    Is thrust angle referring to CV angle?
    I would think it would take a pretty dramatic lift to get the CV joint(s) to groan/bind. Front wheel bearing are a common wear item on 4Runners and Tacoma’s.
    My 97’ Tacoma had a bad drivers side wheel bearing. I could feel it before I could hear it.
  3. Apr 11, 2022 at 10:07 PM
    PLD
    PLD [OP] New Member
    PL
    2015 4Runner SR5 P
    Lift kit
    Hi. Thanks. Then it might be bearing.
    It’s new to me but I’m told the thrust angle is the rear axle position relative to the front wheels. A zero thrust means it’s parallel. Any other number means it’s off. When it’s off the vehicle “dog legs” meaning it goes down the road on a slant. I’m just repeating what I’ve been told.
  4. Apr 12, 2022 at 4:31 AM
    Agent_Outside
    Built 2011 T4R Limited
    Thrust angle *should* always be zero. However the rear doesn’t have any factory adjustments to be able to set it. It is what it is unless you get adjustable rear links. It won’t affect the wheel bearing or CV able.
    Generally speaking CV will noise under load and they tend to have more of clicking type noise, especially while turning. Wheel bearings you can typically isolate bye swerving. If it’s a rotation noise that gets loaded with speed you can mildly swerve left to right. Wheel bearing noise almost always changes tone as the vehicle leans harder to one side or the other.
  5. Apr 12, 2022 at 6:34 AM
    PLD
    PLD [OP] New Member
    PL
    2015 4Runner SR5 P
    Lift kit
    Thanks. I just looked up adjustable rear links. Total Chaos set. Maybe that’s the solution.
  6. Apr 12, 2022 at 4:56 PM
    j cat
    j cat New Member
    massachusetts
    spacer lift front 1inch
    the front pass side wheel bearing is looking it up ... lift the tire rotate the tire see if its a movement pull out and in ...
    dealership says is a lot of bearing wear ...
    pass side does have a lot of banging pot holes ..........bearing wear.. over 130K miles
  7. Nov 27, 2023 at 6:47 AM
    AndyNumnums
    AndyNumnums New Member
    Andrew
    2021 4runner
    Did you end up getting this resolved? Did adjustable rear links work?
