What suspension components do I need?
Discussion in 'Suspension' started by doc57, Mar 20, 2024.
  1. Mar 20, 2024 at 8:06 PM
    doc57
    doc57 [OP] New Member
    Isaac
    2011 4Runner
    Hello I’m new to this forum and to the 4Runner scene in general. I’ve been wanting to get into overlanding just not sure where to start. What suspension components do I need for light off roading and camping? Do I just need better shocks? Just upgraded springs? Just a level kit? Or do I need to completely overhaul the suspension and get all knew springs, struts, shocks, control arms?
  2. Mar 20, 2024 at 10:27 PM
    Stoney Ranger
    Dave
    Driftless Area
    '18 SR5 Nauti Blue
    Before you buy anything, determine what the terrain will be like and if you really need to upgrade. What do you consider "light off-roading"? If you're running fire lanes, the stock suspension will probably be fine. If you need better approach and departure angles then a lift would be in order. I have a bottom of the barrel Dobinson suspension and it got me here with the factory UCA's.
    doc57[OP] likes this.
  3. Mar 20, 2024 at 11:04 PM
    Kwikvette
    Kwikvette Kwik Fab
    Multiple
    Keep it stock and gain experience until you can really benefit from such upgrades; a quality set of tires will get you far in a stock setup
  4. Mar 21, 2024 at 9:55 AM
    doc57
    Isaac
    2011 4Runner
    Okay thank you. My main concern is in the future will the factory springs be able to handle the extra weight from rooftop tents, bumpers, wench, sliders etc?
  5. Mar 21, 2024 at 10:02 AM
    backpacker
    backpacker New Member
    2023 TRD ORP
    You'll need stiffer springs if you add all that weight, which will require some planning. Be realistic about what you're going to add and when.
    My suspension is still stock, and it won't change for the foreseeable future.
    doc57[QUOTED][OP] likes this.
  6. May 2, 2024 at 8:40 AM
    jeepster09
    jeepster09 "Old"-Member....
    Twin Cities MN
    4Runner 2008 Sport
    A work in progress.....
    First off how many miles on it? If it has high miles you may want new springs and shocks. If it is low mileage stock may be fine for now.
  7. May 2, 2024 at 11:00 AM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Nothing...
    A stock 4R is very well equipped from for 99% of forest roads. Good tires will get you just about anywhere you need to go.
    If you start finding rock gardens or going to off road parks you will discover small weaknesses. Address those as they come up.
    Soon you'll have a purpose built rig for your use case.
    There is no set formula. Everyone's use case is different, and people modify for their individual needs.
    Dumping a bunch of money on sh*t people on the internet say you "need" is about the dumbest thing possible.
    jeepster09 likes this.
  8. May 2, 2024 at 11:18 AM
    I agree with others. Keep it stock and determine what your off roading needs are. I waited a year and noticed I needed additional clearance and I also wanted to go to Toyota Jamboree wheee I knew I’d need a better suspension. I then purchased Eibach
