What to do after 4 to 5 months in storage
Discussion in '5th Gen 4Runners (2010-2024)' started by weezol, Jan 13, 2025.
  1. Jan 13, 2025 at 2:19 AM
    weezol
    weezol [OP] New Member
    Hello everyone,
    I have a 4Runner that will be getting taken out of storage soon. It will have been sitting for about 4 months. Before being put into storage:
    -Ethanol free gas was used to fill up the tank. Fuel stabilizer was also added.
    -Engine oil and filter were changed out for new
    -Negative battery terminal was disconnected
    I was planning to replace the oil and filter again before starting it up. But I was wondering whether or not to run the engine before hand. During normal oil changes I let the engine run a bit for the oil to flow out easier.
    However, I was told with the oil sitting for 4.5 months I should just drain it and replace with new before that first start up.
    Is there any potential harm in doing it one way or the other?
    To take it even one step further: a guy I work with said to replace the oil with new, drive the car around for a day or two, and then replace the oil again. He said it would flush out whatever contaminants were in there from storage.
    This seems like overkill, but I’ve never stored a car for months and I plac on keeping this one forever.
    Thanks
  2. Jan 13, 2025 at 3:30 AM
    Since the oil was changed before storage, Check the oil to make sure it is the correct level. Run it till the oil is supposed to be changed. Changing oil before extended storage I believe is to rid the system of as much moisture as possible. My owners manual for my 4 stroke snowmobile has the oil being changed before extended storage for moisture residue in the engine. Granted a snowmobile and a 4Runner aren't mechanically close, but that is why I would do it. You're probably close when you say it's overkill when you talk about changing it before 1st startup. Put a slow charge on the battery to make sure it's charged. Putting fuel stabilizer in was probably good, been using it myself, ethanol laden fuel sucks! Good way to corrode carb parts and fuel systems. I don't see one way being any worse than the other, as far as running it.
    weezol[OP] likes this.
  3. Jan 13, 2025 at 4:36 AM
    bassist
    bassist New Member
    2023 TRD Offroad Premium
    I promise that his 4Runner will not have any carb issues!
  4. Jan 13, 2025 at 5:20 AM
    I know that, it was a reference to the corrosive nature of the ethanol laden gas. You mean the carb will be fine on my fuel injected snowmobile too?! Ha Ha
    bassist[QUOTED] likes this.
  5. Jan 13, 2025 at 5:26 AM
    Lost Woods
    Lost Woods New Member
    For the battery, you can just disconnect it. Chargers are a fire hazard that may be low, but is never zero so unless you're close by, it's best to just disconnect it and leave it in place. A new, full tank of gas should be good for at least six months so I think they'd be ok there. Just need to make sure it's full to minimize water and oxygen in the tank.
    weezol[OP] and Toy4X4[QUOTED] like this.
  6. Jan 13, 2025 at 6:05 AM
    bassist
    bassist New Member
    Yeah, I knew that you were aware that there are no carbs on the 4Runner.
    Couldn’t resist though…
    Toy4X4[QUOTED] likes this.
  7. Jan 13, 2025 at 6:06 AM
    bassist
    bassist New Member
    Owners of rare and exotic cars use trickle chargers more or less constantly.
    Just don’t buy garbage and it’s fine.
  8. Jan 13, 2025 at 8:48 AM
    Hungryhawk
    Hungryhawk New Member
    Southern CA
    2017 SR5
    I would spin the motor without allowing to start.
    Get the engine oil fully circulated before actually starting the motor. Fuel is not needed in the dry cylinders. So I would disable both fuel and spark till lube is circulated.
    alittleoff likes this.
  9. Jan 13, 2025 at 9:05 AM
    RUNNER4DAN
    Daniel
    Doesn't need any
    Ethanol gas has no detrimental affect on sealed fuel systems. Fuel injection will not allow moisture to enter the system.
    bassist likes this.
