Wheel alignment then warning light
Discussion in 'Suspension' started by urban_overlander, Jan 29, 2023.
  1. Jan 29, 2023 at 8:42 PM
    urban_overlander
    urban_overlander [OP] New Member
    Jesus
    5th gen Toyota 4Runner sr5
    None
    Last year I got a wheel on my 2011 Toyota 4Runner sr5 after the wheel alignment was done an warning code 1290 showed up and a warning indicator is steady on I want to get rid of this warning light can someone please give me advice on how to remove this problem or get it fix there’s a photo below of the light
  2. Jan 29, 2023 at 9:22 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    Steering angle position error. Trip to dealership for a reset/update will correct issue.
    Your alignment must of been crazy off to cause this error.
  3. Jan 29, 2023 at 11:31 PM
    urban_overlander
    Jesus
    None
    I’m trying to avoid the dealer ship there crazy expensive give or take how much a trip to Toyota for that little problem
  4. Jan 30, 2023 at 12:03 AM
    LuLu
    LuLu New Member
    Utopia
    2022 TRD Sport
    Take it back to the alignment shop for correction
  5. Jan 30, 2023 at 8:59 AM
    urban_overlander
    Jesus
    None
    I did brother and I told him what’s going on he said every time he’s gives 5th gen 4Runners and even the Lexus suvs they get the indication light
  6. Mar 10, 2024 at 5:00 PM
    urban_overlander
    Jesus
    None
    Any ideas what’s going on I still have that problem
  7. Mar 11, 2024 at 4:45 AM
    TrailSpecial22 New Member
    PA
    that BS! Also is that a traction control light appearing. Did the damage the ABS speed sensor wire upfront somewhere? I have a 2011 & 2022 and never had that light come on after several alighments.
  8. Mar 17, 2024 at 9:18 AM
    PA
    Any updates?
  9. Mar 17, 2024 at 10:06 AM
    3JOH22A Toyota Gigolo
    Is your steering wheel centered when you drive straight? If so, do you get the same number of turns to full lock turning left as you do turning right? If you do, then just disconnect the battery negative cable, wait a few minutes, then re-connect it to reset the zero point stored in the stability control ECU memory.
    The first time you start the engine after battery disconnection, the engine may stumble and die. Restart and everything should be back to normal. Depending on how far north you are, you'll also need to re-enter your compass region number or the compass may deviate.