  10. Jan 13, 2025 at 10:19 AM
    Gumpus
    Gumpus New Member
    I'm no expert but I used to be a powertrain engineer. Your oil is clean. Contamination is not accumulating during storage (ask your expert friends to clarify what specific contamination they are talking about). Even if you didn't change your oil before storage there isn't anything to worry about ...have you or your friends ever heard of one real case of any issue caused by contaminated oil during storage? Are we thinking the engine rusts from the inside out? I'd like to see any evidence for any concern. The Miata forum beats this to death too. While it MIGHT be directionally helpful to spin the engine with the starter to circulate the oil before firing the engine as one poster mentioned it also MIGHT be worse since the cylinder walls rely on splash lubrication which will be best if you just start the engine.
    All you need to do is start it and drive it. If changing the oil two more times makes you happy you can be sure the sequence doesn't matter.
    If you want to pamper the snots out of your vehicle run premium fuel. It's more pure so your engine will stay cleaner. Might even make a difference in super high mileage reliability. Google it; it's not a myth.
    You're smart to use a forum to double-check your friends' advice.
    STrooper, evank, weezol[OP] and 2 others like this.
  11. Jan 13, 2025 at 3:55 PM
    Sometimes I step into it!
  12. Jan 13, 2025 at 3:55 PM
    OK, whatever you say.
  13. Jan 13, 2025 at 4:26 PM
    RUNNER4DAN
    Daniel
    Doesn't need any
    Ok, so explain to me how moisture can enter a closed fuel injection system. Don't miss it, now's your chance to enlighten us all.
    evank likes this.
  14. Jan 13, 2025 at 4:41 PM
    mac1usa
    mac1usa New Member
    You should be fine. I had one that sat stored from October-April and had stabil added, and a battery tender on. I just let it idle for about five minutes before shifting into gear each spring. My new 2024 is same way covered, stabiled, battery tender and to never see salt
  15. Jan 13, 2025 at 5:28 PM
    No need to do anything with the engine oil coming out of storage. Just drive it like usual. A modern synthetic oil isn't going to degrade just sitting in the engine for 4 months. My Tacoma is a trail toy, so it easily sits for 4 months or more during the off season. The 4Runner's engine is more ancient and a lot simpler.
    Focus your efforts on rodent prevention. Chewed wiring can total your vehicle. Set traps all around the vehicle. Discard that cosmetic plastic cover over the intake manifold to reduce available shelter for nests. Drench all the wiring harness bundles you can get to under the hood with a rodent repellent, especially under the intake manifold. Just be sure to spray on a cold engine. https://www.lowes.com/pd/TOMCAT-Rodent-14-oz-Rodent-Repellent/1000763452
    Release the parking brake and chock the wheels. Don't want the brake shoes rusting to the rotor hat.
    Shredder and weezol[QUOTED][OP] like this.
  16. Jan 14, 2025 at 3:05 AM
    The heat of excess fuel returning to the tank from the injection process in cold weather is a known contributor of moisture on partially full tanks, this process goes on in diesel and gas vehicles alike. Condensation in the tank (moisture) causes rust on metal components. A closed system, hardly. Vented, return lines, evap. purge valves, far from "closed".
  17. Jan 14, 2025 at 4:18 AM
    mac1usa
    mac1usa New Member
    I am no mechanic but I get what you’re saying about cold/moisture/condensation. For myself mine won’t be started till the earliest is April after the winter temps. As far as the OP maybe this does come to play a bit now with winter upon us.
    I can’t worry to much about this stuff. Sooner or later something gets us all. Hell my 4R will outlive me at this point.
  18. Jan 14, 2025 at 4:32 AM
    I would love to put ours away until the nice weather was upon us! Mama's daily driver though. If you want something to go wrong, it seems like it happens when it's cold out. -7 here in Wisc. this morning, it is brrrr out! Good Day Mac.
  19. Jan 14, 2025 at 5:00 AM
    mac1usa
    mac1usa New Member
    Yeah same here in MI not quite as cold but that’s coming out this weekend I see. I figure use the old Accord all winter and why introduce salt to a new ride when not needed.
    Good Lord willing someday I’ll retire and spend winters somewhere warmer and with sunshine. This stuff gets old real quick with each year I get older.
    Have a good day also buddy.
  20. Jan 14, 2025 at 7:52 AM
    joshdub
    joshdub New Member
    2020 TRD ORP
    Most of my cars sit for double that. You don't need to do anything for 5 months of storage.
    Toy4X4, weezol[OP], Rocko9999 and 2 others like this.
  21. Jan 14, 2025 at 8:32 AM
    FourBelugas
    FourBelugas New Member
    23 white ORP
    Yep. Four months doesn't really require anything especial beyond usual fluid level check. New cars on dealer lots can sit for a year or even more before they are sold with very few miles driven. All of my cars see relatively few miles now so they all get annual oil change.
    Toy4X4, weezol[OP] and Rocko9999 like this.
  22. Jan 14, 2025 at 9:46 AM
    bassist
    bassist New Member
    I bought a WRX once and traded in a pickup.
    And then gas prices surged, even by CA standards.
    I went to get my first oil change and my pickup was exactly where it had been parked after I traded it in, with cobwebs coming off the bumper.
  23. Jan 14, 2025 at 10:17 AM
    Lost Woods
    There's a difference between keeping a car up in your garage because you might want to drive it in a few weeks and putting it storage knowing you won't touch it for 5 months. A battery won't self-discharge in that time so there is zero reason to use a charger.
  24. Jan 14, 2025 at 10:17 AM
    FourBelugas
    23 white ORP
    My now 18 year old Ford was produced in late 2005 as MY 2006, I bought it in Jan 2007 as a left over model year with 6 miles on it. I suspect most of the 6 miles was from the factory yard to rail and then transport between holding lots and such, and after that it was moved occasionally on the lot when they needed to shift cars. Still runs fine today.
    A 2014 Ram pickup I bought was a similar story as I bought over a year after it was built, I still see it around as the buyer who bought it from me a few years ago lives near me.
  25. Jan 14, 2025 at 2:39 PM
    Oil gets better with age.
    3JOH22A likes this.
  26. Jan 14, 2025 at 2:44 PM
    4 - 5 months is nothing.
    Start her up and go. Some people getting all worried like it was sitting for years.
    Thatbassguy, 7Runner, 3JOH22A and 2 others like this.
  27. Jan 14, 2025 at 4:20 PM
    4Hopper
    4Hopper New Member
    24 Ice Cap 4R TRDOR Prem
    Surprised it hasn’t been mentioned yet, but since it’s been sitting, make sure your blinker fluid is topped off, and the stalk is well lubricated before you attempt to change lanes…good to go.
  28. Jan 14, 2025 at 4:26 PM
    RUNNER4DAN
    Daniel
    Doesn't need any
    Don't forget to reboot the flux capacitor.
    Toy4X4 and 4Hopper[QUOTED] like this.
  29. Jan 15, 2025 at 12:22 PM
    alittleoff
    alittleoff New Member
    Steve
    406
    '16 TP
    OP, It's good that you disconnected the negative side of the battery. Because current is being drawn down from the radio and clock.
    Post #8, @Hungryhawk, describes pulling the ignition and fuel relays/fuses to give the engine a few seconds, maybe 10-15, the let the engine rotate while the oil system pressurizes itself before the cold start up circuit at 1,000 to 1,500 rpm.
    And I think changing the oil before start up is unnecessary.
    Toy4X4 likes this.
  30. Jan 15, 2025 at 12:56 PM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    4-5 months isn't much. You took the right precautions for the fuel.
    I'd probably check the oil before startup and let her eat. All good.
    Toy4X4 likes this.
